ClubSi
#1634970 - 07/11/07 04:55 PM D16Z6 Ticking, sounds like a spun bearing, but...
SPAZ Online   bluecheckmark
Loc: Mars
My engine is ticking pretty badly, sounds like a used sewing machine, however it idles fine minus the tick, so I'm pretty sure it's not a valve, I think it may be a spun rod bearing, but there is no metal in the oil? How do I diagnose this issue without pulling off the oil pan? I have no garage to work in at the moment. \:\(
avatar too big
#1635365 - 07/11/07 06:32 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: SPAZ]
Alloyking Offline
Loc: Minneapolis
-Does the ticking sound increase with Engine speed?
A spun bearing I believe will get louder with RPM
It could be that your timing belt or camshaft timing is off. But if the engine isn't running really bad, or backfiring.. I'd say it's a valve.
Sometimes you can also get a tick from bad bearings in an alternator, water pump, etc. I would imagine the sound from these would not get louder with the RPM.
If you can't remove the oil pan. I'd say get a long screw driver, then while the engine is running. Place the Screw driver end on various places and stick your ear against the handle. This will amplify the sound for you... and you might get a better idea on where the sound is comming from.
#1637742 - 07/12/07 11:10 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: SPAZ]
Import Tuner Offline
Gold Member
Loc: Tacoma, Wash..
You can pull the plug wires (one at a time) and see IF the noise deminishes once you've taken away the power stroke of the piston / rod / crankshaft assy...
Donny
Import Specialty Automotive
#1638998 - 07/12/07 03:53 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: Import Tuner]
Loc: Mars
Awesome, that's what I'll do.
Also, if it is the bearing, am I going to have to get the rank resurfaced? I hasn't run very long with the ticking sound going on, can I just replace the bearing?
Edited by SPAZ (07/12/07 03:57 PM)
avatar too big
#1640607 - 07/12/07 11:43 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: SPAZ]
Gold Member
Loc: Tacoma, Wash..
Unfortunatly, rod knocks (read bearing failures) are generally caused by lack of lubrication or the motor being overreved...
Lack of lubriction would more than likely require the crank being turned...
Overreving would require the rod journal being resized...
It's not to often that you can just replace the bearing...
Donny
#1644277 - 07/13/07 09:38 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: Import Tuner]
Loc: Mars
Yeah, this problem resulted from my oilpan having a ding in it that leaked a good majority of the oil out of the system, when I finally got the oil light, it was too late. \:\(
avatar too big
#1646666 - 07/15/07 02:16 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: SPAZ]
4doorEG Offline
Loc: Overland Park, KS
The single cam is cheap enough, it may be cheaper for you to find a used engine than it would be to PROPERLY fix your damaged engine.
#1653435 - 07/17/07 08:30 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: 4doorEG]
EBP_99 Offline
Loc: Ky
my 99 si also has a tickin sound but it doesnt get any louder or softer but does increase in speed as the rpms rise. ive been told that it could be either lifers pecking or valve chatter. is there any way to get a better idea which other than pulling the valve cover
ebp em1, dc 4-2-1 ceramic header, comptech intake, mugen twinloop, hr springs
#1653647 - 07/17/07 09:48 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: EBP_99]
Gold Member
Loc: Tacoma, Wash..
If you pull the valve cover, you'll notice you don't have lifters (I assume that's what you meant), so that may help to narrow it down for you...
Donny
#1656103 - 07/17/07 07:40 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: Import Tuner]
EBP_99 Offline
Loc: Ky
yeah i meant lifters, thats just what i was told by a mechanic who looked it up in his manual and told me thats what it was and that they had screw adjustments which meant that he could attempt to stop the noise if that was the cause instead of takin it to a honda dealer.
i dont know much about motors so i would not know either way.
any ideas on what it could be?
Edited by EBP_99 (07/17/07 07:41 PM)
#1656809 - 07/17/07 11:50 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: EBP_99]
Gold Member
Loc: Tacoma, Wash..
They are actually "cam followers" which simply follow the cam lobes and open the valve accordingly...
They are in fact adjustable and your mechanic should be able to perform that feat fairly easily...
Donny
#1657578 - 07/18/07 09:51 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: Import Tuner]
EBP_99 Offline
Loc: Ky
in that case does a price of $250 sound to expensive? its was a small shop in central Ky. another shop said $50-$60. quite a difference in my opinion
#1657610 - 07/18/07 09:59 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: EBP_99]
Gold Member
Loc: Tacoma, Wash..
I charge $60.00, so yea I'd think $250.00 is quite excessive...
Donny
#9189938 - 11/17/17 08:52 AM Re: michael kors factory outlet [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
abercrombie and fitch
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
#9190028 - 11/17/17 09:06 AM Re: michael kors factory outlet [Re: chenlixiang]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
hermes
burberry
lunette oakley
watches for men
softball bats
five finger shoes
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
nike roshe
thomas sabo uk
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
Moderator:  The Mad Paki, KenNN
