#1852156 - 09/13/07 08:23 AM TB spacer
smittttty Offline
Loc: cincy oh
just wondering if anyone has this installed.. http://www.corsportusa.com/store/catalog/product_info.php?cPath=1_47&products_id=1685
RR sedan
#1853778 - 09/13/07 03:38 PM Re: TB spacer [Re: smittttty]
AX-NY'06Si Offline
Loc: Southern NY State
Had one on my 83 Rabbit GTi and did absolutely nothing according to the butt-o-meter.
'06 NBP Si w/ OEM fogs
'06 Mazda 3S GT
#1853885 - 09/13/07 04:06 PM Re: TB spacer [Re: AX-NY'06Si]
TJ213 Offline
Loc: Pennsylvania
http://8thcivic.com/forums/showthread.php?t=45585
#1854000 - 09/13/07 04:32 PM Re: TB spacer [Re: TJ213]
zachys Offline
Loc: 191whp 139wtq
Just put it on yesterday and did the TB Coolant bypass since I had it off
supposed to have a dyno day for Saturday but not sure if it'll still be happening
Mods I have = 209whp
#1855659 - 09/14/07 09:23 AM Re: TB spacer [Re: zachys]
smittttty Offline
Loc: cincy oh
thanks for the link. made up my mind.
RR sedan
#1856823 - 09/14/07 03:40 PM Re: TB spacer [Re: zachys]
AppleSauseSi Offline
Loc: the OC in CA right next to LA
notice anything?
looks like you had to getto rig something for the coolant hose too?
-06 Civic Si TW Navi
#1857140 - 09/14/07 05:11 PM Re: TB spacer [Re: AppleSauseSi]
DickChan Offline
Loc: Nor Cal
at least the zip ties match your decals
2007 FA5 HFP 18" Nav
#1858080 - 09/15/07 08:02 AM Re: TB spacer [Re: AppleSauseSi]
zachys Offline
Loc: 191whp 139wtq
notice anything?
Not really. I do notice a touch better response. I'll be on the dyno this afternoon. I started off at 188 with a CAI. I added the exhaust, TBS and bypass
With having the CAI, it pushes it out further into my rad hose. I added another pc. of hose to keep the heat off my intake elbow. I'm thinking of trimming my elbow about 1/4" so everything fits perfect
Edited by zachys (09/15/07 08:04 AM)
#1859429 - 09/15/07 09:17 PM Re: TB spacer [Re: zachys]
zachys Offline
Loc: 191whp 139wtq
Just got back from the dyno. The spacer gave me 3 whp and 2 wtq....nice investment!
#1860807 - 09/16/07 02:54 PM Re: TB spacer [Re: zachys]
06redsi Offline
Loc: Houston TX
wow that made more than my cams!!
06 SI - Hondata ECU reflash - ITR Cams - Custom 3'' catless exhaust - Injen CAI - Hondata IMG - throttlebody coolant bypass - Comptech short shifter - DC race header
#1860816 - 09/16/07 02:55 PM Re: TB spacer [Re: 06redsi]
06redsi Offline
Loc: Houston TX
one thing though, was it on the same dyno set to sae corrected?? if not then this means nothing, just wondering
#1860878 - 09/16/07 03:15 PM Re: TB spacer [Re: 06redsi]
zachys Offline
Loc: 191whp 139wtq
I was there for dyno day for 8thcivic. They let me change it while the car was still strapped...had 3 members helping. Did both a 3rd gear and 4th gear pull
This is the only sheet I have right now...waiting for him to e-mail me the rest...all in all I had about 8 pulls.
There was a loss of the signal on the second run so disregard that torque reading.
#1863439 - 09/17/07 11:10 AM Re: TB spacer [Re: zachys]
06redsi Offline
Loc: Houston TX
thats impressive man!! i wonder how that mod even makes hp?? is it because it increases the airspace on the inside of the intake manifold or something?? please explain if you can. thanks
#1867343 - 09/18/07 08:56 AM Re: TB spacer [Re: 06redsi]
Cicada Offline
Loc: Canuckistan
Was the TB bypass done on both passes or is that swinging the numbers?
Less talk more butt sex
#1867418 - 09/18/07 09:28 AM Re: TB spacer [Re: Cicada]
zachys Offline
Loc: 191whp 139wtq
That was on both numbers.....it doesn't look like it added anything. I had the same numbers as the last time I dynoed without the bypasss
#1867542 - 09/18/07 10:21 AM Re: TB spacer [Re: zachys]
HabaneroSedan Offline
Loc: Phoenix, AZ
Bristol Dyno is like 10 minutes from my old house
2007 Civic Si Sedan: 10psi Supercharged
#1867750 - 09/18/07 11:31 AM Re: TB spacer [Re: Cicada]
06redsi Offline
Loc: Houston TX
WTH is a throttle body bypass????
and does anyone else have any dynos of the before and after of the TB spacer?? i think im gonna order mine today, thats great HP for somthing that cost $80!!!
#1868133 - 09/18/07 01:15 PM Re: TB spacer [Re: 06redsi]
Alien21 Offline
Loc: Orange County, NY
i DID A DYNO IN SCHOOL ON A MUSTANG DYNO AND IT SHOWED ME 206 TO THE WHEEL AND THE ONLY THINK I HAVE IS A K&N DROP IN FILTER. I THINK THE DYNO IS OFF OR SOMETHING
#1868233 - 09/18/07 01:51 PM Re: TB spacer [Re: Alien21]
06redsi Offline
Loc: Houston TX
uhh yeah your dyno must really be off cause mustang dynos usually read lower numbers compared to other dynos. Are you sure you wernt on a hub dyno or dyno dynamics dyno????
#1868311 - 09/18/07 02:09 PM Re: TB spacer [Re: 06redsi]
Alien21 Offline
its not a hub dyno. here is a link. its not my car but this is the dyno at my school http://www.youtube.com/watch?v=hkTOxA7xHRg. im gonna try to get the video of my car on that dyno.
#1870930 - 09/19/07 06:58 AM Re: TB spacer [Re: 06redsi]
zachys Offline
Loc: 191whp 139wtq
http://www.8thcivic.com/forums/showthread.php?t=25348
It's when you bypass the coolant from the TB. There is a coolant line running from the engine to the TB and back out to a tube. I just re-routed it from the block to the tube. The DIY states to buy a hose. You don't need to, just use one of the ones you disconnect. By the end of the month, I'll be putting it back due to living in the NE and I'll need the coolant in the cold weather more than 1 hp
#1878336 - 09/21/07 09:21 AM Re: TB spacer [Re: zachys]
06redsi Offline
Loc: Houston TX
hahaha i did the original write up on this mod back in early 06, its not called a TB bypass its called a coolant bypass. i was thinking damn if you actually bypassed the TB how the hell would your car run hahahaha,, i was confused because of the way it was worded, sorry.
Moderator:  Design, The Mad Paki
