Just put it on yesterday and did the TB Coolant bypass since I had it off supposed to have a dyno day for Saturday but not sure if it'll still be happening
Loc: the OC in CA right next to LA
notice anything?
looks like you had to getto rig something for the coolant hose too?
notice anything?
Not really. I do notice a touch better response. I'll be on the dyno this afternoon. I started off at 188 with a CAI. I added the exhaust, TBS and bypass
With having the CAI, it pushes it out further into my rad hose. I added another pc. of hose to keep the heat off my intake elbow. I'm thinking of trimming my elbow about 1/4" so everything fits perfect
one thing though, was it on the same dyno set to sae corrected?? if not then this means nothing, just wondering
I was there for dyno day for 8thcivic. They let me change it while the car was still strapped...had 3 members helping. Did both a 3rd gear and 4th gear pull
This is the only sheet I have right now...waiting for him to e-mail me the rest...all in all I had about 8 pulls.
There was a loss of the signal on the second run so disregard that torque reading.
thats impressive man!! i wonder how that mod even makes hp?? is it because it increases the airspace on the inside of the intake manifold or something?? please explain if you can. thanks
06 SI
- Hondata ECU reflash
- ITR Cams
- Custom 3'' catless exhaust
- Injen CAI
- Hondata IMG
- throttlebody coolant bypass
- Comptech short shifter
- DC race header
Was the TB bypass done on both passes or is that swinging the numbers?
WTH is a throttle body bypass???? and does anyone else have any dynos of the before and after of the TB spacer?? i think im gonna order mine today, thats great HP for somthing that cost $80!!!
06 SI
- ITR Cams
- Injen CAI
- Hondata IMG
- DC race header
Loc: Orange County, NY
i DID A DYNO IN SCHOOL ON A MUSTANG DYNO AND IT SHOWED ME 206 TO THE WHEEL AND THE ONLY THINK I HAVE IS A K&N DROP IN FILTER. I THINK THE DYNO IS OFF OR SOMETHING
uhh yeah your dyno must really be off cause mustang dynos usually read lower numbers compared to other dynos. Are you sure you wernt on a hub dyno or dyno dynamics dyno????
06 SI
- ITR Cams
- Injen CAI
- Hondata IMG
- DC race header
its not a hub dyno. here is a link. its not my car but this is the dyno at my school http://www.youtube.com/watch?v=hkTOxA7xHRg. im gonna try to get the video of my car on that dyno.
It's when you bypass the coolant from the TB. There is a coolant line running from the engine to the TB and back out to a tube. I just re-routed it from the block to the tube. The DIY states to buy a hose. You don't need to, just use one of the ones you disconnect. By the end of the month, I'll be putting it back due to living in the NE and I'll need the coolant in the cold weather more than 1 hp
hahaha i did the original write up on this mod back in early 06, its not called a TB bypass its called a coolant bypass. i was thinking damn if you actually bypassed the TB how the hell would your car run hahahaha,, i was confused because of the way it was worded, sorry.
06 SI
- ITR Cams
- Injen CAI
- Hondata IMG
- DC race header
