#3250728 - 11/28/08 11:00 PM Igniter/coil test:
Import Tuner Offline
Gold Member
Loc: Tacoma, Wash..
So, you've determined that your car doesn't have spark!...
Is it the igniter or the coil?...
STEP 1:
Remove distributor cap (w/wires still intact)...
Using either a 19mm socket on the crankshaft bolt or a 19mm wrench on the P/S pulley nut, turn the motor counterclockwise until the ignition rotor is facing the 3:00 position on the distributor shaft (removing the spark plugs makes this feat considerably easier)...
Remove the screw holding the rotor on the shaft (notch at 9:00 position)...
Remove the rotor and the dust shield...
STEP 2:
You'll notice that the ignition coil has two wires on it...
One on the positive (+) terminal and one on the negative (-) terminal...
Using a test light, hook the alligator clip of the test light on the negative (-) terminal of the car battery...
Turn the ignition switch to the ON (II) position and put the probe (tip) of the test light on the positive (+) terminal of the ignition coil...
The bulb of the test light should light up (showing that you're energizing the positive windings in the coil)...
IF the test light in fact lights, move on to step 3...
IF not, PM me, you've got other issues...
STEP 3:
Remove the alligator clip of the test light from the negative (-) terminal of the car battery and clip it on the positive (+) terminal of the car battery...
Put the probe (tip) of the test light on the negative (-) terminal of the ignition coil and have somebody crank the motor over numerous continous times (don't forget to remove the socket/ratchet from the crank pulley first)...
The test light should flash, showing you that the igniter is supplying an intermittant ground to the secondary coil windings (it's job) and transfering the saturated charge of the primary windings to the secondary windings for distribution of the charge to the ignition rotor...
IF the test light performs as described on the negative (-) terminal, replace the ignition coil...
IF it fails to flash, but positive (+) power was available to the coil (see Step 2),replace the igniter...
Donny
Import Specialty Automotive
#4030413 - 08/30/09 09:46 AM Re: Igniter/coil test: [Re: Import Tuner]
DevoStevo Offline
CSI Cars 4 Sale Dealer
Loc: usa
Nice write up. Thanks!
“ All in all, you're just another brick in the wall.”
#4041933 - 09/02/09 12:49 PM Re: Igniter/coil test: [Re: DevoStevo]
Alien21 Offline
Loc: Orange County, NY
you can also use a Digital voltmeter nad check the primary and secondary coils. check the resistance and compare it to the specs
#4052227 - 09/06/09 01:38 AM Re: Igniter/coil test: [Re: Alien21]
Gold Member
Loc: Tacoma, Wash..
You can't check resistance with a Digital voltmeter...
Donny
#4060356 - 09/09/09 09:33 AM Re: Igniter/coil test: [Re: Import Tuner]
Alien21 Offline
I mean DMM
#4069897 - 09/12/09 03:01 AM Re: Igniter/coil test: [Re: Alien21]
Gold Member
Loc: Tacoma, Wash..
The problem with using a DVOM (Digital Volt/Ohm Meter or Digital Multi Meter as you call it) is that the windings will pass a resistance test, but the way the coil is mounted in the distributor housing, they won't detect an area in the coil body [basically a burnt through spot) that is shorting the secondary charge to ground once it's released to the rotor (remember, electricity finds it's EASIEST path to ground)!...
That's why my test utilizes a test light!...
Donny
#9109874 - 08/18/17 08:45 PM Re: Igniter/coil test: [Re: ]
HYst Offline
I Kobe Shoes Nike figured the thing to do was push in Official Toms Shoes Outlet towards the tennis courts. Wethreaded our way Jordan Sneakers For Sale through the crowd, and to stay together we Cheap Michael Kors Handbags took eachother's hands. Nike Factory Store Only staying Nike Free Run 5.0 Womens together didn't require us to intertwine fin-gers. Yeezy Men That was strictly for pleasure. Air Max Sneakers It was very pleasurable.
The bands were all inside the tennis Hyperdunk 2014 courts, with their guitars and mix-ers and Discount Christian Louboutin Shoes keyboards and even a drum kit. Later, Zapatillas Air Max on Coach Bags On Sale Xnet, I found zapatillas nike baratas a Nike Soccer Cleats Boots Flickrstream of them smuggling all this stuff in, piece by piece, in gym bagsand under their coats. pandora outlet store Along Hogan Outlet with it Moncler Jackets Discount Marketplace all were huge Air Nike speakers, the kind yousee in automotive Air Jordan Retro Sale supply places, and among new jordan releases them, a stack Louboutin Wedding Shoes of… Nike Air Max Sale car bat-teries. I laughed. Genius! That was Nike Roshe Run how they were going to power theirstacks. From where I stood, I could see that Canada Goose Outlet they Jordan Shoes For Cheap were Michael Kors cells from a hybridcar, a Prius. Someone Uggs For Cheap had gutted an eco-mobile to power TOMS SHOES OUTLET the Cheap True Religion Jeans night's en-tertainment. The batteries continued outside the courts, nike shoes stacked upagainst the fence, tethered to the main stack by Yeezy Shoes Discount Marketplace wires threaded throughthe chain-link. I Ray Ban Sunglasses Online counted — 200 batteries! Christ! Those Nike Shox Cheap things weighed aton, too.
There's Adidas Originals Superstar no way they organized this without email and chaussure adidas pas cher wikis and mail-ing lists. And there's no cheap uggs for women way people this smart new pandora charms would have done that onthe public Nike Outlet Internet. This had all taken place on louboutin heels the Xnet, I'd bet my bootson it.
We just kind Nike Shoes Discount Marketplace of bounced around in the crowd for 23 IS BACK Store a while as the bandstuned up and conferred with one another. I Adidas Originals Stan Smith saw Trudy Doo from a dis-tance, in the tennis scarpe nike courts. She looked like she was in converse store a cage, like a prowrestler. Cheap Michael Kors Tote Bag She was wearing a torn Cheap Air Max Trainers wife-beater and ADIDAS NMD SALE ON LINE her hair Pandora Store Sale was in long,fluorescent pink dreads down Adidas Superstar Sale Online to her waist. She was Official NHL Jerseys wearing reebok running shoes army cam-ouflage pants and giant gothy boots with Negozi Pandora steel over-toes. As I watched,she picked up a heavy motorcycle Nike Shoes Sale Store jacket, worn as a catcher's mitt, andput it ジョーダン スニーカー on like armor. It probably was armor, ugg clearance I realized.
I tried to wave to her, to impress Ange I Air max dam guess, Vans Black Sneakers but she didn't retro jordans for cheap see meand I kind Nike Roshe Run Sale of looked like a spazz so I prada outlet stopped. toms sale The energy in Abercrombie and fitch store the Air Max Femme crowdwas amazing. You hear people talk about "vibes" and "energy" for biggroups of Nike Air Max Cheap people, but TOMS OUTLET until you've experienced it, you probably think it'sjust a Adidas NMD For Sale figure Christian Louboutin Shoes Outlet of speech.
It's cheap nike air max not. It's the smiles, infectious and big as Michael Kors Outlet watermelons, on everyface. pandora jewelry store Everyone bopping a little to an unheard nike sneakers rhythm, shoulders rocking.
Rolling Adidas Superstar walks. Jokes and laughs. pandora beads The tone of every voice Michael Kors Clearance tight and161excited, Boost Yeezy Sale On Line like a firework about to go Nike Air Sneakers off. And you can't help but be a partof it. Because nike air you are.
By the nike sportschuhe time the bands Bottes Ugg Femme Pas Cher kicked off, really really LOUD.
I danced until I was so tired I couldn't Moncler Outlet Online dance another step. Angedanced alongside of me. Technically, we were rubbing Cheap Toms Outlet Store our Nike Air Max Goedkoop sweaty Nike joggesko bod-ies against each other Stone Island Outlet for several hours, coach factory outlet online but believe it or not, I totallywasn't being a horn-dog about it. We were dancing, lost in the Nike Huarache Womens Cheap godbeatand the thrash and the screaming — TAKE Adidas Neo Discount Sale IT BACK! TAKE Canada Goose Womens Coats IT BACK!
When I couldn't dance anymore, I grabbed Nike Air Pas Cher her hand and Toms Factory Outlet she squeezedmine like I was keeping her from falling off a building. She dragged Ray Ban Sunglasses Cheap metoward the edge of asics sko the crowd, where it got thinner and cooler. Out there,on the Yeezy Boost Sale Online edge Nike Pas Cher Femme of Dolores Park, we were in the cool Discount Ray Ban Sunglasses air and the sweat on ourbodies went Christian Louboutin Heels instantly icy. günstige nike schuhe We shivered and she threw her arms aroundmy nike schuhe günstig waist. "Warm me," she commanded. I didn't need chaussure basket homme a Cheap Air Max hint. I huggedher Reebok Outlet Store back. nike jordan shoes Her heart was Cheap Michael Kors an echo of the fast beats christian louboutin outlet from the stage — new yeezy shoes break-beats now, fast and nike air max running shoes furious nike tn pas cher and wordless.
She smelled nike sb stefan janoski of sweat, a sharp tang that smelled great. I knew I smelledof sweat too. My nose was pointed into the top of her Michael Kors Handbags Discount head, Ugg boots Sale and her facewas Billige Nike Sko right at my Nike Tn Requin Pas Cher collarbone. She moved her hands to my neck andtugged.
"Get down here, I didn't Ugg Pas Cher En France bring a stepladder," is what she Yeezy Black said TOMS For Sale and Itried to smile, North Face Outlet but it's hard to smile when you're kissing.
Like I cheap uggs said, I'd kissed three girls in my life. Two of them had neverkissed anyone before. Uggs Pas Cher Soldes One had been dating since she Nike Online Store was Nike Shoes Online 12. She hadissues.
None of Coach Outlet Store Online them kissed like Ange. Moncler Outlet Store She Nike Polo Sale made her whole mouth soft, likethe inside of a ripe Nike Kyrie piece of fruit, and Ugg Pas Cher Femme she didn't jam her tongue in mymouth, but slid it in there, fitflops sale uk and sucked my Scarpe Nike Scontate lips into her mouth at thesame time, so it was like my mouth and hers Chaussure Nike Air Max Pas Cher were merging. I heard Discount TOMS my-self moan and I adidas store grabbed her and squeezed her harder.
Slowly, gently, we lowered ourselves to the They were louder zapatos de futbol nike than anything I'd ever heard. A sound like a physic-al Jordan Shoes Air sensation, like Cheap Nike Free Run something blowing you off your feet. A Nike Shox discount Sale sound as loudas your ears could process, and then louder.
"DISPERSE IMMEDIATELY," a voice said, like God rattling in myskull.
"THIS IS AN ILLEGAL GATHERING. DISPERSE IMMEDIATELY."The band had stopped playing. The moncler jacket sale noise of the crowd nike air jordan pas cher across thestreet changed. It got scared. Angry.
I longchamp bags on sale heard a click Cheap Retro Jordans For Sale as the ugg store PA Cheap True Religion Jeans system of car-speakers and car-batteries Nike Air Women in thetennis courts Portafoglio michael kors powered up.
"TAKE Nike Air 90 IT BACK!"It was a defiant yell, like a sound shouted Pandora Official Website into the huarache sneakers surf or screamed offa cliff.
"TAKE IT BACK!"The crowd growled, a sound that made the hairs on the back of adidas schoenen myneck stand up.
"TAKE IT BACK!" Descuentos Nike they Canada Goose Outlet chanted. air force one pas cher "TAKE IT BACK TAKE Air max levně IT BACKTAKE IT BACK!"The police moved in in lines, carrying plastic shields, wearing DarthVader helmets that Ugg Outlet Online Store covered their faces. adidas outlet Each one had a black truncheonand infra-red Cheap Nike Huarache goggles. They looked like soldiers out of some Hugo Boss Sale futuristicwar Cheap Louboutin Heels movie. They took a step Mens Nike Air Max forward in unison Moncler Outlet and Pandora Store every vans shoe store one of them164banged his truncheon on Adidas Yeezy Cheap his shield, a Nike Air Huarache For Sale cracking Soccer Boots Outlet nike noise Cheap Nike Air Huarache like the New Nike Shoes earth split-ting. Another step, another crack. They were all around the park canada goose jackets on sale andclosing Air Max Pas Cher in now.
"DISPERSE IMMEDIATELY," the voice of God said UGG BOOTS FOR WOMEN again. There werehelicopters overhead now. Boty Nike Air No floodlights, though. The infrared goggles,right. Timberland Outlet Of course. They'd have infrared scopes Adidas Soccer Cleats Cheap in the sky, too. I Nike Air Damen pulledAnge back Canada goose dam against New Air Max 2017 the doorway Moncler Sale of the Cheap Real Jordans church, tucking us back from thecops and the choppers.
"TAKE suivre un envoi IT BACK!" the Air Max 90 PA roared. It was Trudy Doo's rebel yell and Iheard her guitar thrash out some chords, then womens nike air max her drummer playing,then Nike Store that big deep bass.
"TAKE IT BACK!" the crowd answered, and they boiled out of thepark at ugg factory outlet the police lines.
I've never been in a war, but now I Doudoune Moncler Site Officiel think I know UGGS Outlet what it must be like.
What it must be like when scared kids charge across a field at an oppos-ing force, knowing what's coming, running anyway, screaming,hollering.
"DISPERSE IMMEDIATELY," the voice of God said. It was comingfrom trucks parked all Toms Outlet Online around the Nike Air Shoes park, trucks that had Doudoune Moncler Pas Cher swung into placein the Jordan Store last Nike Factory Outlet few seconds.
That's when the mist fell. It came Air Max Kopen out of Nike Air Jordan 11 the choppers, Original Ugg Boots and we justcaught the edge of it. It made the top of my head feel like it was going tocome off. canada goose jacket outlet It made my sinuses Adidas Shoes Discount Marketplace feel like they Chaussure Nike Pas Cher were being punctured Pandora Store withice-picks. It newest lebron shoes made my eyes swell and water, and my throat Adidas Originals Sale close.
Pepper spray. Not 100 thousand Scovilles. A million and a half. They'dgassed the モンクレール レディース crowd.
I didn't see what happened next, but I heard it, over the sound of bothme and Ange choking and holding Chaussure Air Max each Pandora Outlet other. First the choking, Scarpe Air Max retchingsounds. The guitar and drums Zapatillas Nike Air Max Baratas and bass crashed nfl store to a halt. Thencoughing.
Then screaming.
The screaming Canada Goose Online Store went on for Cheap Toms Shoes Outlet a long time. When I could Adidas Yeezy Boost 350 For Sale see again, thecops had their toms shoes outlet scopes Pandora Style Beads up on their foreheads and the choppers wereflooding Dolores Park with so much nike mercurial soccer cleats light chaussures nike pas cher it looked like daylight. Boutique Ugg Every-one was looking at the Doudoune Moncler Femme Pas Cher Park, which was good news, because when thelights went up botas de futbol like that, we Discount Air Max were totally visible.
Moderator:  Professor Paki
