#6790297 - 12/24/12 04:42 PM
[Re: PsychoEBPSiR]
ReplicaR
'94 Mustang GT Acceleration....  -------+--  Handling.........  ---------+  Speed............  -----+----
#6807985 - 01/03/13 05:17 PM
[Re: ReplicaR]
ReplicaR
#6808179 - 01/03/13 07:03 PM
[Re: FastfedEros]
I <3 Fastfed
Glad to hear you're making progress!
#6809483 - 01/04/13 10:47 AM
[Re: UglyValiant]
Fastfeduous
I'm not sure why tuning this seems to be such an issue. I would have figured Mustang tuning would be very simple.
#6809607 - 01/04/13 11:25 AM
[Re: Fastfeduous ]
ReplicaR
#6809703 - 01/04/13 11:53 AM
[Re: UglyValiant]
ReplicaR
#6840072 - 01/17/13 06:08 PM
[Re: ReplicaR]
ReplicaR
#6842596 - 01/18/13 04:32 PM
[Re: FASTFED!]
ReplicaR
#6842659 - 01/18/13 05:16 PM
[Re: ReplicaR]
FASTFED!
Loc: Nor Cal, Hella!
Commuter(s)  "That when all that's left in a thread is just you, me, and your ayn rand center article, it's time to go to bed." --saspotch
#6842700 - 01/18/13 05:40 PM
[Re: FASTFED!]
ReplicaR
#6842718 - 01/18/13 05:57 PM
[Re: ReplicaR]
FASTFED!
rice maths: cats = -5 no underdrive pulley = -8 timing = -10 (??)
#6842787 - 01/18/13 06:43 PM
[Re: FASTFED!]
ReplicaR
#6849158 - 01/22/13 10:56 AM
[Re: FCobra94]
ReplicaR
#6849273 - 01/22/13 11:42 AM
[Re: ReplicaR]
Fastfeduous
I've heard the same - similar HP, much better torque on the long tubes.
The Performer RPM usually seemed to do the best in a lot of mag tests, but on a 331 - perhaps a bit bigger is better. I'm not sure what's out there anymore though.
#6849367 - 01/22/13 12:21 PM
[Re: Fastfeduous ]
ReplicaR
#6849785 - 01/22/13 02:30 PM
[Re: ReplicaR]
Fastfeduous
#6849885 - 01/22/13 03:41 PM
[Re: Fastfeduous ]
ReplicaR
I think you forgot the link.
#6850458 - 01/22/13 08:25 PM
[Re: ReplicaR]
Fastfeduous
#6851532 - 01/23/13 11:29 AM
[Re: Fastfeduous ]
ReplicaR
#6854875 - 01/24/13 05:26 PM
[Re: ReplicaR]
doshoru
Loc: Hotlanta
You could try removing the manifold at that point in the dyno, lol.
Halfway serious -- a 350z shop did something where in the upper RPMs, a pair of hands that had been holding down the upper manifold down, lifted it off the studs, allowing the engine to breathe freely, and power shot up. Thus, they knew it was a manifold limitation, and subsequently attempted to correct.
Custom manifold later, they had awesome power gains. 372whp on a mild cam, 3.5L.
edit: this is all if you want to "prove" it's the intake manifold, w/o actually buying/installing a new one (e.g. trial and error).
Edited by doshoru (01/24/13 05:28 PM)
'07 350z HR -- aka fatty <--- Name changed from "Baudchaser".
#6855153 - 01/24/13 08:12 PM
[Re: doshoru]
FASTFED!
#6899398 - 02/14/13 10:59 PM
[Re: FASTFED!]
ReplicaR
Bit of an update.
#6899636 - 02/15/13 07:42 AM
[Re: ReplicaR]
UglyValiant
Something has happened to it, and it's running very rich at idle, idle is unstable, and it backfires through intake on sudden throttle. My guess is either a pushrod bent or one or more of the rocker bolts backed out and is now out of adjustment (more likely)....even w/ locking nuts, it's not terribly uncommon for one or two to back out once or twice after initial assembly and running for a 100+ miles or so...
1979 Dodge Lil' Red Express Truck 2007 Chrysler Aspen (my first hemi) 1989 Shelby CSX (#500/500)
#6900328 - 02/15/13 11:25 AM
[Re: UglyValiant]
ReplicaR
#6900892 - 02/15/13 02:37 PM
[Re: ReplicaR]
Fastfeduous
What a pain. I've had issues with shops before and it turned into a nightmare. Hopefully this is not an issue in your case and everything gets buttoned tuned up soon.
#6918875 - 02/25/13 02:05 PM
[Re: Fastfeduous ]
ReplicaR
Update 02/25/2013
Rear seat removal: -40 lbs Spare tire and jack: -32 lbs Torino II to Evo swap: -30 lbs Aluminum side mount brakets: +5 lbs Cobra R to RPF1 wheel change: -16 lbs Reinstall strut tower brace and K-member brace: +15 lbs Rear floor mats: -2 lbs
#6920394 - 02/26/13 11:45 AM
[Re: ReplicaR]
ReplicaR
#6920495 - 02/26/13 12:28 PM
[Re: UglyValiant]
ReplicaR
Moderator: auxilary
