Page 1 of 2 12>
#67723 - 12/21/04 09:00 PM Best way to run wires into the doors?
RizzySI Offline
Loc: Orlando, FL
Hey guys, just wondering what would be the best and easiest way to run wires into the doors of a '00 SI. I did it once before and it was a bitch to say the least. There aren't any actual wires that go from the car into the door, just a plug thing. I need to run some wires from inside the car for my remote window modules for my Viper alarm. Any help would be great!
Thanks
#67724 - 12/21/04 09:50 PM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
You can get whats called a "claw" from sears its about 5-10$ and you pull the gromets out and you can stick the claw in one side and since the gromets are rubber you can guide the claw through and when it gets to the other side open the claw and put the wires in close it push the tabs away from each other to get a good grip and just pull through i tried feeding just wires through one time wasn't happening. With the claw took me about 3 minutes. Good luck.
"I'm double the worst trouble you will ever have!" Robert Dinero - Heat
#67725 - 12/21/04 10:16 PM Re: Best way to run wires into the doors?
RizzySI Offline
Loc: Orlando, FL
Hmmm...what gromets? Not understanding exactly...You did this on a '00?
#67726 - 12/22/04 02:12 AM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
Yeh my bad i just went downstairs and looked at my car. Remember what i told you earlier and keep that in mind. If your looking for a professional install which you probably are then your going to have to take the fenders off which shouldnt be that hard. After you take the fenders off you will see the rubber boots/gromets going from the door to the car. Right now if you feel back in your door jamb you can feel the boots. Once you pull the gromets away from the car its going to be easy from there just do what i told you to do earlier and its actually easier to get to the gromets and run the wires then it is on most cars where you have to actually work in the door jambs
#67727 - 12/22/04 05:35 AM Re: Best way to run wires into the doors?
DCSportsSI Offline
Loc: Jacksonville, FL
Man i had a hell of hard time getting wires to the door. I couldnt do it. So.. i had to run it in the door jam. Aint that bitch? yeah, im pissed. There's still hope, so im gonna re-run it when i have the time. I used some wire loom.. it KINDA looks stock. Hey it works for me for now. It kinda pisses me off though.
So, please explain WHERE to run the wires. From under the glove compartment i found a side hole, was a bitch to get a wire through but did. The rubber covering for all the wires going into door is a no go. There is NO SPACE in that hole to add wires. Damn i really want to use factory wiring. Check out my other post "My wiring a waste of time"
Ricky @ Wiredspeed FlamencoT KTeller Camp1320 Earl
#67728 - 12/22/04 12:17 PM Re: Best way to run wires into the doors?
vtec_yosh Offline
When I attempted to run wires through the door of my 00 Si for window control, I found the easiest way to do it was take take the door off completely. Its been awhile, I cant remember, but I think the wires are connected to the doors with a plug and I ran the wires through the grommet and behind the plug and you could never tell it was there.
the only problem was that I could never get the door back on straight. It always kinda saggeed when you opened and close it. Good luck though.
http://www.memphisracingscene.com
#67729 - 12/22/04 01:16 PM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
once you take the fender off and pull the gromet out and the panels under the glove box are off here is where the claw and a light is your best friend. You lay a light in the floor board facing where your working then you go outside the car look thorugh the gromet hole for the light when you see the light you can just stick the claw in that direction and go inside the car and look and im sure you will be able to find the claw if you can see light from outside the car. Sometimes you may need 2 people for the claw though.
#67730 - 12/22/04 07:40 PM Re: Best way to run wires into the doors?
georgelb Offline
Loc: Arlington, TX
You cannot use a claw or any other device like that on an '00 because there is a molex plug in the door. You will need to carefully drill a hole in each side of the molex plug to get your wires into the door through the stock loom.
Molex Plug
#67731 - 12/22/04 10:45 PM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
I wasnt talking about using a claw for the doors... Read the post carefully!
#67732 - 12/22/04 10:52 PM Re: Best way to run wires into the doors?
DCSportsSI Offline
is there a Molex Plug on a 99 Si as well? "THE CLAW!!!" haha just sounds funny. So what can this CLAW be used for? just removing grommets? man ohh man. IM definatly gonna take the time to rewire my shit. I fuckin HATE seeing that loom in my door jam. Thats like..... "RICE". lol
#67733 - 12/22/04 11:24 PM Re: Best way to run wires into the doors?
RizzySI Offline
Loc: Orlando, FL
So, what you're tellin' me, it's gonna be a nother bitch to do this again...haha
#67734 - 12/23/04 11:27 PM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
The claw is about 2 1/2 feet long and can bend in any direction and has two tabs on one end push them towards each other the claw at the opposite end will open push them away from each other and the claw with close tightly on the wires your trying to pull through a hole such as a gromet hole or through a dash. Here I will tell you how to get wires into the door without having to run it in wire loom. First disassemble the work area: take the glove box off take the passenger kick panel out and take the door panel and the fenders off. Unplug the Molex Plug and pull the gromet out that is going into the car. Once you have all this done you can lay a light on the floor of the car facing in the direction of the gromet hole go to the outside the car and look through the hole to see the light and when you see the light you can put the claw in towards the lighted area. Open the claw and insert the wires that you need to run outside the car and then close the claw and pull the wires through. Since it goes into a plug you can either run the wires in the rubber boot and then have them come out in the end or you can tape them with electrical tape to the actual rubber boot. Then like georgelb stated CAREFULLY drill a hole by the Molex Plug but look inside the door or feel just to make sure where the wires are because if you drill through wires then dont expect the windows or door locks to work. Once the hole are drilled feed them through and then you can reassemble the car and finish what you need to do in the door area.........Any questions??
#67735 - 12/24/04 12:30 AM Re: Best way to run wires into the doors?
DCSportsSI Offline
Dude thats bad ass! thanks bro, im looking forward to cleaning up this installation
#67736 - 12/24/04 01:20 AM Re: Best way to run wires into the doors?
BrandonCLaps Offline
Loc: Syracuse, NY
Molex Plug
finally someone that knows what they are talking about
how did you disconnect the wires that are connected to the door/car (the link)
#67737 - 12/24/04 06:17 AM Re: Best way to run wires into the doors?
DCSportsSI Offline
is this the same for my 99 si?
#67738 - 12/24/04 07:39 AM Re: Best way to run wires into the doors?
georgelb Offline
Loc: Arlington, TX
I didn't completely disconnect the wires from the car. Just unplugged the Molex plug and then popped the plug out of the door and pulled it down through the speaker cutout so I could get to it good, then very very slowly used a dremel, a drill, and various other things to make a hole in each side of the plug. It was harder on the driver side because there are more wires going into the door, thus less room to make a hole without hitting a wire.
I posted these in another thread ages ago, but I will post them again so you can get an idea how I did it.
#67739 - 12/24/04 01:12 PM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
Yeh I remember your post and tried searching for the pictures and post but couldnt find anything.
#67740 - 12/25/04 01:26 AM Re: Best way to run wires into the doors?
DCSportsSI Offline
DUDE! You are the man!!!!!!!!! this helped me out so much. Now when I get home... im re running my stuff. thanks! Thats a good enough christmas present for me!
#67741 - 12/25/04 02:03 AM Re: Best way to run wires into the doors?
Ricer4life15 Offline
Loc: Michigan
yeah this definately helps out a bunch..........
#67742 - 12/25/04 05:18 PM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
No problem..
#67743 - 12/26/04 10:19 PM Re: Best way to run wires into the doors?
Loc: Syracuse, NY
wow looks easy without any interior. nice pics man. looks like you got your crossovers inside the car right?
#67744 - 12/27/04 03:13 AM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
I dont think thats the crossover. I believe its actually something from Honda put there. Look at the harness going into the side of it.
#67745 - 12/27/04 02:46 PM Re: Best way to run wires into the doors?
georgelb Offline
Loc: Arlington, TX
no problem man, and yeah, the crossovers are in the trunk by the amp.
#67746 - 12/28/04 03:57 PM Re: Best way to run wires into the doors?
Design Offline
Great install details. Perhaps a sticky or post in "tips and tricks?"
01 Echo 5MT
#67747 - 12/29/04 04:57 PM Re: Best way to run wires into the doors?
Loc: Michigan
got any picture of what this "claw" might look like? i went to sears today and couldnt find anything.........or possibly what it is really called?
#67748 - 12/29/04 08:57 PM Re: Best way to run wires into the doors?
Loc: Syracuse, NY
the reason i said he has crossovers in his car was because i see 2 sets of wires going into the door meaning crossover is inside. the part your reffering to is the keyless entry module
#67749 - 12/29/04 09:01 PM Re: Best way to run wires into the doors?
Loc: Syracuse, NY
i got mine at a dollar store, it basically looks like this
this is a pickle grabber, its the same concept, except the i use is made out of metal and is flexible
#67750 - 12/29/04 09:53 PM Re: Best way to run wires into the doors?
civicdude04 Offline
Loc: IL
i just drilled a small hole (just big enough to run the wire through) right next to the plug in the door, put a rubber gromet in the hole (so the metal doesnt cut the wires) then i ran the wire right through the stock rubber tubing all the way up to the hole, then cut a hole in the rubber tubing and ran it into the hole i drilled. i didnt have to take the fender off, the door off, or nothing. it was easy, and you cant even tell that i did it. thats just another option.
-ryan
i-VTEC, do you?
#67751 - 12/29/04 10:47 PM Re: Best way to run wires into the doors?
DCSportsSI Offline
got pics of the way you did it?
#67752 - 12/29/04 11:10 PM Re: Best way to run wires into the doors?
Loc: Michigan
dude, i freaking love ebay, they have everything, i looked up the "claw" on there and they definately had them.......i ordered one that is 36" for $4 shipped!
#67753 - 12/30/04 12:35 AM Re: Best way to run wires into the doors?
Imprt2nr Offline
Loc: Va, NoVa
http://buy1.snapon.com/catalog/item.asp?...amp;dir=catalog Well incase people are still wondering what they look like and where to get them click here to get a Snap-On 24" claw with 4 claws for 8.50$
#67754 - 12/31/04 11:41 AM Re: Best way to run wires into the doors?
civicdude04 Offline
Loc: IL
i dont have my camera right now, but when i get it back, i can post some pics of it. you cant even tell i ran a wire through there.
-ryan
i-VTEC, do you?
#67755 - 03/23/05 09:35 AM Re: Best way to run wires into the doors?
EmptyWallet Offline
What size wire is that up there in those pics?
"I don't think I've ever seen you get angry?"
[laughs] "Oh, I used to get angry. All the time. Frustrated too."
"You don't get...frustrated anymore?'
[smiles]"...I'm not lost anymore.."
"How..how did you do that?"
"Same way that anything lost,...gets found.....I stopped looking."
#67756 - 03/23/05 12:55 PM Re: Best way to run wires into the doors?
Loc: Syracuse, NY
looks like 12 gauge
#67757 - 03/23/05 03:20 PM Re: Best way to run wires into the doors?
EmptyWallet Offline
looks like 12 gauge
I think I'd much rather do 14.
Page 1 of 2 12>
Moderator:  rcurley55, The Mad Paki
