#6805964 - 01/02/13 08:10 PM basement subfloor question
Choco 'Nuck Offline
Proud Member of BLM
Loc: Somewhere out there
So any of you chumps do your basement yourself? Mine is finished, but I am ripping out the carpet. I'm planning on using drilock for the subfloor and then some 5" Bruce turlington lock and fold engineered wood in a floating floor.
http://www.1aflooring.com/productslist.aspx?cid=563
What did you use for a subfloor? Is there a better or cheaper subsitute than drilock?
#6805982 - 01/02/13 08:22 PM Re: basement subfloor question [Re: Choco 'Nuck]
loudsubz Offline
platon + OSB on mine, cheaper than those pre made panels but less convenient if you have a hard time getting full stock into your basement. Its the same thing.
#6805983 - 01/02/13 08:23 PM Re: basement subfloor question [Re: Choco 'Nuck]
robbbby Offline
master electrician
Loc: Canada
wtf is drilock? google didn't turn up much except drylock roll on sealer. Do you mean dricore?
#6805987 - 01/02/13 08:24 PM Re: basement subfloor question [Re: robbbby]
Choco 'Nuck Offline
Proud Member of BLM
^^ Haha, yeah, dricore, don't know why I typed drilock
Wife is also bugging me to do infloor heating, anyone install this?
http://www.warmlyyours.com/en-US/floor-heating/hardwood-heating
#6805989 - 01/02/13 08:25 PM Re: basement subfloor question [Re: robbbby]
robbbby Offline
master electrician
Loc: Canada
platon is crap! terrible load ratings compared to deltafl.
But ya, I did deltafl + 5/8 OSB
#6805993 - 01/02/13 08:27 PM Re: basement subfloor question [Re: Choco 'Nuck]
robbbby Offline
master electrician
Loc: Canada
That stuff is a GIANT fucking ripoff. You can do it for 1/4 of the price if you put in a bit of work. Not to mention because it is in 2x2' sections and it doesn't butt up perfect you have moisture get between the actual membrane. Slim chance it would rot the osb or anything would even happen, but still, for that price, fuck that shit.
#6805999 - 01/02/13 08:28 PM Re: basement subfloor question [Re: robbbby]
Choco 'Nuck Offline
Proud Member of BLM
So you OSB was just floating over the deltafl?
#6806004 - 01/02/13 08:29 PM Re: basement subfloor question [Re: robbbby]
robbbby Offline
master electrician
Loc: Canada
I think you will find that you wont need infloor heat with a raised membrane subfloor, does not get cold at all
#6806006 - 01/02/13 08:30 PM Re: basement subfloor question [Re: Choco 'Nuck]
robbbby Offline
master electrician
Loc: Canada
No tapconed down, silicone applied to the tapcons before fastening. Makes for a super sturdy floor. Floor will be shitty if you just float the OSB over a membrane, plus good luck finding perfectly flat pieces of osb.
#6806007 - 01/02/13 08:31 PM Re: basement subfloor question [Re: robbbby]
Choco 'Nuck Offline
Proud Member of BLM
One more question, where would be a good location to rent a table say for ripping (cheapest for say a week). I have a mitre saw already, but I figure I'll need a table saw as well.
#6806009 - 01/02/13 08:33 PM Re: basement subfloor question [Re: robbbby]
Choco 'Nuck Offline
Proud Member of BLM
The silicone is to seal the holes in the deltafl? So you used a hammer drill to install the tapcon screws into the concrete. What size tapcons?
#6806016 - 01/02/13 08:35 PM Re: basement subfloor question [Re: Choco 'Nuck]
I can lend you my table saw (used it to do my hardwood floor) but it's fucking old school heavy mofo and in my shed. When do you need it?
#6806021 - 01/02/13 08:39 PM Re: basement subfloor question [Re: Risky Business]
Choco 'Nuck Offline
Proud Member of BLM
Not for another 4 weeks or so. Need to wait for hardwood to come in. Are you going to lend me your $200 shed building skills too? Beer is on me
#6806030 - 01/02/13 08:43 PM Re: basement subfloor question [Re: Choco 'Nuck]
loudsubz Offline
You don't need silicone, thats just bananas
also don't need a table saw, circular saw or circular saw + saw sled are more than enough. You are more likely to hurt yourself using a table saw trying to rip big sheet goods unless you have the proper setup with in and outfeed support.
#6806039 - 01/02/13 08:46 PM Re: basement subfloor question [Re: Choco 'Nuck]
robbbby Offline
master electrician
Loc: Canada
hammer drill hole, apply silicone to threads (JUST LIKE DELTA TELLS YOU TO DO, IT'S NOT FUCKING BANANAS!!!!), install. 1/4" tapcons x whatever length you need. And a table saw is pointless, you just need a skill saw, it's not precision cutting.
#6806063 - 01/02/13 08:58 PM Re: basement subfloor question [Re: robbbby]
loudsubz Offline
Bananas. The silicone is most likely not doing squat by the time its screwed down into place. Plus the fact that its unlikley water will ever penetrate any of the holes you drilled. Did you silicone all the cracks in the floor too? lol
#6806066 - 01/02/13 09:00 PM Re: basement subfloor question [Re: robbbby]
loudsubz Offline
Delta FL is too expensive and hard to find in some areas.
Unless you have an elephant in your basement than you are fine, thats what the OSB is for to distribute the weight load as well, its not rocket science. If it was such a bad product people would be complaining.
Go troll somewhere else lol
#6806082 - 01/02/13 09:08 PM Re: basement subfloor question [Re: loudsubz]
its pretty obvious OP should just buy a new house
#6806101 - 01/02/13 09:16 PM Re: basement subfloor question [Re: Euphoricuck]
Choco 'Nuck Offline
Proud Member of BLM
I wish I could, but I don't have Flexin's or Risky's budget
#6806103 - 01/02/13 09:17 PM Re: basement subfloor question [Re: loudsubz]
robbbby Offline
master electrician
Loc: Canada
Deltafl was cheaper. Rona son.
#6806108 - 01/02/13 09:20 PM Re: basement subfloor question [Re: loudsubz]
robbbby Offline
master electrician
Loc: Canada
You're just mad you didn't put silicone on your shitty wet floor. Enjoy your moisture chump!
#6806198 - 01/02/13 09:56 PM Re: basement subfloor question [Re: robbbby]
loudsubz Offline
In general Platon can be had cheaper than Delta FL. Delta FL also comes in smaller rolls generally so it may seem cheaer but Price Per Sqaure foot its usually more expensive. Check out the nerds on RFD, they documented it to death avg 0.30 psf for Platon and 0.5X for Delta FL
#6806200 - 01/02/13 09:56 PM Re: basement subfloor question [Re: robbbby]
loudsubz Offline
I embrace the wetness, nobody likes going in dry
#6806205 - 01/02/13 09:58 PM Re: basement subfloor question [Re: loudsubz]
LNXGUY Moderator Offline
Wayne, if you need a hand let me know. I might wanna borrow that 100-400mm again
#6806295 - 01/02/13 10:29 PM Re: basement subfloor question [Re: LNXGUY]
Screamin' Type-R Offline
The R stands for exactly what you think it does.
yet another mike holmes thread special
#6806544 - 01/03/13 05:51 AM Re: basement subfloor question [Re: LNXGUY]
Choco 'Nuck Offline
Proud Member of BLM
I'll send a PM to all the CSI Mike Holmes when I get all the materials etc \:\)
#6806559 - 01/03/13 06:19 AM Re: basement subfloor question [Re: Choco 'Nuck]
Right on dude.
#6806885 - 01/03/13 10:39 AM Re: basement subfloor question [Re: Choco 'Nuck]
c2k Moderator Offline
seriously?
heated steering wheel and now heated floors?
has your wife ever heard of wearing slippers for cold floors or gloves for cold steering wheel?!?!!
Who cares
#6806889 - 01/03/13 10:42 AM Re: basement subfloor question [Re: c2k]
loudsubz Offline
Heated floors rock, esp in the bathroom
#6806923 - 01/03/13 11:01 AM Re: basement subfloor question [Re: loudsubz]
Choco 'Nuck Offline
Proud Member of BLM
Yes, they do! Even better when you have a towel warmer.
seriously?
You have no idea how nice a heated steering wheel is in the middle of winter!
#6808216 - 01/03/13 07:19 PM Re: basement subfloor question [Re: Choco 'Nuck]
qwiksi Offline
Loc: North Pole
My current house the previous owner used the dricore subfloor tiles,900 sq ft basement must of cost the guy huge bucks! We can definatly stay down here comfortably.I wanted to use them at my old house but they were to costly so I just threw the laminate over the concrete(with the thickest underlay) and boy was it cold down there.So for me,yes I feel the difference in comfort level.
My kids will actually stay down there for hours without bugging us now.
#6808303 - 01/03/13 08:01 PM Re: basement subfloor question [Re: qwiksi]
Choco 'Nuck Offline
Proud Member of BLM
Anyone have a wholesale account to get dricore at a discount?
#6808345 - 01/03/13 08:19 PM Re: basement subfloor question [Re: Choco 'Nuck]
robbbby Offline
master electrician
Loc: Canada
you have too much money to burn if you insist on dricore.
Moderator:  c2k, LNXGUY, TheRealCSnapper, The Mad Paki
