#6591298 - 09/17/12 09:36 AM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
OH DB press 70x9,8,7 Tbar rows 190x11,11,10,8 then dropped to 135x12 DB flat press (where I started to struggle) 95x9,8,7,6 dropped to 80x9 Close grip bench was fail 175x9,7,6 was shooting for 3 sets of 10 Killed my lateral and bent over lateral raises though 35x12x3
#6591314 - 09/17/12 09:45 AM
Re: My 5/3/1 log...
[Re: Impulsive ]
OdBag1
42-19 doesn't = 0. Math 101
Loc: I have no home
I still don't understand this routine.
#6591547 - 09/17/12 11:06 AM
Re: My 5/3/1 log...
[Re: OdBag1]
DieZel
Loc: 18th green
Week 1
Day 1 OHP 3 sets of 5, last set is 5+ (do at least 5 but continue until failure or just prior to failure) Then you can choose to do 5 sets x 10 at 55% of your training max... What's your training max...?
Got that...?
Move to week 2 you do a set of 3 with 70% TM, 3 with 80% TM, set of 3+ with 90% TM Move to week 3 you do a set of 5 with 75% TM, 3 with 85% TM, set of 1+ with 95% TM ( hence the name 5/3/1) Move to week 4 (deload week) you do 3 sets of 5 with 40,50,60% TM
EASY SCHMEEZEY...
#6601858 - 09/21/12 09:42 AM
Re: My 5/3/1 log...
[Re: DieZel]
Impulsive
Exactly. My gains seems pretty minor right now, but I think the whole point of the 5-3-1 is that even small gains are gains, so any progression matters.
#6616787 - 09/28/12 01:32 PM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
last week on incline db press @ 90 i did 9,8,7 dropped to 80 for 8,7 this week on incline db press @ 90 i did 9,9,8,7 dropped to 80 for 9
#6620500 - 10/01/12 09:47 AM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
http://youtu.be/m0x8peqX0t8
#6676133 - 10/28/12 03:28 PM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
#6704104 - 11/09/12 08:55 PM
Re: My 5/3/1 log...
[Re: DieZel]
65_289
current macros
training days 500c/75f/210p = 3515cals
off days 360c/80f/220p = 3040cals
Saturday refeed 680c/55f/175p = 3915cals
#6704464 - 11/10/12 07:14 AM
Re: My 5/3/1 log...
[Re: DieZel]
65_289
#6704841 - 11/10/12 01:26 PM
Re: My 5/3/1 log...
[Re: DieZel]
65_289
#6704858 - 11/10/12 01:42 PM
Re: My 5/3/1 log...
[Re: 65_289]
65_289
I'll stop hijacking your thread now.
#6723449 - 11/19/12 12:58 PM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
#6725002 - 11/20/12 05:34 AM
Re: My 5/3/1 log...
[Re: DieZel]
Fastfedlock
Loc: Jayhawk Country
Just started week 3 of my new training, and it's going pretty well... Squat today was 3 sets of 3-5... I hadn't done squats for a few months do to jacking up my back a few months earlier, but decided it was time to give it a go again... I never was a good deep squatter... i always felt if I got close to parallel that was good enough to get the job done... I'd like to get lower, but either I'm a pussy and afraid to get lower, or my body simply doesn't want to get down there... I'm sure there are 6+ footers that can go ATG but for me, i just don't see that happening... Here's a depth check vid I took today at 275... the last set was @ 285 and was nearly touching the spotter bars so I'm happy with that... Looks like i'll be able to get up beyond 300+ pounds again here soon... taking baby steps, but want these legs to grow, so gotta push it too... http://www.youtube.com/watch?v=cQHd_eKddeo&feature=share&list=UUqmuxgc4ruXcmwFUaO7fpUw
Moderator: Bumjubeo
