#10218545 - 02/28/22 11:32 AM
Covid Oil Changes
A2B-Lexus
Loc: Raptors Land
Are you guys going to do your oil changes based on kms? I've driven my Q3 for 4000 kms for the last 2 years. Its a 2015 CPO so I haven't been back as I am not voiding any warranties. Feels like a waste of $$ changing the oil only after 4000 kms.
Before covid, I was really only driving about 6000 or so kms per car so I've always done it annually anyway but 2 years+ or so seems like a long time between changes.
For my Acura RDX, I just go with the car's computer as that seems to be kms based.
#10218558 - 02/28/22 11:57 AM
Re: Covid Oil Changes
[Re: furball]
DoWnGEAR
Loc: Toronto, Ontario
I was paranoid enough about this that I sent in a sample to black labs after 3 years from my rarely driven s2000. The test results were flawless and they included this in the write up:
You can safely jettison the idea of calendar based oil changes. Modern engines are sealed up tight and not susceptible to issues like corrosion or oil breaking down due to moisture and other outside contaminants getting in over time. Solids from heat/blow-by/use(insolubles) and wear metals are the things that must be removed during oil changes and those only build up while the engine is running. Here wear metals are low next to universal averages.
#10219412 - 03/01/22 02:15 PM
[Re: 87ZCSi]
titty sprinkles
I drove 330kms in my GT3 last year. One can only hope that was all accumulated in a few lapping days?
nah, runs to foody mart.
#10219767 - 03/01/22 11:18 PM
[Re: DoWnGEAR]
A2B-Lexus
Loc: Raptors Land
Nice. Good to know!
#10219769 - 03/01/22 11:19 PM
[Re: titty sprinkles]
A2B-Lexus
Loc: Raptors Land
I drove 330kms in my GT3 last year. One can only hope that was all accumulated in a few lapping days? nah, runs to foody mart. Probably just T&T. He lives closer to those.
#10220157 - 03/02/22 01:45 PM
[Re: DoWnGEAR]
Screamin Type ARGH!
For all cars today, pretty much this.
Did u use wearcheck in Burlington? We use them.
#10220298 - 03/02/22 05:34 PM
[Re: A2B-Lexus]
Hatorade
pheggit
LOL I’ve done this.
'07 997.1 GT3 '08 E90 M3 '11 E90 d '02 Rota Grid - 195-55-16FR (RIP) '04 Volk GTC - 245-35-19F/275-35-19R (Sold to a farm boi) I thought Spark was a robot from the old movie and I kind of remember seeing him telling some engineer showing the equation for a clear metal that the guy would event years later - porschetr
#10220429 - 03/02/22 11:34 PM
[Re: Screamin Type ARGH!]
87ZCSi
Loc: Portland and Toronto
You can safely jettison the idea of calendar based oil changes. Modern engines are sealed up tight and not susceptible to issues like corrosion or oil breaking down due to moisture and other outside contaminants getting in over time. Solids from heat/blow-by/use(insolubles) and wear metals are the things that must be removed during oil changes and those only build up while the engine is running. Here wear metals are low next to universal averages. For all cars today, pretty much this. Did u use wearcheck in Burlington? We use them.
You likely always bring that car up to temperature though. One of our cars does a lot of short trips to daycare so that would look different. I've sent a sample off to Blackstone they said run to 15 months on my ML350. So, those oil tests can save money if used properly.
#10221211 - 03/03/22 10:39 PM
[Re: 87ZCSi]
hyper-s2k
Loc: T dot O dot, Canada
I have a lot of short distance drives (to in-laws; grocery stores; etc.) - so I stuck with once a year in the last couple of years.
I think I end up filling up once a month now (per car) - which I get about 400-450 a tank.
Ironically, the longest drives I have is taking my car to the mechanic in Markham. LOL
#10222006 - 03/06/22 06:24 AM
[Re: 87ZCSi]
DoWnGEAR
You can safely jettison the idea of calendar based oil changes. Modern engines are sealed up tight and not susceptible to issues like corrosion or oil breaking down due to moisture and other outside contaminants getting in over time. Solids from heat/blow-by/use(insolubles) and wear metals are the things that must be removed during oil changes and those only build up while the engine is running. Here wear metals are low next to universal averages. For all cars today, pretty much this. Did u use wearcheck in Burlington? We use them. You likely always bring that car up to temperature though. One of our cars does a lot of short trips to daycare so that would look different. I've sent a sample off to Blackstone they said run to 15 months on my ML350. So, those oil tests can save money if used properly.
This is a very good point that everyone should consider. I would imagine short trips would even have a larger impact on modern direct injected engines where build up of unburnt fuel in oil can occur.
#10234513 - 03/29/22 11:26 PM
[Re: DoWnGEAR]
BroKe
Loc: Markham, Ontario
After realizing I haven't done an oil change in exactly 1 year I started to read up if it's bad or not. Apparently because of the temperature changes, condensation can cause moisture which can build up and cause sludge which will block lubrication. That's if you don't drive alot and only drive short trips so the oil doesn't get hot and burn off the moisture. So now I'm slightly paranoid. I'm still at 70% oil life and my last oil change was a year ago. I think I might just do the oil change soon. Can't hurt I guess.
