#3365165 - 01/06/09 10:35 PM
GM 4.3L Troubleshooting
fellfrosch7
Loc: Las Vegas
So, picked up a cheap molester van a while ago, 98 Chevy Astro with the 4.3L. It ran decent when I got it, probably put around 100 miles on it over a couple of weeks, but it did have a CEL for P0172 and P0175 codes. I cleaned out the MAF, cleared the codes, drove for about 10 miles, and the light came back on, same codes. 2 miles later, CEL starts flashing and car gets a horrible misfire. I limp it home and park it. Check on it an hour later, starts right up, no more misfire.
2 days later, I go to drive the van again to drop off some boxes, probably about 10-15 miles trip. Park it home, and leave it for a few days. Next time I try to go and start it, maybe 4-5 days later, it just cranks and does not start. Will start with ether sprayed into the intake hose though, but dies as soon as it's done. When I turn the key, you can hear the fuel pump prime, but it seems like it gets nothing past the injectors.
On top of it, this POS is impossible to work on - I never had a van, how do you get to the engine? Through the dash? I didn't do any reading about these yet, but I want to know if anyone with 4.3L experience knows anything about the fuel setup on these and particular problems to look for, or things to try.
Running: 99 Maxima SE, 97 240SX SE - All motor Not running: 90 TSi AWD
#3365340 - 01/06/09 11:58 PM
Re: GM 4.3L Troubleshooting
[Re: fellfrosch7]
Submission
Loc: Houston, TX
GM uses a pretty standard size on the fuel line fitting for the pressure.
also, figure out what you need and buy it from here: http://stores.ebay.com/Nordstroms-Automotive-Inc we always have good luck w/ them.
on the GM's if the fuel pump is extremely loud (think racecar fuel pump but higher pitched) its done for, its just running and not making pressure.
#3365702 - 01/07/09 06:15 AM
[Re: Submission]
CommonGutterTrash
do these have the same "spider" injector as the vortec v8? if so thats your problem.
I was thinking this, or coils.
#3365817 - 01/07/09 07:53 AM
[Re: UglyValiant]
NHRATA01
Loc: New York
I have a factory service manual with the trouble shooting schematic.
It suggest by this:
1. Open hood.
2. Is engine 4.3 v6? If yes, go to 2a; No, 2b
2a. Junk vehicle. Not worth salvaging. Piece of crap.
Shortest Factory service manual ever.
The 4.3 is not a piece of crap at all, they're very stout. The problem is the port fuel injection systems they've been using since '94ish are crap. You can find an old TBI 4.3 that makes less power but will run 200k miles without a hiccup.
2001 NHRA Trans Am M6 2012 Buick Regal GS
#3366663 - 01/07/09 12:24 PM
[Re: NHRATA01]
SiGuyUWP
If the fuel pump replacement wasn't OEM, it might have gone bad again. My Dad's Blazer just needed a fuel pump, and OEM pump cost a bit more but it's worth it because it's a pain to replace. His had some similar problems, it ran great on the ~75 mile drive to my house loaded with boxes. I went to move it out of the driveway and it wouldn't start, a few hours later a friend and I went to mess with it and it fired right up. I drove it back to his house the next day with no trouble.
#3366668 - 01/07/09 12:24 PM
[Re: NHRATA01]
UglyValiant
The 4.3 is not a piece of crap at all, they're very stout. The problem is the port fuel injection systems they've been using since '94ish are crap. You can find an old TBI 4.3 that makes less power but will run 200k miles without a hiccup. I wouldn't go so far as to say the 4.3 is a piece of crap (though I'm not nearly as enamored with it as say my GM buds are), the schematic represented the vehicle it was in...there was only one possible outcome via following it.
I hate working on old school, RWD engine under the dash vans...
Older vans (particularly mid 60's, but into the 70's as well) at leas actually had a bit less room for the passenger, but gave FAR easier access to the engine. As ergonomics and room became a greater concern, the engines became less and less accessible...to the point of absurdity in some cases.
#3368321 - 01/07/09 08:41 PM
[Re: CommonGutterTrash]
DPG23
Loc: Los Angeles, CA
Umm that is a spider injector. I forgot you can replace them individually tho. The redesigned ones move the solenoid to the very tip of the injector, unlike the one in the link.
#3435833 - 01/29/09 04:29 PM
[Re: DPG23]
CommonGutterTrash
when I said "these are you injectors" I meant these are ALL of them...
#3438057 - 01/30/09 11:55 AM
[Re: fellfrosch7]
stickaz_old
Loc: Nor Cal, Hella hurr durr
i can't solve your specific problem, but wanted to share that I've always held the gm 4.3 v6 in high regard (I had a 91 s-10 blazer) usually little misfire problems i had had to do with running larger tires and the fender "splash" guards not protecting the distributor/other electrical shit properly, I'd have to dry everything out and re-grease it and replace the plugs just for grins and normally that solved whatever misfire i had. never did get around to replacing the splash shields though
#8877163 - 12/10/16 09:13 PM
[Re: stickaz_old]
00Formula
00Formula
The GM 4.3L was used in Yale and Hyster fork lifts up until 2015 and may still be an option, but I think they've moved toward Kubota LP engines. Yale/Hyster are the sales leaders in that size range fork lift, so they must be decent engines.
#8978803 - 03/20/17 09:57 PM
ypMs
#9089827 - 07/27/17 02:48 AM
zhengjx
zhengjx20170727 burberry canada marc jacobs sale michael kors outlet clearance canada goose outlet ugg boots,ugg boots outlet,ugg boots for women,ugg boots on sale,ugg boots clearance,ugg boots for men,ugg boots for kids,ugg boots clearance sale women,ugg boots clearance outlet coach outlet longchamp handbags coach outlet online polo ralph lauren true religion jeans sale uggs outlet nike outlet online ysl outlet online ferragamo shoes sale true religion outlet uk michael kors outlet clearance los angeles lakers coach outlet cheap football shirts mlb jerseys coach outlet clearance true religion jeans sale nfl jersey wholesale fitflops ray ban sunglasses uk chrome hearts outlet cheap ray ban sunglasses coach outlet online true religion outlet canada goose uk michael kors outlet online ralph lauren outlet louis vuitton uk oakley sunglasses sale louis vuitton outlet nike trainers uk cheap oakley sunglasses coach outlet online longchamp converse shoes sale michael kors outlet online coach factory outlet ferragamo outlet coach outlet coach factory outlet coach outlet online coach factory outlet mulberry handbags polo ralph lauren michael kors handbags true religion outlet mbt shoes cazal outlet ugg outlet,ugg outlet clearance,uggs outlet,ugg outlet online clearance,ugg outlet store,ugg outlet online store,ugg outlet sale,ugg outlet coupons,ugg outlet boots cheap oakley sunglasses christian louboutin shoes michael kors outlet online coach factory outlet michael kors outlet online cartier watches coach outlet online michael kors outlet michael kors outlet clearance ray ban sunglasses cheap jordans for sale mulberry uk canada goose burberry outlet store michael kors handbags pandora jewelery adidas wings shoes cheap ray ban sunglasses coach outlet store online oakley sunglasses wholesale nhl jerseys oakley sunglasses wholesale louis vuitton outlet online polo ralph lauren supra shoes sale nike trainers michael kors canada tory burch outlet online tory burch handbags ralph lauren polo ralph lauren uk polo outlet store ray ban wayfarer air max 90 ray ban sunglasses uk ralph lauren uk adidas shoes michael kors outlet clearance cheap jordans free shipping canada goose jackets max 90 true religion jeans cheap nike shoes mont blanc pens christian louboutin shoes longchamp handbags michael kors outlet links of london jewellery michael kors outlet louis vuitton borse ralph lauren polo air max 90 coach factory outlet louis vuitton outlet stores louis vuitton camisetas futbol baratas louis vuitton adidas shoes michael kors outlet online pandora jewelry nike outlet jerseys wholesale louis vuitton outlet online louis vuitton outlet store canada goose jackets cheap ray ban sunglasses oakley sunglasses sale mulberry handbags ralph lauren outlet coach outlet cheap replica watches polo ralph lauren michael kors outlet store michael kors outlet online coach factory outlet longchamp mulberry handbags sale nike outle michael kors outlet clearance michael kors outlet clearance cheap oakley sunglasses nike shoes uk longchamp outlet nfl jersey puma shoes michael kors outlet clearance oakley sunglasses sale kobe shoes instyler michael kors outlet online true religion outlet store mizuno shoes canada goose jackets coach outlet michael kors outlet clearance true religion outlet pandora outlet ralph?lauren?polo?shirts coach outlet online cheap jordan shoes michael kors outlet online michael kors outlet yeezy boost coach outlet online prada outlet snapbacks wholesale michael kors outlet online cheap oakley sunglasses mulberry outlet,mulberry handbags outlet michael kors outlet clearance nike shoes coach outlet online air force 1 shoes tory burch outlet online oakley sunglasses wholesale adidas shoes michael kors handbags canada goose outlet gucci outlet online coach outlet online cheap jordans ugg boots clearance,ugg boots,ugg boots outlet,ugg boots for women,ugg boots on sale,ugg boots for men,ugg boots for kids,ugg boots clearance sale women,ugg boots clearance outlet cheap jerseys wholesale michael kors outlet clearance lebron shoes adidas nmd runner kate spade handbags coach outlet christian louboutin shoes cheap ray bans cheap nfl jerseys coach outlet store online pandora jewellery cheap nfl jerseys coach outlet clearance michael kors outlet clearance reebok shoes swarovski jewellery cheap mlb jerseys Nike Free shoes coach factory outlet ralph lauren outlet coach outlet store true religion outlet michael kors outlet clearance michael kors uk ralph lauren coach outlet store online ugg boots for women,ugg boots,ugg boots outlet,ugg boots on sale,ugg boots clearance,ugg boots for men,ugg boots for kids,ugg boots clearance sale women,ugg boots clearance outlet vans outlet tods outlet online cheap oakley sunglasses adidas uk store michael kors outlet clearance true religion canada coach outlet nhl jerseys wholesale prada outlet nba jerseys wholesale rolex watches louis vuitton coach factory outlet cheap jordan shoes thomas sabo charms polo ralph lauren rolex orologi ralph lauren outlet stores kate spade uk louis vuitton louis vuitton outlet oakley sunglasses wholesale coach outlet online juicy couture tracksuit polo ralph lauren michael kors handbags max 1 cheap ray ban sunglasses nike air max 1 swarovski outlet pandora outlet true religion jeans swarovski uk air max 90 mulberry handbags tory burch sandals louis vuitton outlet coach outlet online oakley sunglasses wholesale michael kors outlet ferragamo shoes mont blanc outlet michael kors outlet gucci outlet online kate spade coach factory outlet canada goose outlet reebok shoes ralph lauren outlet coach outlet online mulberry handbags sale cheap oakley sunglasses cheap nba jerseys michael kors uk lacoste polo ecco outlet louis vuitton oakley sunglasses wholesale ugg outlet clearance,ugg outlet online clearance,ugg outlet,uggs outlet,ugg outlet store,ugg outlet coupons,ugg outlet boots,ugg outlet online store,ugg outlet sale tory burch outlet online coach factory outlet michael kors outlet online nike outlet store online oakley sunglasses wholesale nike uk store hermes belts coach outlet online ed hardy outlet cartier outlet nfl jersey wholesale nike roshe run polo ralph lauren outlet polo ralph lauren canada goose coats christian louboutin sale nike air max coach outlet online sac louis vuitton pas cher swarovski crystal cheap ray ban sunglasses polo outlet stores true religion outlet nfl jerseys bottega veneta outlet online michael kors outlet online oakley sunglasses canada goose outlet ray-ban sunglasses swarovski crystal louis vuitton handbags michael kors outlet online true religion jeans polo pas cher nba jerseys cheap jerseys wholesale gucci outlet online ralph lauren outlet Basketball Shoes michael kors uk louis vuitton outlet stores cheap oakley sunglasses michael kors outlet store ugg boots,ugg boots outlet,cheap uggs boots,ugg boots for women,ugg boots on sale,ugg boots clearance,ugg boots clearance sale women,ugg boots clearance outlet,ugg boots for men,ugg boots for kids ralph lauren uk longchamp handbags louis vuitton outlet online michael kors outlet clearance oakley sunglasses wholesale swarovski jewelry gucci borse chrome hearts online store coach outlet store online snapback hats oakley sunglasses cleveland cavaliers jerseys nike roshe run fitflops sale clearance nike free running soccer jerseys wholesale louis vuitton outlet coach outlet online polo outlet online pandora outlet coach outlet michael kors outlet michael kors outlet clearance christian louboutin uk polo ralph lauren outlet oakley sunglasses wholesale christian louboutin shoes ray-ban sunglasses christian louboutin sale nfl jerseys louis vuitton outlet adidas nmd burberry outlet sale christian louboutin outlet oakley sunglasses sale omega outlet christian louboutin sale oakley sunglasses wholesale coach outlet online polo outlet asics,asics israel,asics shoes,asics running shoes,asics israel,asics gel,asics running,asics gel nimbus,asics gel kayano michael kors outlet online canada goose outlet store louis vuitton outlet online christian louboutin michael kors outlet canada goose outlet store christian louboutin shoes ralph lauren polo cheap soccer jerseys ray ban sunglasses outlet coach outlet store online lacoste pas cher coach outlet online oakley sunglasses louis vuitton handbags pandora outlet coach outlet clearance mbt shoes outlet canada goose jackets louis vuitton cartier watches for women true religion jeans cheap ray ban sunglasses oakley sunglasses lebron shoes coach outlet cheap uggs outlet,cheap uggs for sale,cheap ugg boots,cheap uggs for kids,cheap uggs for women,cheap uggs bailey bow,cheap uggs china,cheap uggs for men,cheap uggs for girls,cheap uggs boots for women polo ralph lauren outlet polo outlet mulberry outlet coach outlet adidas outlet michael kors outlet online coach outlet online ugg outlet,uggs outlet,ugg outlet online clearance,ugg outlet store,ugg outlet coupons,ugg outlet boots,ugg outlet online store,ugg outlet sale tory burch outlet stores hermes outlet nike shoes cheap oakley sunglasses nike outlet store online nike blazer pas cher adidas shoes cheap oakley sunglasses christian louboutin outlet ray ban sunglasses outlet pandora charms sale clearance rolex watches for sale longchamp outlet online cheap ray bans cheap jordan shoes true religion uk michael kors uk nike shoes for women uggs outlet christian louboutin outlet polo ralph lauren michael kors outlet clearance michael kors outlet online herve leger dresses hollister clothing store foamposite shoes cheap oakley sunglasses ferragamo shoes coach outlet ray ban sunglasses canada goose outlet cheap ray ban sunglasses coach outlet louis vuitton giuseppe zanotti shoes louis vuitton outlet stores nike air huarache ralph lauren louis vuitton outlet online cheap ray ban sunglasses coach outlet store online kate spade uk nike shoes outlet ugg outlet basketball shoes,basketball sneakers,lebron james shoes,sports shoes,kobe bryant shoes,kobe sneakers,nike basketball shoes,running shoes,mens sport shoes,nike shoes coach outlet coach outlet online coach factory outlet cheap oakley sunglasses nike air max 90 true religion jeans outlet polo outlet cheap oakley sunglasses louis vuitton bags coach factory outlet oakley sunglasses wholesale michael kors outlet coach outlet online cheap oakley sunglasses coach handbags outlet louis vuitton nike air max 90 coach outlet ferragamo shoes lacoste outlet coach outlet michael kors outlet online ray bans mulberry bags christian louboutin sale michael kors outlet michael kors outlet clearance prada sunglasses for women rolex watches tory burch outlet jordan shoes birkenstock shoes cheap oakley sunglasses pandora bracelet hermes birkin bag michael kors outlet clearance ralph lauren canada goose outlet coach outlet cheap jordans kobe 9 elite oakley sunglasses wholesale air max 2015 air max shoes kate spade handbags kobe bryants shoes louis vuitton ferragamo outlet fitflops ferragamo outlet louis vuitton outlet cheap oakley sunglasses cheap jordan shoes ralph lauren?uk ralph lauren outlet kate spade outlet online coach outlet store online kd shoes gucci outlet prada outlet online soccer cleats gucci outlet online ralph lauren outlet nike store uk christian louboutin shoes adidas outlet michael kors outlet michael kors outlet clearance new balance outlet mulberry outlet michael kors outlet online cheap ray ban sunglasses air max 90 nike trainers rolex watches outlet canada goose outlet polo ralph lauren outlet fitflops uk fitflops sale clearance polo outlet cartier watches ralph?lauren cartier watches for sale coach outlet online mac cosmetics sale polo ralph lauren polo outlet stores ugg outlet,ugg outlet store,uggs outlet,ugg outlet online clearance,ugg outlet coupons,ugg outlet boots,ugg outlet online store,ugg outlet sale louis vuitton outlet lacoste shirts ralph lauren outlet canada goose jackets burberry outlet store mlb jerseys coach outlet michael kors outlet stores ray ban sunglasses wholesale mbt shoes outlet fitflops sale clearance coach outlet online ralph lauren swarovski jewelry ray ban sunglasses michael kors outlet clearance canada goose jackets pandora charms nike air huarache coach factory outlet cheap oakley sunglasses louis vuitton outlet michael kors handbags valentino shoes christian louboutin longchamp outlet rolex outlet michael kors factory outlet gucci bags michael kors wallets for women snapbacks wholesale rolex watches,rolex replica watches,replica rolex watches,replica watches fitflops salomon outlet louis vuitton coach outlet store online fitflops uk air max trainers ugg outlet,ugg outlet sale,uggs outlet,ugg outlet online clearance,ugg outlet store,ugg outlet coupons,ugg outlet boots,ugg outlet online store michael kors outlet clearance oakley sunglasses wholesale coach outlet coach outlet clearance fitflops sale clearance coach factory outlet yeezy boost 350 louis vuitton outlet gucci outlet store ralph lauren shirts ralph lauren outlet cheap oakley sunglasses rolex uk jordan 4 coach outlet store online polo ralph lauren outlet fred perry polo tory burch outlet online coach outlet roshe run ray ban sunglasses canada goose outlet online cheap ray ban sunglasses coach outlet store online birkenstock shoes hermes outlet store cheap oakley sunglasses rolex watches,rolex watches,swiss watches,watches for men,watches for women,omega watches,replica watches,rolex watches for sale,rolex replica,rolex watch,cartier watches,rolex submariner,fake rolex,rolex replica watches,replica rolex mcm backpacks
#9173964 - 10/31/17 03:26 AM
HYst
