#2848446 - 07/23/08 07:32 PM motor mounts
B00stedsi Offline
Loc: SRQ
I need some help.
My mounts are shot. Should I get the stock units. Inserts or a full urathane mount.Thanks
wisco pistons9:1/eagle I rods/stock crank/.57 trim/skunk 2 cams
springs and retainers/ferraa valves/exedy clutch/750cc/hondata s300
#2848481 - 07/23/08 07:45 PM Re: motor mounts [Re: B00stedsi]
SamuraiSam Offline
Loc: Bellingham, WA
It doesn't really matter what anyone on this forum recommends for you to do, because when everyone tells you to buy new motor mounts (standalone and 1000cc injectors) you'll do something completely asinine like take your stock mounts, put urethane inserts in them and fill with 3m window weld (go out and use a rising rate fuel pressure regulator and stock injectors.) The end result will be disastrous- your motor bouncing all over the engine bay (blowing up your expensive "built" motor) and then you'll be back to inquire about engine torque braces (asking questions about block guards or how much timing 'everyone' is running)
You are not welcome in this forum. Leave.
Edited by SamuraiSam (07/24/08 09:44 PM)
#2848589 - 07/23/08 08:28 PM Re: motor mounts [Re: SamuraiSam]
kyden Offline
Loc: Providence, RI
wow.
#2848660 - 07/23/08 08:56 PM Re: motor mounts [Re: kyden]
SamuraiSam Offline
Loc: Bellingham, WA
Pay attention to the dates, questions asked, and answers given. This guy's either a troll or the world's biggest moron.
http://forums.clubsi.com/ubbthreads.php/ubb/showflat/Main/105589/Number/1979450
10/24/07 08:09 PM
 Originally Posted By: B00stedsi
i have a 2000 si with built internals. Questions. what boost controller should i use,a forge manual, or a greddy 2? boost spikes? and Should i use a Apexi AFC Neo controller or use the hondata200. both cost the same. I need answers. im ordering it like tomarrow.
Wapshhhh
10/24/07 09:05 PM
 Originally Posted By: SamuraiSam
Boost controller if you have to pick from those two, get the Greddy.
I don't know where you got the idea that you can use an Apexi AFC Neo, but it wont work at all for you.
The Hondata s200 is discontinued for a reason. Don't even consider it.
Find the best tuner in your area and buy whatever EMS he recommends.
http://forums.clubsi.com/ubbthreads.php/ubb/showflat/Main/112353/Number/2127912
12/22/07 04:20 PM
thats a garrett? Do i have to change out my stock injectors, is 550cc enough.and I have a tial 38mm (7psi)spring. do i have to swap it out to make 22 pounds. i cant get past 14 pounds. Im lookn for 450 whp. thanks
12/22/07 05:00 PM
Wait, have you been driving on this setup with stock injectors???? I'm a bit confused.
Get 1000cc injectors and an FJO Injector Driver. What kind of EMS are you using?
Use and tune with the .5 bar spring that you have, and then step it up to a 1 bar spring.
http://forums.clubsi.com/ubbthreads.php/ubb/showflat/Main/125212/Number/2425587
03/11/08 02:02 PM
what timing are you guys using. I was 2 degrees retarded, and my 2 and 3 pistons
cracked the 1st ringlands.Not from detonation.A/F was 11.2.Im running wisecos.thanks
03/11/08 09:07 PM
It was firing on 3 cylinders.When I pulled the plugs to check it was closed not damaged.I dont no the duty cycles.I didnt hook it up to a computer.There stock injectors.I have an inline 255 and a regulator.the psi set from drag.I believe 50 psi.
03/11/08 09:21 PM
i wont have the map till tomarrow.I use the apexi neo.Im starting to think its garbage.
FAIL.
Edited by SamuraiSam (07/24/08 11:15 PM)
#2852536 - 07/24/08 09:36 PM Re: motor mounts [Re: SamuraiSam]
B00stedsi Offline
Loc: SRQ
You guys are funny. I try coming for advice so i can fix what i screwed up on my car. I understand I really didnt know what im was doing but im trying to understand more and become more educated but all you guys want to do is talk shit and you would rather bring up old shit and waste your time then just anwser a simple question. Im sorry im invading your little utopia. Im not a troll(what ever made up word that is). Im just a guy that loves his civic.
#2852560 - 07/24/08 09:45 PM Re: motor mounts [Re: B00stedsi]
SamuraiSam Offline
Loc: Bellingham, WA
If you were actually coming to us asking help and advice, you would have taken it. If you read my previous post I actually answered your question while in asshole-rant mode:
What I meant by that is, you SHOULD do things the right way and buy new motor mounts, just like you SHOULD have taken our advice a year ago and bought the correct fuel system components and a standalone ECU, but you didn't then, and you probably won't now. My advice back then was just as good as my advice now.
Edited by SamuraiSam (07/24/08 09:46 PM)
#2852735 - 07/24/08 10:58 PM Re: motor mounts [Re: SamuraiSam]
Happy Birthday cua0 Offline
Loc: Red Deer, Alberta, Canada
it's true, and yet somehow you're more of an asshole today than you were then.
not that i'm complaining, i think he more than deserves it. heh
#2852759 - 07/24/08 11:09 PM Re: motor mounts [Re: cua0]
SamuraiSam Offline
Loc: Bellingham, WA
I've just let all of my honesty out into the open. There are people who are general dicks and are abrasive about anything. I'm more along the lines of an unbridled brutally honest-hole, I think. It's been building up for awhile but I've let it out into the open over the last few months. I've been spending a lot of time on the gtr.co.uk Technical forums lately, which are filled with owners who have picked up GT-R's on the cheap and have no idea how to maintain or modify them, but go around preaching to other people that you can do x y and z. I have a lot of fun, and really unleash my full asshole qualities over there on at least a weekly basis.
Assholes have more fun, anyways.
*edit: I went back and highlighted/made the really funny points of the history of b00stedsi's turbo saga really apparent. I needed a laugh.
Edited by SamuraiSam (07/24/08 11:16 PM)
#2854075 - 07/25/08 11:51 AM Re: motor mounts [Re: SamuraiSam]
00OldSi Offline
Loc: DC
Man you been around as long as me Sam...LOL! I still remember some of dumbest questions asked back when this forumn was ran by Jason. But you know..its all good man. Most just too lazy to search or learn.
#2854232 - 07/25/08 12:37 PM Re: motor mounts [Re: 00OldSi]
jcoosi Offline
Loc: TN
Quoted for the m-fin truth
#2854270 - 07/25/08 12:50 PM Re: motor mounts [Re: jcoosi]
00OldSi Offline
Loc: DC
Sometimes its just easier for them to ask peeps like yall who have ALOT of hands on experience. its all good though!
#2854305 - 07/25/08 01:00 PM Re: motor mounts [Re: 00OldSi]
SamuraiSam Offline
Loc: Bellingham, WA
I've been on forums long enough now that I don't really get mad when people don't search - anything thats not covered in the FAQ's are fair game and I"ll answer it... I just get pissed when I've already given an answer and it's ignored
#2854901 - 07/25/08 03:49 PM Re: motor mounts [Re: SamuraiSam]
SiAdam Moderator Offline
Same here. I have people local to me ask for my advice..I tell them and then they do whatever the heck they were going to do in the first place. Their motor blows, or they have issue after issue. They come back and guess what, ask for more advice...
Guess what..tough luck..should have listened the firs time..we don't type/speak for our health or to look cool..
We can't help people who don't want to first help themselves.
