#4084161 - 09/16/09 04:52 PM 00 Civic with Jackson Racing Charger issue.
BartmanMN-Si Offline
Loc: Minneapolis, MN
So here is a little background. I have been running my charger on my car for 50 to 60K miles without any issues. Last week while driving home I through a cell P0131, which is for low voltage to the Primary Oxygen sensor.
I have been running a test pipe with Zips O2 Simulator the entire time. Thinking that maybe the O2 Simulator went bad, I had my Catlytic converter installed back on the car and plugged the sensor back in. I reset the cell and drove ~15 to 20 miles and it has not come back on. This is positive.
The other issue that I now have is my car detonates with the slightest touch of the gas. I have to drive it super carefully to not detonate. I do not have engine management. I have the 2025 Cartech Fuel Pressure Regulator. The Fuel Pressure on my gauge also reacts very quickly to any throttle deployment.
Any ideas what I should look at??
00' EBP Si--(JRSC)
Wanted: Free Hondata \:D
#4084203 - 09/16/09 05:03 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
Now that the catalytic conv and o2 sensor are installed, I am thinking about uninstalling the O2 Simulator in case it did go bad and that is contributing to the fuel issues.
00' EBP Si--(JRSC)
#4084859 - 09/16/09 08:18 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
4doorEG Offline
Loc: Overland Park, KS
If you are using the fmu crap that comes with the JRSC kits then throttle tip in detonation is probably what you are experiencing.
What plugs do you have in the car? Do you have an AFR gauge to show you what AFRs are with throttle tip in?
You might have to bite the bullet and buy true engine management and get the car tuned properly.
#4085057 - 09/16/09 09:40 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: 4doorEG]
Plugs are NGK brk7e. Well, I can tell you which cylinder is detonating. God Damn. #2 spark plug and wire were torched. Going to leave it in the garage until I can check the ohms on the injectors to see if I have a bad injector.
00' EBP Si--(JRSC)
#4085523 - 09/17/09 12:35 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
AzRider Offline
Loc: Phoenix, AZ USA
THIS. time to ante up to a simple engine management solution. i ran a very basic hondata s200 and 440cc rc injectors when i had a 00 civic w/ a jr. helped tremendously. DO IT. and might have to replace one or both o2 sensors cause they are prolly shot. won't know until you use a voltmeter.
#4086972 - 09/17/09 12:37 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: AzRider]
4doorEG Offline
Also if your front o2 sensor is shot, then you should have that replaced also. It could be thinking it's too rich and just pulling back fuel. Do you have a good scanner to check long and short term fuel trims?
-Chuong
#4090431 - 09/18/09 12:08 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: 4doorEG]
All resistors came back consistant on my Multimeter at 11.8Ohms, so those look fine. I replaced the spark plugs and wires and have the car on jacks to replace the primary O2 sensor as well. I am hoping it was all related to the primary sensor.
00' EBP Si--(JRSC)
#4094609 - 09/20/09 12:56 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
TittyQ Offline
Was not really effected by COVID
Loc: The unknown
If it has been running good for 50-60K then most likely it is one of the parts you are replacing.
#4096734 - 09/21/09 09:47 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: TittyQ]
I was able to get the Primary o2 sensor installed in addition to the wires and plugs and it appears to be running better without detonation under normal driving conditions. I have not tried to push it into boost yet.
00' EBP Si--(JRSC)
#4096799 - 09/21/09 10:05 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
TittyQ Offline
Loc: The unknown
I had a similar issue when I had mine, but it would only detonate under half boost, but at full it was scream. Ended up having a vacuum line that was clogged.
#4098200 - 09/21/09 03:31 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: TittyQ]
Thanks for the tip. I have been thinking about replacing all of my vacuum lines with new rubber, just because they are getting a bit old and the stuff is cheap.
00' EBP Si--(JRSC)
#4100622 - 09/22/09 09:05 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
Drove into work today cell free, however the car still wants to detonate even out of boost. If I press the gas enough to cause my fuel pressure gauge to increase by 10-20 psi it starts to detonate. I don't remember my fuel pressure rising until I transitioned from vacuum to boost in the past. Was I just not paying attention or is it abnormal for the fuel pressure to increase even out of boost?
00' EBP Si--(JRSC)
#4100870 - 09/22/09 10:06 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
TittyQ Offline
Loc: The unknown
Sounds like the map sensor might be seeing boost. Are you running the relay or the JR map controller?
#4101174 - 09/22/09 11:14 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: TittyQ]
I am running the relay to my knowledge. I have the JR BTC, but not the JR map controller.
00' EBP Si--(JRSC)
#4104727 - 09/23/09 11:13 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
I made a few WOT runs on the way home last night and the detonation stops when in boost, so it looks to be 'tip in' related. o2 Sensor likely fixed the cel, so I should be "ok" for now.
00' EBP Si--(JRSC)
#4105733 - 09/23/09 03:33 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
Cut the charger belt off today and the car runs completely detonation free and the vacuum stays at 10 while accelerating.
Edited by BartmanMN-Si (09/23/09 04:48 PM)
Edit Reason: removed portion about spinning charger, figured it out.
00' EBP Si--(JRSC)
#4106561 - 09/23/09 08:20 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
drifter57 Offline
a lot of us had the same problems with the jrsc... we all ended up getting bigger injectors and engine management, and the things really helped out a lot... I'll tell you my story,
I started off with the JRSC with just a AEM CAI and walbro LPH 255 fuel pump, and retarding the timing by say 6-10 degrees. There was power, but my car suffered from lack of low end power. I think it dyno'd at a measly 157 whp
So then I tried using Zip's version of the VAFC plus DSM 450 cc's to trick the MAP sensor and raising the fuel in boost. It did not solve tip-in detonation, the car would surge every so often in part throttle, and then after the 3rd or 4th day, it would throw a CEL.
Then I upgraded to the hondata with rc 440's, had it retuned, and got a healthy 198 whp with still just a an aem CAI and fuel pump. timing was advanced, and the car became so much more driveable.
You're probably on a budget, but to be honest, when you're supercharging or turbocharging, you've got a do it right, or suffer having detonation and possibly more damage to the internals...
Some people were running chrome a while back as well as a host of other freeware type engine management software on p28 ecus. you may want to check that out if you're on a budget... cheers
d
#4107066 - 09/23/09 10:45 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: drifter57]
TittyQ Offline
Loc: The unknown
I would at least try and find a used JR Map controller, some times they pop up and are $50-70.
#4111916 - 09/25/09 10:56 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: TittyQ]
Yeah, I read up on the MAP controller and it sounds like it just dumps fuel as if you are cold cranking your car at start up. I'm just going to leave the charger belt off for awhile, until I get annoyed by the slowness. haha
00' EBP Si--(JRSC)
#4127552 - 10/01/09 06:24 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
JAMinCiViC Offline
Loc: San Diego, now Iwakuni, JAPAN
looks like you def need a hondata!
JORDAN - [EM1 Crew]
20% OFF @ KARMALOOP.COM -->USE REP CODE JL7116
#4248841 - 11/13/09 04:03 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: JAMinCiViC]
Question for people with a Jackson Racing charger or who had one. If you schredded a belt and took it off. Would you zip tie the bypass valve open or leave it alone to continue driving? If you did zip tie it, would your car go into vtec or not. Mine does not with it not zip tied. I have not tried zip tying it yet.
00' EBP Si--(JRSC)
#4249117 - 11/13/09 05:43 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
drifter57 Offline
If the belt is off, then you won't need to open up the bypass valve in regards to risk of hurting your motor. As far as vtec engaging or not, you've got me on that one. I believe vtec is based on engine speed, rpms, and throttle position / air velocity - not whether or not the bypass valve is open. Then again, you're probably getting a lot of restriction with the JRSC not working, so if you open up the bypass valve, you may be getting the vtec to engage...
#4380891 - 12/29/09 09:14 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: drifter57]
Highrevs99 Offline
Loc: Moultrie,GA.USA
Dang,cant believe some people still have this problem 10 yrs later after the JRSC intro. Get a simple engine management and the car will run better and reliably. All the JR rig fixes are just that; a bandaid. Your vtec is based off engine load and rpm. Fix the belt asap and stop revving the motor with a broken blower belt.
Got a 5.0 really going to BLOW
#4475770 - 01/31/10 09:57 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: BartmanMN-Si]
danova Offline
movie downloads
#4849752 - 06/24/10 11:15 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: danova]
whitemanch22 Offline
nobody mentions here that you should be running premium with jrsc. i also had the same issue and started running 91 and once with 100 which fried my o2 sensor and cat b/c of lead in the 100 octane. But ultimately I say get rid of the jsrc the company is unreliable and at some point the compressor housing will start to leak oil which is not refillable. good luck
#4850748 - 06/25/10 11:26 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: whitemanch22]
Buzzbomb Offline
Loc: Bryan, Ohio, USA
He's running an Si which requires premium even without the SC.
Authorized AMSOIL Dealer
00' Si Turbo
02' WRX Wagon XPT Stage2
13' Tribeca 3.6R Limited
#9045669 - 06/01/17 04:13 AM Re: 00 Civic with Jackson Racing Charger issue. [Re: ]
lzm Offline
ua shoes
Abercrombie Fitch
pandora uk
sunglasses store
pandora sale
nike shox
ray ban wayfarer sunglasses
Jimmy Choo Shoes
nike shox
Nike Air Jordan
Hockey Jerseys Outlet
wayfarer sunglasses
moncler jacket
north face sale
nike huarache shoes
prada sale
snow boots uk
Nike Jordans
ray ban clubmaster sunglasses
burberry australia
Premier Jewelry - Official
Nike Dunk SB Low
Kate Spade - Online Sale
chrome store
Zales Jewelry
Wave Prophecy 2 Shoes
Kay Jewelers - Official
Prada Sunglasses - Official
pandora rings
Dreamland Jewelry - Official
moncler sale
ugg uk
pandora.com
chrome store canada
prada sunglasses
Hugo Boss Store
Engagement Rings - Official
official michael kors
Nike Free Run
Ray Ban sunglasses
ray-ban aviator
pandora deutschland
Nike Air Max
Football Jerseys Outlet
pandora bracelets charms
Pandora Bracelet - Official
burberry scarf
pandora rings
Sunglasses outlet sale
sunglasses sm
coach usa online
burberry scarf
official kate spade website
Jared Jewelry - Official
yeezy boost 350 white
Nike Hyperdunk Shoes
prada outlet online
ray-ban glasses
Baseball Jerseys Outlet
Prada Outlet
ray ban online
coach australia
pandora uk
gel kayano
ugg uk
Basketball Jerseys Outlet
salomon sneakers
Chanel Outlet
Coach Sunglasses Outlet
chrome store
prada outlet online
top sunglasses
prada outlet woodbury
rayban prescription glasses
tiffany co
sunglasses
Nike KD 8
tracking ups
burberry australia
nike air max 95
ray-Ban sunglasses
abercrombie canada
nflshop com
ray-ban eyeglasses
pandora jewelry sale
the beat
Brighton Jewelry - Official
louis vuitton bags
Coach Handbags
louis vuitton
kate spade italy
Baseball Jerseys Outelt
nike free shoes
mens sunglasses
mcm outlet online
prada outlet online
coach australia
homepage keywords
burberry outlet
balenciaga us
coach outlet us
kate spade outlet store
pandora sale
official coach outlet site
pandora uk
prada online
michael kors watches
Diamond Rings - Official
Prada Shoes - Official
sunglasses
Longchamp outlet
ray ban uk
Hermes Outlet
Wine
Nike Free
prada outlet sale
michael kors australia official
Burberry Australia
Michael Kors Outlet
Nike Air Max
michael kors us
pandora rings
prada outlet bags
pandora uk
shoes sale
Jordan Flight 45 Femme
yeezy boost 350 shoes
piumini moncler replica
Oakley Sunglasses
oakley frogskins sunglasses
Nike Free Run
Oakley Sunglasses
michael kors uk online
coach tennis shoes
chrome store
canada goose sale online
ray-ban sunglasses
Nike Free
louis vuitton us
louis vuitton australia
mk outlet online
burberry outlet online
Oakley Sunglasses
Longchamp tote
burberry purse
softball jerseys
ugg boots
pandora rings uk
Nike Free
spades uk
chanel bag
Nike Free Run
coach handbags sale
BURBERRYburberry australia
Promise Rings - Official
myhermes parcel shop
nike jordan shoes
prada online
rayban sunglasses
Watches
coach watches
kate spade wallet outlet
prada wallet men
Prada bags
pandora rings
coach carter
shop mlb
burberry outlet canada
tiffany co
sunglasses hut
ugg boots
Wedding Rings- Official
Jewelry Armoire - Official
prada us
payless shoes online
poly sunglasses
michael kors outlet bags
pandora uk
nike running
Nike Zoom
Coach outlet online
moncler us
Burberry Shirt - Official
celine outlet online
Premier Jewelry. - Official
official chrome hearts
pandora necklaces
nbastore
prada purses
ray ban polarized sunglasses
sunglasses outlet
coach outlet online sale
oakley holbrook.
prada outlet online
snow boots
pandora uk
pandoracharms
rayban prescription sunglasses
Salomon Speedcross Shoes
lzm6.1
#9079233 - 07/13/17 11:48 PM Re: 00 Civic with Jackson Racing Charger issue. [Re: lzm]
ppst Offline
On the field of death, the Moncler Outlet Online shells, in colossal[35] joy, chorused Sac a main michael kors their terrible harmonies, making Vans Black Sneakers the nfl store heavens sonorous with cheap nike air max their Michael Kors Outlet wanton and Nike Shoes Sale Store unbridled frenzy; star-shells, which seemed at ugg factory outlet times Jordan Schoenen to be Air Max Pas Cher fixed Ugg boots Sale on the ceiling of Nike Factory Store the sky, Nike Air Max Cheap oscillated in zapatos de futbol nike a botas de futbol dazzling whirl of Chaussure Air Max red and green—and men Nike Air Max Sale died.... We remained Yeezy Boost Sale Online in Boutique Ugg the Adidas Shoes Discount Marketplace trenches Jordan Shoes For Cheap the Hugo Boss Sale next day. They Nike Online Store were very Cheap Air Max Trainers quiet, nike air jordan pas cher and Cheap Michael Kors Tote Bag we lay at ease nike shoes in Moncler Outlet Store our Air max levně dug-outs, Pandora Official Website read new pandora charms week-old papers, wrote letters and canada goose jackets on sale took turns Nike Store on sentry-go. louboutin heels On 23 IS BACK Store our front lay New Nike Shoes a chaussures nike pas cher dull Ray Ban Sunglasses Online brown, Boty Nike Air monotonous zapatillas nike baratas level TOMS OUTLET and two red-brick Pandora Style Beads villages, Loos and Hulluch. Our barbed-wire Nike Air Huarache For Sale entanglement, twisted Yeezy Men and shell-scarred, cheap uggs showed countless rusty spikes günstige nike schuhe which stuck out ominous and Nike Pas Cher Femme forbidding. A dead German Ray Ban Sunglasses Cheap hung on Adidas Originals Stan Smith a wire prop, his feet Ugg Pas Cher En France caught nike air max running shoes in Zapatillas Air Max a Michael Kors Handbags Discount cheval Descuentos Nike de frise, the skin of Cheap Air Max his Soccer Boots Outlet nike face peeling away from Air Max Sneakers his bones, and his hand clutching Jordan Shoes Air the wire as if for zapatilla adidas support. Nike Roshe Run He had been huarache sneakers out there Boost Yeezy Sale On Line for Nike Shox discount Sale many months, nike jordan shoes a foolhardy Cheap Nike Air Huarache foe who got a Canada Goose Outlet bullet Ugg Pas Cher Femme through his head when christian louboutin outlet examining our defences.
