ClubSi
#267942 - 05/23/06 01:46 AM audio & security wiring thread.
00CivicSI-R Offline
Loc: westchester county, NY
Hey guys, I thought I would post this to help out in this forum.
RADIO HARNESS:
+12V DC battery(constant) white/blue fuse # 47- 7.5 amp(underhood fuse box)
Switched accessory yellow/red fuse # 28- 10 amp( underhood fuse box)
Ground black
Illumination Red/black & red stripe
Left front + blue
Left front - gray/black
Right front + blue
Right front - brown/black
Left rear + blue/yellow
Left rear - gray/white
Right rear + red/yellow
Right rear - brown/white
AT SPEAKERS:
left front mid + red/green
left front mid - brown/black
left front tweeter + red
left front tweeter - blue
right front mid + blue
right front mid - gray/black
right front tweeter + red
right front tweeter - blue
DISASSEMBLY OF RADIO:
1. Open glove box and drop down by releasing rear clips.
2. Remove black bolt on left bottom and screw on top left.
3. Remove drivers underdash panel by removing threew screws and remove
4. Remove screw on top righ and bottom left holding the center underdash panel in.
5. Remove two vertical screws holding center underdash panel and remove.
6. Remove two silver screws in rear of radio and two in front of radio.
7. Carefully remove bezel including radio and climate control assembly by releasing clips and unplug all connectors.
8.Remove climate control assembly by removing four screws in rear and removing knobs in front.
9. Remove four screws securing radio/pocket assembly and remove.
SECURITY/REMOTE START WIRING:
(wire/function) (color) (location) (polarity)
12 volts white ignition harness +
Ignition blk/yellow ignition harness +
Accessory yellow ignition harness +
Starter blk/white ignition harness +
key sense blue/white ignition harness -
Tach signal blue test connector AC
(under hood drivers side in white plug)
Lock green/white in driver's kickpanel -
(or in factory alarm harness behind radio)
Unlock green/orange in driver's kickpanel -
Doorpin lite green/red in driver's kickpanel -
Trunk pin blue/black in driver's kickpanel -
Brakeswitch green/white at switch above pedal +
Parklights red/black at light switch harness +
Hand brake green/red in connector above driver's kickpanel -
Horn blue/green at steering column -
Clutch switch black/red at relay above driver's kickpanel Type 1
Driver's windows up red/yellow at switch in driver's door rev Pol
Driver's windows down red/blue at switch in driver's door rev Pol
passenger window up blue/yellow at switch in driver's door rev Pol
passenger window down blue/orange at switch in driver's door rev Pol
Reverse Lights green/black large harness in driver's kickpanel +
Dimmer red at dimmer switch harness
VSS wire blue/white in 20-pin plug above fusepanel 4000ppm
I hope this was hopefully. Any questions post or pm me
Juno aim: iamyatypema
#267943 - 05/23/06 10:34 AM Re: audio & security wiring thread.
Design Offline
Looks good. Please state make and model (06 Si?).
01 Echo 5MT
#267944 - 05/23/06 07:21 PM Re: audio & security wiring thread.
00CivicSI-R Offline
oh yea sorry about that LOL. this is the wiring for 99-00 Civics.
#267945 - 05/24/06 12:23 AM Re: audio & security wiring thread.
Anonymous
funny, I was looking for a thread exactly like this on Sunday. We finished the wiring today and had to guess which wire was which for the rear speakers. If this is accurate, I did it right! :woot:
#267946 - 05/24/06 01:36 AM Re: audio & security wiring thread.
00CivicSI-R Offline
yes this is accurate. It was taken from a database internet program called Installology. Most shops use this database. I will post up the wiring for 02-05 Si and 06 Si soon.
#267947 - 05/30/06 12:34 AM Re: audio & security wiring thread.
TunedWhips Offline
Loc: Ontario Canada
2006 civic here is wire diagram for you.
This may not be 100% but its pretty close. Test all wire befor you make any conections..
12 VOLTS white (50a) + ignition harness
STARTER 1 yellow + ignition harness
STARTER 2 n/a
IGNITION 1 blue + ignition harness
IGNITION 2 n/a
IGNITION 3 n/a
ACCESSORY 1 orange + ignition harness
ACCESSORY 2 red + ignition harness
KEYSENSE pink - ignition harness
POWER LOCK green - dr kick or micu,34,pin plug,pin 28 The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
POWER UNLOCK gray - dr kick or micu,34,pin plug,pin 27 The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
DOORLOCK MOTOR blue 5wi dkp or fuse box,rear 14 pin plug
DOOR UNLOCK MOTOR yellow 5wi dkp or fuse box,rear 14 pin plug
DISARM NO UNLOCK see factory alarm disarm
FACTORY ALARM ARM orange - dr kick or micu,34,pin plug,pin 32 Meter this wire while turning the key in the driver door key cylinder. The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
FACTORY ALARM DISARM brown - dr kick or micu,34,pin plug,pin 31 Meter this wire while turning the key in the driver door key cylinder. The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
DISARM DEFEAT
PARKLIGHTS POSITIVE red + dr kick or fuse box,top 42 pin plug
PARKLIGHTS NEGATIVE gray - switch or micu,20,pin plug,pin 13 The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
HEADLIGHT pink - switch or micu,20,pin plug,pin 11 The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
HAZARD green + switch or fuse box,rear 16 pin plug
TURN LEFT blue + dr kick or fuse box,top 42 pin plug
TURN RIGHT brown + dr kick or fuse box,top 42 pin plug
REVERSE brown (4dr) or purple (2dr) + dr kick or fuse box,top 42 pin plug
BRAKE lt. green + switch or fuse box,top 42 pin plug
PARKBRAKE
DOOR PIN see notes - ea kick or fuse box,top 42 pin plug The LF door is green in pin 37. The RF door is lt. green in pin 3. The LR door is brown in pin 17. The RR door is gray in pin 2. Use all four wires and diode isolate each.
HOOD PIN lt. blue - pin sw or fuse box,mid 21 pin plug
TRUNK PIN blue - dr kick or fuse box,top 42 pin plug
DOMELIGHT SUPERVISION pink - fuse box,rear 8 pin plug Also found in a plug attached to the bottom of the fuse box.
TACH not blk/wht,black or yel/blk ac any ignition coil or fuel injector
VSS blue radio harness The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
GLOW PLUGS n/a
TRUNK RELEASE green + dr kick or fuse box,top 42 pin plug
SLIDEDOORS n/a
LEFT FRONT UP/DWN yel (4dr) or red (2dr) - green A driver window switch in door
RIGHT FRONT UP/DWN orange - brown A driver kick,door harness
LEFT REAR UP/DWN green - purple A driver kick,door harness
RIGHT REAR UP/DWN lt. blue - red A driver kick,door harness
SUNROOF LIMIT n/a
SUNROOF OPEN/CLOSE motor part of module
MEMORY SEAT 1 n/a
MEMORY SEAT 2 n/a
MEMORY SEAT 3 n/a
HORN orange - switch or fuse box,rear 16 pin plug
DEFROST
WIPER
RADIO 12V
RADIO GROUND black - radio harness
RADIO SWITCH purple + radio harness
RADIO ILLUMINATION gray or red/black + radio harness
FACTORY AMP TURN ON lt. blue + radio harness
POWER ANTENNA gray + radio harness
LEFT FRONT SPEAKER lt. green - pink +,- radio harness or amp under ctr dash On vehicles with the amplifier,the LF tweeter wires are red (+) - green (-).
RIGHT FRONT SPEAKER gray - brown +,- radio harness or amp under ctr dash On vehicles with the amplifier,the RF tweeter wires are pink (+) - blue (-).
LEFT REAR SPEAKER yellow - brown +,- radio harness or amp under ctr dash
RIGHT REAR SPEAKER blue - orange +,- radio harness or amp under ctr dash The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
#267948 - 05/30/06 12:36 AM Re: audio & security wiring thread.
TunedWhips Offline
Loc: Ontario Canada
2004 Civic sir
12 VOLTS white (40a) + ignition harness
STARTER 1 black/white + ignition harness
STARTER 2 n/a
IGNITION 1 black/yellow + ignition harness
IGNITION 2 n/a
IGNITION 3 n/a
ACCESSORY 1 black/red + ignition harness
ACCESSORY 2 white/red + ignition harness
KEYSENSE red/white - ignition harness
POWER LOCK white/blue - driver kick,door harness Photo
POWER UNLOCK white/green - driver kick,door harness Photo
DOORLOCK MOTOR yellow/black 5wi dkp or back of fuse box,top left
DOOR UNLOCK MOTOR yellow/green 5wi dkp or back of fuse box,top left
DISARM NO UNLOCK factory remote only
FACTORY ALARM ARM factory remote only
FACTORY ALARM DISARM factory remote only
DISARM DEFEAT
PARKLIGHTS POSITIVE red/black + back of fuse box,top middle Can also use red/yellow (+) at the front of the fuse box,18,pin plug,pin 15.
PARKLIGHTS NEGATIVE blue - switch or factory alarm plug The factory alarm plug is a green plug above the driver kick panel.
HEADLIGHT
HAZARD same as turn signal wires
TURN LEFT green/red + turn signal switch
TURN RIGHT green/yellow + turn signal switch
REVERSE green + frt of fuse box,18,pin plug,pin 1
BRAKE white/black + brake pedal switch The Immobilizer Control Unit is on the ignition key cylinder.
PARKBRAKE
DOOR PIN green/red - driver kick This wire is hard to reach in drivers kick and is beside roll tube at top of dash. Can also be found at factory security plug. Drivers door = Green. Pass door = Green/red.
HOOD PIN
TRUNK PIN red - frt of fusebox or factory alarm plug notes: the factory alarm plug is a green plug above the driver kick panel.
DOMELIGHT SUPERVISION green/red - back of fuse box,top right
TACH blue a/c engine comp Photo This wire is at the blue test connector located at the front of the engine compartment loom along fender, wrapped in blue tape.
#267949 - 05/30/06 12:38 AM Re: audio & security wiring thread.
TunedWhips Offline
Loc: Ontario Canada
2005 civic
STARTER 2 n/a
IGNITION 2 n/a
IGNITION 3 n/a
DISARM DEFEAT
HEADLIGHT blue/red - switch or factory alarm plug The factory alarm plug is a green plug above the driver kick panel.
PARKBRAKE
DOOR PIN see notes - frt of fusebox or factory alarm plug The driver door is green,the passenger door is lt. green/red,and the rear doors are green/white. Use all three wires and diode isolate each. The factory alarm plug is a green plug above the driver kick panel.
HOOD PIN n/a
TRUNK PIN red - frt of fusebox or factory alarm plug The factory alarm plug is a green plug above the driver kick panel.
TACH blue ac test tachometer connector The test tachometer connector is a two pin connector to the passenger side of the battery.
VSS white/green or blue/white ecm/pcm,pin a18 or e25 The ECM/PCM is behind the glove box. If equipped with cruise control,the vss wire is also blue/white at the cruise control unit to the left of the steering column on the sedans,or the cruise control actuator under the hood on the coupes.
GLOW PLUGS n/a
TRUNK RELEASE n/a
SLIDEDOORS n/a
LEFT FRONT UP/DWN red/black - red/yellow A driver window switch in door
RIGHT FRONT UP/DWN blue/red - blue/white A driver kick,door harness
LEFT REAR UP/DWN brown/white - brown A driver kick,door harness
RIGHT REAR UP/DWN blue/orange - brown/yellow A driver kick,door harness
SUNROOF LIMIT n/a
SUNROOF OPEN/CLOSE green/yellow - green/black A moonroof relays rear of moonroof
MEMORY SEAT 1 n/a
MEMORY SEAT 2 n/a
MEMORY SEAT 3 n/a
HORN orange - switch or factory alarm plug The factory alarm plug is a green plug above the driver kick panel.
DEFROST
WIPER
RADIO 12V
RADIO SWITCH yellow/red + radio harness
RADIO ILLUMINATION red/black + radio harness
FACTORY AMP TURN ON n/a
POWER ANTENNA yellow/green + radio harness
LEFT FRONT SPEAKER green/black - lt. green +,- radio harness
RIGHT FRONT SPEAKER green/yellow - gray/red +,- radio harness
LEFT REAR SPEAKER blue/white - blue/black +,- radio harness
RIGHT REAR SPEAKER pink - blue/yellow +,- radio harness
again check all wires befor you make any contacts.
#267950 - 05/30/06 12:41 AM Re: audio & security wiring thread.
TunedWhips Offline
Loc: Ontario Canada
2003 civic
12 VOLTS white + ignition harness
STARTER 2
IGNITION 2
IGNITION 3
KEYSENSE
POWER LOCK white/blue - gray plug above drivers kick
POWER UNLOCK white/green - gray plug above drivers kick
DOORLOCK MOTOR yellow/black back of the fusebox In the top left plug.
DOOR UNLOCK MOTOR yellow/green back of the fusebox In the top left plug.
DISARM NO UNLOCK
FACTORY ALARM ARM
DISARM DEFEAT yellow back of the fusebox In the top left plug.
PARKLIGHTS POSITIVE red/black + back of the fusebox
PARKLIGHTS NEGATIVE blue - factory alarm plug The factory alarm plug is a green plug above the drivers kick panel.
HEADLIGHT blue/red - headlight switch
HAZARD
TURN LEFT
TURN RIGHT
REVERSE
PARKBRAKE
DOOR PIN see notes - factory alarm plug The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white. The factory alarm plug is a green plug above the drivers kick panel.
HOOD PIN green/black silver dots - under hood harness in front of battery
TRUNK PIN red - factory alarm plug The factory alarm plug is a green plug above the drivers kick panel.
DOMELIGHT SUPERVISION comes on with unlock n/a
TACH blue test connector Far right in top plug in fusebox. Fusebox is right of steering column and can be lowered by removing 10 mm bolt. Alternate is test connector. It is a 2 pin plug to the passenger side of the battery.
VSS white/green pcm The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column or Blue/White near center plug of fusebox. Fusebox is right of steering column and can be lowered by removing 10 mm bolt.
GLOW PLUGS
TRUNK RELEASE n/a
SLIDEDOORS n/a
LEFT FRONT UP/DWN red/blk - red/yel A driver window switch
RIGHT FRONT UP/DWN blu/red - blu/wht A driver kick panel
LEFT REAR UP/DWN brn/wht - brown A driver kick panel
RIGHT REAR UP/DWN blu/org - brn/yel A driver kick panel
SUNROOF LIMIT
SUNROOF OPEN/CLOSE
MEMORY SEAT 1
MEMORY SEAT 2
MEMORY SEAT 3
HORN orange - steering column
DEFROST
WIPER blue (l), blu/yel(h) - steering column
RADIO 12V
FACTORY AMP TURN ON
POWER ANTENNA
LEFT FRONT SPEAKER grn/blk - lt. green radio harness
RIGHT FRONT SPEAKER grn/yel - gry/red radio harness
LEFT REAR SPEAKER blu/wht - blu/blk radio harness
RIGHT REAR SPEAKER pink - blu/yel radio harness
check all wires first
#267951 - 05/30/06 12:51 AM Re: audio & security wiring thread.
00CivicSI-R Offline
good shit bro..thanks for contributing.
#267952 - 05/31/06 04:11 PM Re: audio & security wiring thread.
TunedWhips Offline
Loc: Ontario Canada
Any time ..Just helping each other out
#267953 - 09/22/06 08:15 PM Re: audio & security wiring thread.
Need the wiring layout for the 92-95 crowd....
#267954 - 09/23/06 03:09 AM Re: audio & security wiring thread.
00CivicSI-R Offline
here ya go buddy..92-95 civics.
12 volts/white/ignition harness/+
Ignition/blk-yellow/ignition harness/+
accessory/yellow/ignition harness/+
starter/black-white/ignition harness/+
tach signal/blue/at coil on engine/AC voltage
Lock/ green-white/drivers kickpanel/ -
unlock/green-red/drivers kickpanel/-
doorpin/Lt.green-red/drivers kickpanel/-
trunkpin/green-blk/connector on fusebox/-
brakeswitch/green-white/switch above brake pedal/+
parklights/red-blk/at fusepanel/+
hand brake/green-red/connector above drivers kickpanel/-
horn/blue-green/at steering column/-
drivers window up/red-blue/main window switch/reverse polarity.
drivers window down/red-yellow/main window switch/rev pol
pass. window up/blue-green/main window switch/rev pol
pass. window down/blue-yellow/main window switch/rev pol.
headlights/red-white/light switch harness/+
reverse lights/green-black/large harness in drivers kickpanel/+
VSS wire/ yellow-blue/grey plug above fusebox.
key sense/blue-white/ignition harness.
Enjoy Adam
#1054563 - 02/15/07 05:59 PM Re: audio & security wiring thread. [Re: 00CivicSI-R]
RVelasc0 Offline
Loc: 310 CA
is the wiring layout the same for the 96-98 civics as the 99-00 civics? if not can you post it please!
#1106421 - 03/01/07 10:20 AM Re: audio & security wiring thread. [Re: RVelasc0]
todzilla Offline
Loc: Cambridge, OH
How ironic. I had a friend with a 2000 civic thats installing a radio and needed some help. I was like, uhhhhh...."Its been so long ago" Glad this little post was here. I was afraid I would be going through pages of CSI archives....lol
'07 GMC Canyonero
"I'm not sure why they call hunting a 'sport', when the hometeam always loses"
#1597697 - 07/01/07 01:40 AM Re: audio & security wiring thread. [Re: todzilla]
Easy Offline
my radio in my 00 si resets everytime i turn off the car..losin all presets so i find this thread n i see the two fuses i need.
i notice i didnt have the #47 fuse so i put one in thinkin it would fix everything. Except now the radio and speakers just stays on even after i turn the car off. Wat could be wrong? could it be the wiring itself and not have anything to do with the fuses or do i actually need both fuses?
Moderator:  rcurley55, The Mad Paki
