#5370417 - 02/13/11 11:27 AM
For those still into car audio - My Autotuba
loudsubz
Built one the other day with an 8" tangband w8-740. Amazing bass from such a small subwoofer. It utilizes a folded horn design from http://www.billfitzmaurice.com
You can build them yourself from the plans if your handy with woodworking. Hands down best sub build I have ever done. Went up against my brothers 12" Infinity reference in a sealed box + another cheaper 12" (2 X 12") and it was as loud but played lower and very musical.
Some pics
Heres what the build looks like inside.
#5370620 - 02/13/11 02:13 PM
Re: For those still into car audio - My Autotuba
Choco 'Nuck
Proud Member of BLM
Loc: Somewhere out there
Infinity reference or perfect 12 in a sealed box hits hard. I remember when I had the teg, I had two perfect 12s in a sealed box. You could move your nose hair with the spl
That folded horn design must hit pretty hard then
#5370687 - 02/13/11 03:06 PM
[Re: Choco 'Nuck]
loudsubz
heres a graph comparing it to a normal 12
Also the Tuba is efficient. I had about 25 watts going into the sub when it was playing at those levels. The woofer can't handle that much power but is capable of 120 watts rms.
#5370836 - 02/13/11 04:53 PM
[Re: Choco 'Nuck]
titty sprinkles
Infinity reference or perfect 12 in a sealed box hits hard. I remember when I had the teg, I had two perfect 12s in a sealed box. You could move your nose hair with the spl That folded horn design must hit pretty hard then
ya your subs in the teg were pretty serious. you can hear the old man reggae from across town!
#5371384 - 02/13/11 10:02 PM
[Re: loudsubz]
robbbby
master electrician
Loc: Canada
can something like this be built for home theatre? i need a new sub that sounds good. i have a cheaper old paradigm that isn't very musical, just sort of makes the same note at different volume levels. Take your pick: http://www.billfitzmaurice.com/He has the Table Tuba or Tuba Home Theatre. Depends on how much room you have to spare. You could also do a Tuba 60 but its more for pro sound use. Hit me up if you want to start a build.
Ya I definately will in the near future, got a few other projects on the go still so the theatre stuff isn't seeing much use. How much will something like this run? I don't need crack the foundation type bass, just something tight and clean that will sound good and work well for effects in movies. I'm just trying to save spending $1k on a decent sub since I still need to upgrade my AV receiver.
Actually i remember you saying it takes a while t build these right because you can only glue one piece at a time? Maybe i'll start this sooner than later.
edit - holy fuck these things are huge
#5372728 - 02/14/11 02:30 PM
[Re: loudsubz]
loudsubz
And if your referring to this guys post:
http://forums.audioholics.com/forums/showthread.php?t=18810
I have nothing to say...his post should give you an idea of what type of person he is
#5381675 - 02/17/11 09:20 PM
loudsubz
took a couple videos, you really need headphones with good bass response or a sub on your comp speakers to get an idea. Also it was so loud it causes my video camera mic to start distorting, all of the enclosures I have made so far cause this on the mic. I did not have this happen on direct radiator designs before.
Video 1 http://www.youtube.com/watch?v=4sqS2oNsX38
#5381700 - 02/17/11 09:33 PM
[Re: loudsubz]
loudsubz
#5381717 - 02/17/11 09:41 PM
[Re: loudsubz]
loudsubz
#5381795 - 02/17/11 10:23 PM
big tuner
Loc: Oakville, Ontario, Canada
I bet Euphoric busted out the glow sticks watching those videos
#5382690 - 02/18/11 12:11 PM
[Re: loudsubz]
titty sprinkles
hey loudsubz you don't happen to do fiberglass enclosures do you? I have worked with FG before when building some kick panels, but nothing major. Its too messy for me to enjoy using it a lot, so I try and stick to wood only.
ah gotcha. a long time ago i saw i think it was JL audio make this enclosure that fits 1 10 or 12 in the corner of the trunk of the integra. it was molded to fit nice and flush but i have never been able to find them. i want one so i don't have a box, and a cage is going to get welded in so i don't even know if a box will fit in there.
