ClubSi
#38945 - 01/04/04 07:20 PM Spoon Ventuli plate
breakneckvtec Offline
Loc: NJ
Would this best be run with:
Stock cams
CTR cams
Skunk stage 1 cams
Rev limit would be set higher for the CTR or skunk cams, so factor that. And of course, what setup would offer greatest gains overall, ie, just running skunks with no plate VS CTR or stock cams with the plate. Just need some opinions on this, I already have the I/H/E. Also, since I came across a setup cheap, this will be tuned with a hondata.
06 Nissan Pathfinder SE
06 MS6
04 Seadoo GTX wake edition - GPS top speed 62.3 mph w/ no mods
#38946 - 01/04/04 09:07 PM Re: Spoon Ventuli plate
Sleeper_EM1 Offline
Dont go for it.
Its like breathing through a straw.
Ive seen with my own eyes the Hondata intake manifold gasket beat spoon's ona dyno test.
I donno, just my input.
(it's not like it lost horsepower, but Hondata is much cheaper and pulled out more on the dyno sheet)
#38947 - 01/04/04 09:14 PM Re: Spoon Ventuli plate
Stein Offline
Loc: Rip City
I think stock cams, I think the theory is that you have to give up top end power but you gain mid range, so why buy high rpm cams when you're going to choke them out?
2018 Ford Mustang GT
#38948 - 01/04/04 09:16 PM Re: Spoon Ventuli plate
Loc: NJ
I got it, so if I want a small midrange gain go with the plate, if I want to make some decent power go hondata gasket with skunk cams. Makes sense, thanks guys.
06 MS6
#38949 - 01/04/04 09:58 PM Re: Spoon Ventuli plate
MadtownSi Offline
Moderator
Loc: Madison,WI
I used my Ventuli plate with Toda Spec B cams. Midrange was very strong but topend did suffer. I like the setup, gave my B16 some punch!! Depending on were you want to make your power is the deciding factor for getting the Ventuli plate.
BTW, Hondata and Ventuli plate are two completely different designs and make power in to completely different ways. Hondata isolates heat to make power, Spoon changes air flow config to make power.
--------------------------------- F1 www.donandmikewebsite.com
#38950 - 01/04/04 10:04 PM Re: Spoon Ventuli plate
Loc: NJ
ITR cams with ventulli plate for a strong midrange and decent top end a good idea? I have a 4-2-1 header too. I would probably run this setup with a redline no higher than 8400, probably shift at about 8 - 8.2. I hear the ITR cams have a very nice midrange, more so than even the skunks. Thoughts on this setup, its a street car and might see some autoX this coming season, not really going to make this a drag queen. Thinking of also tossing a heatshield of some kind for the intake and an exedy clutch flywheel combo as well. Would cam gears be a good idea with ITR cams or a waste?
06 MS6
#38951 - 01/05/04 12:43 AM Re: Spoon Ventuli plate
Stein Offline
Loc: Rip City
If it's going to be an AutoX car and you do not mind losing power up top, maybe you should invest in Toda Spec A and a Spoon Ventuli plate... ?
#38952 - 01/05/04 07:40 AM Re: Spoon Ventuli plate
trans am killer Offline
Loc: Rosemount, MN
you will have something similar to this.
thin red line (bottom) is the 1st run torque #'s
mods are as follows.
98 ITR short block, 11:1 apprx.
B16 head CASTING
b16 valves
2001 ITR cams
ITR springs and retainers
Mugen headgasket
b16 intake manifold
b16 thorttle body
spoon ventuli plate
AEM CAI
exedy clutch
fidaza flywheel
98 ITR ECU
VAFC
Mugen Gyhmkhana header
ITR exahust
Mugen Muffler
Quaiffe
Gods speed test pipe
we ended up with vtec at 5100rpms. Air fuel was kinda wacky, all over the place, got it better but still very rich at the top end. Tried to lean it out but lost power so we left it in its stock setting.
Still have A/C, and PS. on 93 octane reformulated crap.
I built the car for midrange so i could better compete in Street Mod at autoX. It does very well and has great midrange power for daily driving. I know i need to get a ITR manifold/TB and lose the ventuli plate and then i might put down some better numbers. But for now this is all shes got. Its great I can bust the tires loose in 2nd gear but it just kinda feels slow at the top end. I shift at 8K cause it puts me in the best part of the power band for the next gear. 3rd and fourth gears are the strongest. It was fun before i tuned it where i jumped 20whp at vtec engagement, but now its less pronounced and cant feel it as much. around 6 grand though the car feels awesome.
but this is with the gymkhana and the b16 intake manifold, im sure the top end will improve greatly with a different IM. cause well after driving the car for a summer, i miss teh top end pull, cause it sucks. On the other hand it keeps me from redlining it all the time.....
AIM: LnDonSilver 1999 Impreza RS
#38953 - 01/05/04 07:41 AM Re: Spoon Ventuli plate
Loc: Rosemount, MN
well wait, I just realized you were using a b16 block.... well forget my post then
#38954 - 01/05/04 01:36 PM Re: Spoon Ventuli plate
MadtownSi Offline
Moderator
Loc: Madison,WI
This is a B16 with Toda Spec B cams and the Ventuli plate
160whp and 112.7 ft/lbs of torque. The setup made a nice flat torque curve.
#38955 - 01/05/04 03:32 PM Re: Spoon Ventuli plate
cruzersi99 Offline
You could give it a try. I would think that ITR cams or Stock cams would be suitable. Like everyone else mentioned your top end will suffer, but given the right combination of parts you can build a car with a little more midrange.
Given stock or mild cams, and I/H/E I think it's debatable whether total area under the curve is actually increased or reduced, instead your powerband may just shift down a few RPMs. Will this make you faster? Depends on the situation.
Let me know I have a friend with a Ventuli for sale. He's talking it off because he is going with bigger cams.
As noted, the Spoon Ventuli plate and Hondata piece serve different purposes. Hondata gains can be attributed to change in air temp, whereas Spoon gains are the result of a change in air flow volume, and velocity.
186 whp - Church Automotive (Dynapack)
189 whp - Zero Factory (Bosch)
#38956 - 01/09/04 05:50 PM Re: Spoon Ventuli plate
SiKO Offline
Loc: Seattle/Silicon Valley, USA
You could use Spoon cams with the ventuli plate. I have new set available if interested. I was going the same route until I sold my car, and have a lot of new or slightly used parts.
#9212726 - 12/18/17 08:45 PM Re: Spoon Ventuli plate [Re: SiKO]
20171219caihuali
toms sko
marc jacobs outlet
polo outlet
polo outlet
giuseppe zanotti outlet
huaraches shopping
longchamp bags
adidas wings
canada goose jackets
michael kors wallets
polo outlet
tory burch outlet
birkenstock outlet
kicks nice
swarovski crystal
coach factory outlet
tory burch outlet
nike roshe
canada goose parka
lebron james shoes
chrome hearts outlet
fitflops shoes
prada sunglasses
longchamp solde
nike air force 1
burberry outlet
ugg boots clearance
salomon sko
burberry outlet
soccer jerseys
links of london
burberry outlet
nike sko
adidas nmd
fred perry polo shirts
toms sko
air huarache
air max 1
hermes outlet
mulberry sale
adidas trainers
ugg boots
tory burch outlet
chrome hearts
canada goose black friday
montblanc pens
air jordan 4
ugg boots clearance
burberry outlet
rayban sunglasses
reebok outlet store
longchamp pas cher
nike sko
nike store uk
new balance shoes
tods outlet
adidas outlet store
birkenstock sandals
nike free 5
cartier outlet
mulberry outlet
ecco shoes
tory burch outlet
fitflops shoes
[url=http://www.canadagooseoutletgoose.us.com ]canada goose outlet[/url]
supreme clothing
vans shoes
cheap snapbacks
tory burch outlet
kobe shoes
true religion uk
ugg boots clearance
Girls shoes
ugg boots
basketball shoes
tory burch shoes
cheap nhl jerseys
lakers jerseys
herve leger outlet
football shirts
swarovski crystal
salomon shoes
swarovski outlet
adidas nmd
swarovski outlet
soccer jerseys
adidas uk
ysl outlet
supreme clothing
supreme clothing
futbol baratas
vans sko
dansko shoes
polo shirts
valentino outlet
canada goose cyber monday
moncler jackets
tory burch outlet
ralph lauren polo shirts
ralph lauren pas cher
air huarache
cleveland cavaliers jersey
timberland boots
nike roshe one
reebok trainers
ed hardy clothing
polo outlet
polo outlet
bottega veneta outlet
prada shoes
ugg black friday
ugg boots
michael kors bags
soccer shoes
nfl jerseys wholesale
ugg boots clearance
ecco sale
canada goose coats
adidas sko
cheap jerseys
mac cosmetics
chicago blackhawks jerseys
thomas sabo
vans greece
air max trainers
mulberry outlet
lacoste polo shirts
supra shoes
coach outlet canada
ugg boots
kobe 9
mcm outlet
true religion outlet
ugg boots
ugg outlets
puma outlet
ugg boots
ugg boots clearance
cheap snapbacks
longchamp pliage
coach canada
nike factory outlet
cheap jerseys
ugg cyber monday
hermes birkin
swarovski outlet
nike air max 2015
hermes belt
ugg boots
fitflops sale
kobe bryant shoes
polo outlet
converse shoes
polo outlet
cazal sunglasses
mulberry bags
rayban sunglasses
hermes outlet
longchamp solde
toms sko
nike sko
air max uk
kevin durant shoes
fitflops outlet
moncler jackets
polo outlet
christian louboutin online
nfl jersey wholesale
yeezy boost 350
lacoste soldes
ray bans
nike foamposite
uggs
coach handbags
timberland sko
swarovski outlet
coach handbags
supreme clothing
tory burch outlet
hogan scarpe
ray-ban sunglasses
mulberry bags
asics shoes
new balance shoes
ugg boots clearance
converse shoes
20171219caihuali
#9235958 - 01/21/18 09:14 PM Re: Spoon Ventuli plate [Re: ]
Andada
colts jerseys
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
michael kors handbags sale
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
cheap basketball shoes
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
discount oakley sunglasses
buffalo bills jerseys
fitflops sale
polo ralph lauren outlet
nike huarache
seattle seahawks jerseys
jaguars jersey
Moderator:  Runnin@Redline Jr, Dr. BrokenLimits, The Mad Paki
