#4979404 - 08/21/10 07:52 PM How to bypass the neutral safety switch in a 99 Si?
straitcrazy Offline
I got a remote start for my 99 Si. I already installed it and it works. However, I have to push the clutch in to get it to start. I need to know how to bypass the neutral safety switch so I can remote start the car without being in it to to use the clutch. Thanks.
Edited by straitcrazy (08/21/10 07:53 PM)
#4980083 - 08/22/10 11:25 AM Re: How to bypass the neutral safety switch in a 99 Si? [Re: straitcrazy]
kyden Offline
Loc: Providence, RI
its not a neutral safety ftr.
the ghetto way, paper clip in the clutch switch. right way would be a relay.
#4996708 - 08/28/10 10:03 PM Re: How to bypass the neutral safety switch in a 99 Si? [Re: kyden]
4doorEG Offline
Loc: Overland Park, KS
One day you will leave it in gear and hell will break loose. Don't do it
#4997442 - 08/29/10 01:02 PM Re: How to bypass the neutral safety switch in a 99 Si? [Re: 4doorEG]
kyden Offline
Loc: Providence, RI
depends on the remote start unit. with the new dei alarms they do have a manual transmission mode, and the only way you can really mess up is if you reach through an open window and put it in gear.
#5012501 - 09/04/10 06:13 PM Re: How to bypass the neutral safety switch in a 99 Si? [Re: straitcrazy]
KenNN Moderator Offline
Loc: Virginia, USA
The feature you're talking about is usually not called the "neutral safety switch". Most manufacturers call this the "clutch interlock" safety system. It requires you to have your foot on the clutch pedal to prevent the car from lurching if left in gear when the starter is engaged.
This feature is typically found only on US models as required by law. Other countries seem to be doing just fine without the clutch interlock system.
I don't recommend bypassing this safety feature so follow at your own risk.
The best way is to get an FSM. Pull up and see how the starter wiring works. You will see that there is a clutch switch that diverts power away from the starter solenoid if the clutch is not pressed. You need to bypass the clutch switch and provide power to the starter solenoid regardless of the clutch position.
#5012740 - 09/04/10 09:37 PM Re: How to bypass the neutral safety switch in a 99 Si? [Re: KenNN]
Loc: Virginia, USA
The 99 Si came with the factory alarm. Look at page 133-7 of the FSM. It shows you the wiring for the clutch interlock switch.
Get under the clutch pedal and look for a little switch that gets pressed when the clutch is all the way out. Unplug the connector.
There should be 2 wires: blue/black and black. Jumper or otherwise connect these 2 wires together (it makes the car think that the clutch pedal is pressed all the time) and the starter should be able to turn without the clutch pedal being depressed.
The factory alarm is a whole other mess but you're not asking about it so I'll leave it alone.
#9122615 - 09/03/17 09:33 PM Re: How to bypass the neutral safety switch in a 99 Si? [Re: KenNN]
fatihin nurul Offline
ka kemudian mengatakan bahwa jika kita telah me Harga besi siku baja
Agen pipa besi baja sch 40 sch 80
Harga besi wf
Agen bondek
undangan pernikahan unik
Supplier Welded Beam T beam King Queen Cross Castellated Beam
Supplier Pipa Besi baja
Harga besi h beam baja
Supplier besi beton delcoprima
Jual besi siku baja
Jual besi siku baja
Agen Plat besi
Jual besi wf
Agen wiremesh
undangan pernikahan ada foto
Supplier Bondek Cor
Agen Pipa Besi baja
Jual besi h beam baja
Supplier besi beton cakra steel cs
Supplier besi siku baja
Agen besi h beam
Supplier besi wf
undangan pernikahan yang unik
Supplier Atap Spandek Sni
Toko Pipa Besi baja
Supplier besi h beam baja
Supplier besi beton bjku
Toko besi siku baja
Toko besi siku baja
Agen besi wf
Toko besi wf
Agen besi hollow
undangan pernikahan ala jepang
Supplier Plat Bordes Kembang
Jual Pipa Besi baja
Toko besi h beam baja
Supplier besi beton Sni Ulir Polos
Agen besi siku baja
Agen besi siku baja
Agen wiremesh
Agen besi wf
Agen besi beton Sni Ulir Polos sewa villa puncak
undangan pernikahan arab
Supplier Plat Besi Hitam
Harga Pipa Besi baja
Agen besi h beam baja
Supplier besi beton ais
Pabrik besi siku baja
Agen besi unp
Pabrik besi wf
Agen besi wf baja
Supplier Plat Kapal Bki Krakatau Steel
Pabrik Pipa Besi baja
Pabrik besi h beam baja
Supplier besi beton
Distributor besi wf
Distributor besi wf
Agen besi cnp
Distributor besi hollow
Agen besi unp
undangan pernikahan bermanfaat
Supplier Jual Besi Siku Baja
Distributor Plat Kapal Besi baja
Distributor plat besi hitam
jasa konstruksi baja
Harga besi wf
Harga besi wf
Agen besi hollow
Harga besi hollow
Agen besi siku
undangan pernikahan ada fotonya
Supplier Besi Unp Baja Profil Kanal
Supplier Plat Kapal Besi baja
Harga plat besi hitam
www.pusatbesibaja.co.id
Jual besi wf
Jual besi wf
Jual besi hollow
Agen Plat besi plat kapal
undangancinta.com
Supplier Besi Cnp Profil Baja Gording
Agen Plat Kapal Besi baja
Jual plat besi hitam
www.pusatbesibaja.com
Supplier besi wf
Supplier besi wf
ironsteelcenter.com
Supplier besi hollow
undangan pernikahan cantik dan murah
Supplier Besi Hollow
Toko Plat Kapal Besi baja
Supplier plat besi hitam
Toko besi wf
Toko besi wf
Toko stainless steel
Toko besi hollow
Agen besi cnp
undangan pernikahan akrilik
Supplier Wiremesh
Jual Plat Kapal Besi baja
Toko plat besi hitam
Pabrik besi beton Sni Ulir Polos polos ulir
Agen besi wf
Agen besi wf
Toko atap spandek
Agen besi hollow
www.gudangbesibaja.com
undangan pernikahan bentuk tas
Supplier Besi Pipa Baja Schedule 80
Harga Plat Kapal Besi baja
Agen plat besi hitam
Pabrik besi beton sii
Pabrik besi wf
Pabrik besi wf
Toko baja ringan
Pabrik besi hollow
Toko besi Wf Baja
undangan pernikahan online
Supplier Besi Pipa Baja Schedule 40
Pabrik Plat Kapal Besi baja
Pabrik plat besi hitam
Pabrik besi beton psi Ulir Polos
Toko bondek
Distributor pipa besi
Toko bondek
undangan pernikahan modern
Supplier Pipa Besi Hitam Medium
Distributor Wiremesh Besi baja
Distributor plat kapal besi baja
Pabrik besi beton perwira
Harga besi hollow
Harga besi hollow
Toko Plat kapal besi baja bki krakatau steel
Harga pipa besi
Toko wiremesh
Supplier Besi Wf
Supplier Wiremesh Besi baja
Harga plat kapal besi baja
Pabrik besi beton PAS
Jaket Parka Jaket Parka
undangan pernikahan kalender
undangan pernikahan islami
undangan pernikahan
undangan pernikahan simple
undangan pernikahan murah
undangan pernikahan artis
undangan pernikahan
undangan pernikahan
LINK 8
#9164179 - 10/20/17 12:40 AM Re: How to bypass the neutral safety switch in a 99 Si? [Re: fatihin nurul]
Desy Offline
Faced the same problem.
#9189978 - 11/17/17 09:00 AM Re: How to bypass the neutral safety switch in a 99 Si? [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
abercrombie and fitch
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
#9214650 - 12/20/17 08:38 PM Re: How to bypass the neutral safety switch in a 99 Si? [Re: ]
20171221yuanyuan Offline
nike outlet store
louis vuitton outlet store
ugg boots
ugg boots
ralph lauren sale
the north face outlet
air max
ray ban sunglasses discount
pandora jewelry outlet
fred perry polo shirts
cheap ugg boots
canada goose jackets
coach factory outlet online
michael kors outlet clearance
nike outlet store
timberland outlet
longchamp sale
gucci outlet
oakley sunglasses outlet
adidas outlet online
ugg
longchamp bags
birkenstock outlet
michael kors outlet store
retro 11
adidas nmd r1
burberry handbags
supreme clothing
toms shoes
canada goose coats
ray ban glasses
yeezy shoes
air jordans
hermens
louboutin outlet
pandora charms sale
valentino outlet
ugg outlet store
cheap ugg boots
discount oakley sunglasses
coach outlet canada
ray bans
nike outlet online
canada goose outlet store
adidas nmd r1
canada goose coats
fred perry shirts
burberry outlet online
nike outlet online
yeezy boost 350
adidas nmd runner
canada goose coats
kate spade outlet online
moncler sale
moncler jacket
ugg boots
ugg boots
north face outlet
north face sale
burberry outlet
louis vuitton factory outlet
canada goose coats
jordans
nike sneakers
ugg boots sale
moncler
bottes ugg
pandora uk
supreme uk
adidas yeezy boost
ugg outlet store
pandora uk
ray bans
ray ban sunglasses cheap
nmd adidas
hermes bag
moncler jackets
pandora
longchamp outlet store
ugg boots
ugg outlet store
valentino
coach handbags outlet
mulberry
adidas yeezy boost 350
ugg canada
ugg boots
salvatore ferragamo shoes
uggs
red bottoms
north face outlet
mbt
ugg boots
ugg outlet online
coach factorty outlet online
yeezy boost 350
canada goose coats
cheap jordans free shipping
moncler sale
uggs clearance
moncler coats
ugg australia outlet
adidas ultra boost
cheap ugg boots
adidas yeezy shoes
canada goose coats
cheap jordans for sale
nike sneakers
hermes outlet
moncler outlet online
tory burch outlet online
longchamp bags
ugg canada
uggs clearance
ugg boots outlet
ugg boots outlet
ralph lauren sale
nike air max 2018
hermes handbags
adidas outlet store
air max
caterpillar boots
air jordan retro
ugg sale
adidas sneakers
moncler uk
air max shoes
gucci outlet online
moncler jackets
fitflop sandals
hermes bags
cheap air jordans
supreme shirts
pandora charms outlet
ugg outlet online
burberry handbags
moncler pas cher
harden vol 1
mulberry uk
moncler coats
nike outlet store online
adidas yeezy boost
cheap air jordans
ugg boots
moncler jackets
coach purses
burberry handbags
adidas outlet store
north face jackets
yeezy shoes
red bottom heels
yeezy boost 350
mulberry outlet uk
michael kors outlet canada
ugg boots
birkenstock shoes
michael kors bags
cheap uggs
ugg boots
cheap ugg boots
adidas superstars
canada goose jacket
coach outlet canada
mlb jerseys cheap
adidas nmd r1
adidas store
ugg boots outlet
salvatore ferragamo outlet
air jordan shoes
moncler uk
moncler coats
timberland outlet store
ugg outlet online
columbia sportswear outlet
yeezy shoes
canada goose jackets uk
canada goose outlet online
canada goose parka
cheap nfl jerseys wholesale
uggs on sale
adidas superstar shoes
birkin handbags
cheap air jordans
mbt
the north face jackets
red bottom
louboutin outlet
pandora jewelry store
adidas nmd runner
uggs on sale
north face jackets
hermes bags
ugg boots
ugg boots women
tory burch shoes
ugg boots
ugg outlet store
#9235999 - 01/21/18 09:20 PM Re: How to bypass the neutral safety switch in a 99 Si? [Re: 20171221yuanyuan]
Andada
colts jerseys
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
michael kors handbags sale
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
buffalo bills jerseys
fitflops sale
nike huarache
seattle seahawks jerseys
jaguars jersey
Moderator:  The Mad Paki, KenNN
