#157254 - 04/20/06 09:08 AM
Re: How to Polish your Rims
teal_dx
sweet write up.
i did mine in white after i polished them, cause the idiot put a weight on the lip when i specifically told him to put it inside.
Those look good! like mini-Type R's got any pics of them on your civic?
#157255 - 05/02/06 01:41 PM
NY-Si
Loc: NY
what would u use for a clear coat?
#157256 - 05/08/06 09:49 PM
Stryker124
Loc: Mentor, Ohio USA
#157258 - 05/09/06 08:54 PM
teal_dx
NICE JOB man... that looks great!!! Looks like you used Duplicolor Graphite wheel paint for the inset parts of the spokes? can't wait to see how they look on your Si,, 3 more to go!
#157259 - 05/09/06 10:18 PM
Stryker124
Thanks, and yes, I followed your example and used the Duplicolor Graphite wheel paint. That stuff is really nice to work with.
2010 Mazdaspeed3 "Please, please let the warranty expire soon...I needs a downpipe and some ECU work..."
#157260 - 05/30/06 01:08 PM
Katharine McPhee
Loc: Boston Area
Wow, what a difference. I just got done polishing my hytech header... I think I am enough confidence to try this on my CP-035s. I've been having problems selling these, so I might as well have a polished set... it'll be the only 16" CP-O35Rs that I know of.
#157261 - 06/01/06 03:32 AM
dd2000si
Loc: Vaughan
WOW, props for the write up and the hard dedicated work put in to those rims, excellent job!
#157264 - 09/06/06 12:11 AM
pacey
Loc: CA, USA
You did a good job man!! I'm thinkin about doin it to mah gsr rims..
#157265 - 09/08/06 01:02 AM
pacey
Loc: CA, USA
Btw, what if i dont want it that shiny.. i want to make it like OEM? what should i do? can anyone help me? thank you!
#157267 - 12/22/06 09:19 AM
teal_dx
If you don't want the bling factor, then stop after you wetsand with 2000 grit and don't do the mother's polish.
after 2000 grit:
(close rim is 2000, back one is 240)
edit: here is side by side of 2000 grit and 2000 grit after mother's polish. The rim would still look great if you didn't use the mothers and left it at 2000:
Edited by teal_dx (12/22/06 09:24 AM)
#157268 - 12/22/06 09:22 AM
teal_dx
Has anyone polished any ls wheels? I take it that it would be the same but the inside of the spokes are really rough. Do i just sand them aswell?
I would just work on polishing the face and paint the sides of the spokes where it has the rough cast surface. otherwise you will be sanding and polishing for a looooong time if you do the sides of the spokes too. I like to paint the sides of the spokes with the Duplicolor Graphite, it gives the rims an OEM look.
#157269 - 12/22/06 09:48 AM
teal_dx
here's some more pics of polished rims!
cl rims = hawt RZR's
Si's only slightly polished  HX's only slightly polished
RSX, these must have been a bitch, all curved surfaces!
Teg Blades
CRX Si's
LS Meshies
slipstream
some optional Honda wheel
fat 5
#157271 - 12/22/06 07:15 PM
teal_dx
for 8 million dollars. I'm never doing that shit again  Actually I have some Fat 5's I'm thinking about polishing or painting black. Most rims are going to be way easier than the HX's I did because of all the curved spokes and the lip. Those RSX rims above were probably just as hard as the HX's but fat 5's, Si's, crx Si's and most other Honda alloys have the flat face which makes life easier when polishing
#157273 - 12/23/06 07:43 PM
hkt03
Loc: Chicago, IL
#899904 - 01/11/07 12:27 PM
[Re: Napoleon3]
Stryker124
Have any of you had your wheels sand blasted before you polished them?
I didn't but that would help take the clearcoat off, which would save a little sanding time, and it might help take down some of the factory machining which would help as well.
#992898 - 02/01/07 10:22 PM
[Re: PurduinaSi]
teal_dx
just polishing the lip would be easy. The lip is the easiest part to do by hand because it is a uniform surface. It would take 2 mins for each grit of sand paper to do just the lip of a rim. a sander is only going to help on a flat surface, so you could use it on the very outer edge if it is flat like OEM rims are. But by the time you install the paper on the sander, you could have probably sanded it with a block by hand. any pics of the rims?
#1136444 - 03/08/07 06:14 PM
[Re: teal_dx]
BrianGriffin
That looks awesome! Good Job!
#1160948 - 03/15/07 09:03 PM
[Re: 99 SI AutoXer]
B16BSTD
I heard somewhere on the net that if you put the front end of your car on jackstands and start the car and put it in gear then you can easily polish the lip of the wheel. I tried it and it worked great.
I went from this:
To this:
Moderator: Dr. BrokenLimits, The Mad Paki
