#6591547 - 09/17/12 11:06 AM
Re: My 5/3/1 log...
DieZel
Loc: 18th green
Week 1
Day 1 OHP 3 sets of 5, last set is 5+ (do at least 5 but continue until failure or just prior to failure) Then you can choose to do 5 sets x 10 at 55% of your training max... What's your training max...?
Got that...?
Move to week 2 you do a set of 3 with 70% TM, 3 with 80% TM, set of 3+ with 90% TM Move to week 3 you do a set of 5 with 75% TM, 3 with 85% TM, set of 1+ with 95% TM ( hence the name 5/3/1) Move to week 4 (deload week) you do 3 sets of 5 with 40,50,60% TM
EASY SCHMEEZEY...
#6603514 - 09/21/12 11:56 PM
Re: My 5/3/1 log...
[Re: DieZel]
137
Loc: Newsomville, CA
Deadlifts yesterday for 5+ @ 290 did 12 and stopped... could have done a few more, but i told myself if i hit 12 i'm done... if i keep hitting these high ass rep numbers i will continue to bump my training maxes by 15 vs 10 pounds fromn month to month...
tomorrow my 5+ bench is 215... really hoping to get 10... may not seem like alot to you big benchers, but my bench has always been shittay...
I'd love to hit anything over my body weight for reps. Slowly getting there! Chest is going to look awesome one that bottom tit fat melts away!
Wayne
#6616787 - 09/28/12 01:32 PM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
last week on incline db press @ 90 i did 9,8,7 dropped to 80 for 8,7 this week on incline db press @ 90 i did 9,9,8,7 dropped to 80 for 9
#6620500 - 10/01/12 09:47 AM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
http://youtu.be/m0x8peqX0t8
#6676133 - 10/28/12 03:28 PM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
#6704104 - 11/09/12 08:55 PM
Re: My 5/3/1 log...
[Re: DieZel]
65_289
current macros
training days 500c/75f/210p = 3515cals
off days 360c/80f/220p = 3040cals
Saturday refeed 680c/55f/175p = 3915cals
#6704464 - 11/10/12 07:14 AM
Re: My 5/3/1 log...
[Re: DieZel]
65_289
#6704841 - 11/10/12 01:26 PM
Re: My 5/3/1 log...
[Re: DieZel]
65_289
#6704858 - 11/10/12 01:42 PM
Re: My 5/3/1 log...
[Re: 65_289]
65_289
I'll stop hijacking your thread now.
#6723449 - 11/19/12 12:58 PM
Re: My 5/3/1 log...
[Re: DieZel]
DieZel
Loc: 18th green
#6725002 - 11/20/12 05:34 AM
Re: My 5/3/1 log...
[Re: DieZel]
Silock
Loc: Jayhawk Country
Just started week 3 of my new training, and it's going pretty well... Squat today was 3 sets of 3-5... I hadn't done squats for a few months do to jacking up my back a few months earlier, but decided it was time to give it a go again... I never was a good deep squatter... i always felt if I got close to parallel that was good enough to get the job done... I'd like to get lower, but either I'm a pussy and afraid to get lower, or my body simply doesn't want to get down there... I'm sure there are 6+ footers that can go ATG but for me, i just don't see that happening... Here's a depth check vid I took today at 275... the last set was @ 285 and was nearly touching the spotter bars so I'm happy with that... Looks like i'll be able to get up beyond 300+ pounds again here soon... taking baby steps, but want these legs to grow, so gotta push it too... http://www.youtube.com/watch?v=cQHd_eKddeo&feature=share&list=UUqmuxgc4ruXcmwFUaO7fpUw
Moderator: Silock, Professor Paki
