ClubSi
#2692149 - 06/02/08 04:03 PM 99 Civic Si - Replaced o2 sensor, still getting same code
kbourque Offline
Loc: Nova Scotia, CA
Hey guys,
After getting code 61 (Primary oxygen sensor) a couple times I had the sensor replaced and I'm still getting the same code. CEL stayed off for a week then came back on. Should I try resetting the ECU? What else could be causing this?
Or are there too many possibilities to list.
Any info would be appreciated.
Thanks
Kris
#2692313 - 06/02/08 04:47 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same cod [Re: kbourque]
hammeredsi Offline
Loc: WA
did you check the fuse?
#2714459 - 06/09/08 09:23 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same cod [Re: hammeredsi]
kbourque Offline
definitely not the fuse, the garage I bring my car to can't figure it out either and recommended I go to the dealer so I may have to go there. I suspect it may be wiring.
Edited by kbourque (06/09/08 09:24 PM)
Kris
#2721299 - 06/11/08 06:56 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same cod [Re: kbourque]
DevoStevo Offline
CSI Cars 4 Sale Dealer
Loc: usa
Did you try replacing your spark plugs with some NGK plugs and then resetting your ecu(unplug your battery for a few mintes)and trying it again.
“ All in all, you're just another brick in the wall.”
#2734198 - 06/16/08 12:40 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: kbourque]
kbourque Offline
The garage showed me that it keeps throwing the "Front Oxygen Sensor Slow Response" code. They also tested it while driving and said the O2 Sensor was working perfectly so it's most likely not that. Just to make sure though they are going to try ONE more O2 Sensor.
Could I get a "Slow Response" code because of Spark Plugs?
Thanks for the help.
Kris
#2734388 - 06/16/08 01:28 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: kbourque]
garden_gnome Offline
Loc: red deer, alta
do you have a factory manifold? i have seen a slow response code from inproperly placed o2 sensors in after market headers.
89 si 1.8 n20 hatch 89 crx si sold 99 ford exploder "have you hugged your honda today"
#2860536 - 07/28/08 12:44 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: garden_gnome]
skatrsi Offline
Loc: Virginia, USA
I am having the same problem in my 00 Si. I was getting the slow to respond code so i went ahead and replaced both o2 sensors. The light went off for a week and now its back on, I tried resetting my ecu and it came back on a day later. I am pretty lost with this.
#2860720 - 07/28/08 01:32 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: skatrsi]
Design Offline
Might try checking the headers for any cracks/leaks.
01 Echo 5MT
#2864430 - 07/29/08 01:59 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: Design]
Si's_RUS Offline
where are you guys getting your sensors from,honda?or like auto zone?
#2881166 - 08/04/08 08:48 AM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: Si's_RUS]
skatrsi Offline
Loc: Virginia, USA
My sensor did come from Car quest but i don't believe thats the problem, since it is throwing the same code as before. Thanks for everyones input
#2886163 - 08/05/08 04:58 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: skatrsi]
Import Tuner Offline
Gold Member
Loc: Tacoma, Wash..
Unfortunately, aftermarket sensors are notorious for slow response and out of parameter codes (even when new)...
Donny
Import Specialty Automotive
#2891275 - 08/07/08 08:31 AM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: Import Tuner]
gtrcivic Offline
Loc: Northern VA
last summer with 160k on the clock, i got the PO code for bank1/bank 2 so i went ahead and ordered ngk o2 sensors and a cat from the web and got all 3 installed..no more CEL
#2895399 - 08/08/08 02:41 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: gtrcivic]
Gold Member
Loc: Tacoma, Wash..
Yeah, you want to use O.E., Denso, or at least NGK...
The guys that use Bosch, Beck Arnley, or whatever the auto parts sells CHEAP are the guys that have recurring CELs...
Donny
#2922416 - 08/18/08 12:36 AM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: Import Tuner]
MUGEN RR Offline
Use Scan tool to check FF, because Honda have TSB for ECU replacement for that P0133
#2936207 - 08/20/08 11:02 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: MUGEN RR]
justfocus Offline
Loc: Va Bch VA
Is there a link to this TSB? I am in a similar situation...
#9122616 - 09/03/17 09:35 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: justfocus]
fatihin nurul Offline
ninggalkannya lagi kita akan kehilangan dia. Va Distributor plat besi hitam
undangan pernikahan bentuk tas
Distributor plat kapal besi baja
Agen besi beton interworld steel is
undangan pernikahan modern
Toko Plat Bordes Kembang
Distributor Pipa Besi baja Schedule Sch 40
Distributor besi cnp baja
jasa konstruksi baja
Harga plat besi hitam
undangan pernikahan biru
sewa villa puncak
Harga plat kapal besi baja
Agen besi beton gunung garuda
undangan pernikahan biasa
Toko Plat Besi Hitam
Supplier Pipa Besi baja Schedule Sch 40
Harga besi cnp baja
www.pusatbesibaja.co.id
Jual plat besi hitam
Jual plat kapal besi baja
Agen besi beton delcoprima
Toko Plat Kapal Bki Krakatau Steel
Agen Pipa Besi baja Schedule Sch 40
Jual besi cnp baja
www.pusatbesibaja.com
Supplier plat besi hitam
undangan pernikahan bagus
Supplier plat kapal besi baja
Agen besi beton cakra steel cs
undangan pernikahan cantik elegan
Toko Jual Besi Siku Baja
Toko Pipa Besi baja Schedule Sch 40
Supplier besi cnp baja
Toko plat besi hitam
undangan pernikahan bermanfaat
Toko plat kapal besi baja
Agen besi beton bjku
undangan pernikahan akrilik
Toko Besi Unp Baja Profil Kanal
Jual Pipa Besi baja Schedule Sch 40
Toko besi cnp baja
Supplier besi beton Sni Ulir Polos polos ulir
Agen plat besi hitam
Agen plat kapal besi baja
Agen besi beton Sni Ulir Polos
Toko Besi Cnp Profil Baja Gording
Harga Pipa Besi baja Schedule Sch 40
Agen besi cnp baja
Supplier besi beton sii
Pabrik plat besi hitam
undangan pernikahan anti mainstream
Pabrik plat kapal besi baja
Agen besi beton ais
undangan pernikahan coklat
Toko Besi Hollow
Pabrik Pipa Besi baja Schedule Sch 40
Pabrik besi cnp baja
Supplier besi beton psi Ulir Polos
undangan pernikahan klub bola
Distributor besi siku baja
Agen besi beton
undangan pernikahan kalender
Toko Wiremesh
Distributor Pipa Besi baja Schedule sch 80
Distributor besi unp baja
Supplier besi beton perwira
undangan pernikahan cetak
Harga besi siku baja
Toko Besi Pipa Baja Schedule 80
Supplier Pipa Besi baja Schedule sch 80
Harga besi unp baja
Supplier besi beton PAS
Agen stainless steel
Jual besi siku baja
undangan pernikahan arab
Toko Besi Pipa Baja Schedule 40
Agen Pipa Besi baja Schedule sch 80
Jual besi unp baja
Supplier besi beton master steel ms
Agen atap spandek
Supplier besi siku baja
Toko Pipa Besi Hitam Medium
Toko Pipa Besi baja Schedule sch 80
Supplier besi unp baja
Supplier besi beton ksty
Agen baja ringan
Toko besi siku baja
undangan pernikahan custom
Toko Besi Wf
Jual Pipa Besi baja Schedule sch 80
Toko besi unp baja
Supplier besi beton krakatau steel
Agen bondek
Agen besi siku baja
Toko besi beton Sni Ulir Polos polos ulir
undangan pernikahan klasik
Toko Besi H beam
Harga Pipa Besi baja Schedule sch 80
Agen besi unp baja
Supplier besi beton jcac
Agen Plat kapal besi baja bki krakatau steel
Pabrik besi siku baja
Toko besi beton sii
undangan pernikahan batik
Toko Besi Beton
Pabrik Pipa Besi baja Schedule sch 80
Pabrik besi unp baja
Supplier besi beton interworld steel is
Agen besi siku
Distributor besi wf
Agen besi Wf Baja
undangan pernikahan
www.sentrabesibaja.com
Distributor besi h beam baja
Supplier besi beton gunung garuda
undangan pernikahan islami
undangan pernikahan online
undangan pernikahan
undangan pernikahan simple
undangan pernikahan murah
undangan pernikahan artis
undangan pernikahan
undangan pernikahan
LINK 9
#9190020 - 11/17/17 09:06 AM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
abercrombie and fitch
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
#9214671 - 12/20/17 08:39 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: ]
20171221yuanyuan Offline
nike outlet store
louis vuitton outlet store
ugg boots
ugg boots
ralph lauren sale
the north face outlet
air max
ray ban sunglasses discount
pandora jewelry outlet
fred perry polo shirts
cheap ugg boots
canada goose jackets
coach factory outlet online
michael kors outlet clearance
nike outlet store
timberland outlet
longchamp sale
gucci outlet
oakley sunglasses outlet
adidas outlet online
ugg
longchamp bags
birkenstock outlet
michael kors outlet store
retro 11
adidas nmd r1
burberry handbags
supreme clothing
toms shoes
canada goose coats
ray ban glasses
yeezy shoes
air jordans
hermens
louboutin outlet
pandora charms sale
valentino outlet
ugg outlet store
cheap ugg boots
discount oakley sunglasses
coach outlet canada
ray bans
nike outlet online
canada goose outlet store
adidas nmd r1
canada goose coats
fred perry shirts
burberry outlet online
nike outlet online
yeezy boost 350
adidas nmd runner
canada goose coats
kate spade outlet online
moncler sale
moncler jacket
ugg boots
ugg boots
north face outlet
north face sale
burberry outlet
louis vuitton factory outlet
canada goose coats
jordans
nike sneakers
ugg boots sale
moncler
bottes ugg
pandora uk
supreme uk
adidas yeezy boost
ugg outlet store
pandora uk
ray bans
ray ban sunglasses cheap
nmd adidas
hermes bag
moncler jackets
pandora
longchamp outlet store
ugg boots
ugg outlet store
valentino
coach handbags outlet
mulberry
adidas yeezy boost 350
ugg canada
ugg boots
salvatore ferragamo shoes
uggs
red bottoms
north face outlet
mbt
ugg boots
ugg outlet online
coach factorty outlet online
yeezy boost 350
canada goose coats
cheap jordans free shipping
moncler sale
uggs clearance
moncler coats
ugg australia outlet
adidas ultra boost
cheap ugg boots
adidas yeezy shoes
canada goose coats
cheap jordans for sale
nike sneakers
hermes outlet
moncler outlet online
tory burch outlet online
longchamp bags
ugg canada
uggs clearance
ugg boots outlet
ugg boots outlet
ralph lauren sale
nike air max 2018
hermes handbags
adidas outlet store
air max
caterpillar boots
air jordan retro
ugg sale
adidas sneakers
moncler uk
air max shoes
gucci outlet online
moncler jackets
fitflop sandals
hermes bags
cheap air jordans
supreme shirts
pandora charms outlet
ugg outlet online
burberry handbags
moncler pas cher
harden vol 1
mulberry uk
moncler coats
nike outlet store online
adidas yeezy boost
cheap air jordans
ugg boots
moncler jackets
coach purses
burberry handbags
adidas outlet store
north face jackets
yeezy shoes
red bottom heels
yeezy boost 350
mulberry outlet uk
michael kors outlet canada
ugg boots
birkenstock shoes
michael kors bags
cheap uggs
ugg boots
cheap ugg boots
adidas superstars
canada goose jacket
coach outlet canada
mlb jerseys cheap
adidas nmd r1
adidas store
ugg boots outlet
salvatore ferragamo outlet
air jordan shoes
moncler uk
moncler coats
timberland outlet store
ugg outlet online
columbia sportswear outlet
yeezy shoes
canada goose jackets uk
canada goose outlet online
canada goose parka
cheap nfl jerseys wholesale
uggs on sale
adidas superstar shoes
birkin handbags
cheap air jordans
mbt
the north face jackets
red bottom
louboutin outlet
pandora jewelry store
adidas nmd runner
uggs on sale
north face jackets
hermes bags
ugg boots
ugg boots women
tory burch shoes
ugg boots
ugg outlet store
#9235944 - 01/21/18 09:06 PM Re: 99 Civic Si - Replaced o2 sensor, still getting same code [Re: 20171221yuanyuan]
Andada
colts jerseys
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
michael kors handbags sale
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
buffalo bills jerseys
fitflops sale
nike huarache
seattle seahawks jerseys
jaguars jersey
Moderator:  The Mad Paki, KenNN
