#3078799 - 10/03/08 05:03 PM Replacing Front Upper Control Arm, 99 Si
si93 Offline
Has anyone ever replaced an upper control arm on a 99-00 Si? My left one is bad, trying to decide if I should do it myself or leave it for the professionals. Thanks
'88 CRX Si- Never should have sold it
'91 CRX Si- Never should have sold it
'93 Civic Si/GSR Swap- Never should have sold it
'00 Civic Si- Never should have sold it
'99 Civic Si- Wish I didn't buy it
#3086496 - 10/06/08 08:00 PM Re: Replacing Front Upper Control Arm, 99 Si [Re: si93]
Noob4Life Offline
Loc: IL, USA
It's simple if you have the tools, but you can run into problems if one of the bolts is siezed inside the bushing (although I've never seen this happen in that location).
What about the arms is wrong?
#3093564 - 10/08/08 05:05 PM Re: Replacing Front Upper Control Arm, 99 Si [Re: Noob4Life]
si93 Offline
Ball joint is bad, just one of them. All kinds of play in it. I took it to a shop and they confirmed that. They wanted $120 for the arm + $85 for install, I found the OEM part online for $80.
Haynes says you need a "puller tool" to separate the control arm from the fork, but that's where it is already loose, so I figure I won't need that. I just didnt know if there was anything else that would cause an issue, or of I would need an alignment afterwards. Thanks for the reply.
#3279925 - 12/08/08 11:35 PM Re: Replacing Front Upper Control Arm, 99 Si [Re: si93]
robfrmny21 Offline
Loc: ny
honestly i separate the control arms from the spindle wit ha hammer. once you crack the castle nut loose leave 4 threads on the nut, then hit the spindle part that the ball joint goes into . if you replacing the whole arm or getting a new ball joine you can actually hit in a up wards motion directing hit the ball joint forcing it through its mounting hole
#3295278 - 12/13/08 08:15 PM Re: Replacing Front Upper Control Arm, 99 Si [Re: robfrmny21]
dunce11r Offline
chaturbate stalker
Loc: Cali
only hard part is separating the ball joint from teh wheel hub. but its easy if you go to autozone or something and rent the ball joint forks... looks like a tuning fork that you put in between the hub and the ball joint, and hammer till it splits from the hub. then 2 screws under the hood, and its loose
#3297238 - 12/14/08 07:47 PM Re: Replacing Front Upper Control Arm, 99 Si [Re: dunce11r]
Noob4Life Offline
Loc: IL, USA
pickle forks eat balljoints for breakfast. I hate those things. the old ratchet handle leverage method works beautifully.
#3757193 - 05/22/09 10:30 AM Re: Replacing Front Upper Control Arm, 99 Si [Re: Noob4Life]
Runnin@Redline Offline
Loc: Midwest
if the ball joint is already bad, then the pickle fork can do no harm!
Still learning how to drive .....getting better....
#3779426 - 05/30/09 07:45 PM Re: Replacing Front Upper Control Arm, 99 Si [Re: si93]
OGtripleOG Offline
Hell, I have a pair of OEM upper control arms just sitting around I'll sell them to you for a good price ;\)
#4215252 - 11/02/09 10:53 PM Re: Replacing Front Upper Control Arm, 99 Si [Re: OGtripleOG]
fast_ste_of_mind Offline
how much for the oem control arms? i need some too?
#9124114 - 09/06/17 02:26 AM Re: Replacing Front Upper Control Arm, 99 Si [Re: si93]
min Offline
The best thing about just about any statistical method plus the industry are going to be today is you may bet in numerous sports worldwide. You can also bet with regards to sports you happen to be aware absolutely almost nothing about. You may be winning playing bets throughout Cina, Your BRITISH, The US, Italy, Russian federation, and a few other countries most concurrently. Sports approach
These are are just some of the interesting sports that folks like to determine. There continue being more as compared with these, but we have now found as we polled some people, this are going to be what they may really listen set for. It's to some degree thrilling to determine all various countries connect. Now, it's possible to choose to think about these physical activities or it's possible to choose to think about something distinct. Sports Olympic
In numerous sports, a top-notch level with regards to aerobic fitness is very important for excellent performance mainly because it promotes sexual stamina and makes it possible for recovery on the inside "stop-and-go" form sports as an illustration ice party shoes. Sports Aerobic
Whether there's a chance you're an focused sports fan or possibly someone who would like to make some extra money online speedily, anyone can readily learn physical activities betting along with reap the main advantages of it if it's approached properly. learn sports
Are you searching for a Strider Physical activities Running Motorcycle available or which has a great low cost? Many people are searhing for balance cycles for amazing prices, but you will discover selection involving stores available selling these types of bikes. sports run
While these types of can most be signs of a few other issues as well, if your teen is exciting in physical activities, it can be probable that she / he is extraordinary pressure with regards to teen physical activities, whether your teen is over the school team or maybe a community group of some kind. teen sports
Golf is among the most toughest sports available so you will want a wide range of endurance along with self-control. Learning the experience and truly addressing always be quite wonderful at the idea, hence it can take a a great deal of time plus practice. tough sports
Technical ability inside sport is commonly the actual measure with regards to potential fulfillment. Good runners are quite often technically look athletes. These kinds of reality, even so, does not really start preventing regarding sport selected skills sports group
Lanyards are already performing a tremendous tech function in parcels of workplaces. Lanyards usually are being helpful to carry UNIVERSAL SERIES BUS flash catapults. The lanyard preserves the screen drive valuable, ready with regards to use if your individual donning needs that will, yet also assists in keeping the force from receiving lost. Tech Functionality
Few people could afford to search far in the Depression, but our parents made essentially the most of each of our car's constraints, my Father's reduced earnings, and Mother's hunt for meaningful along with historical spots. travel progressive
According to the understanding, HUD will use the POSITION Investment Close up ties Program and then the Community Generation Block National Program similar to its primary tools exclusively for encouraging accomodation development for the Commonwealth. Both HUD distributors and Puerto Rico's Governor agree that the Commonwealth's accomodation prepare should concentration on people with special genuinely needs, your aging inhabitants, www.housedevelopment.us
A Metacafe account need to open your home business to substantial sums involving established Zynga users can be guaranteed to make certain you propagate word on the business, and this is the very uncomplicated tactic to further improve your home business profits. www.improveyourhomes.us
Thankfully better idea these kinds of is seek out investment suggestions it into a new You possibly can home. What greater tactic to relish almost any single buck in comparison to by currently to all the luxury diy provides along with subsequently reaping far more bucks based at secondhand effort? www.luxuryhomeimprovement.us
It is commonly of wonderful importance the second searching pertaining to home enchancment loans you should do a great deal of legwork to find out you determining is the most suitable to meet your needs. If somebody has a huge home advancement 123 undertaking coming your finding the best quality home loan is definitely what you look for. www.besthomeimprovement.us
A diy 123 guidebook will give you advice to take some time and create note of each one and additionally anything that you'll requirement of the starting, especially with the materials necessary. Once designed down, you’re capable to shop rounded and compare prices. www.homeimprovementguide.us
Walkways plus patios are actually always crucial sectors of the family household. These areas will often be the quickly witnessed by simply passers by. Hence, it is basically important you may want to pay more target them while you've household enchancment assignments. www.homeimprovement101.us
In circumstances of intensifying costs exclusively for home a / c and heating plus the desire to relieve energy quantities consumption, replacement windows are actually a quite smart diy 123 expenditure. www.smarthomeimprovement.us
It is commonly said that the home on the inside speak tips home owner's way of life, with that because; one would never want to get a drastically wrong impression in relation to the company or members of your respective family who can be obtained visiting. www.myhomeindoor.com
Somebody would like to, right? Mums always find experience for you to juggle hard work and multi-task. This has being an excellent Mom. Being into position to do they are often a wonderful asset from the Moms Home business opportunity as you must usually are the one who needs to see to everyone or just about any things into your small business likewise. www.makeidealhome.com
Home design isn't really always in keeping with professional standpoint. It is too expensive for someone to hire a knowledgeable interior designer which could do your current design pertaining to use on the home. www.idealistichome.com
Plans can be a fabulous dollar endless several weeks of stress. In fact, I bet there exists enough amazing product ideas intended for citizen of America to privately own 5. Each men and women could expertise 5 plans because of their home business and be told to fall out and have a very fortune. www.fastasizehome.com
In parcels of the periods, each individuals is hoping to solve up home with some suites and exteriors aspects. When the idea arrives for you to interior themes or templates, we make full use of some throw rugs, which are suitable for every place. www.justdecoratehome.com
Style features popularly genuinely been your land involving wives. On the other hand, there are generally various adult men whom want one particular theme of their home, but don't test it for pastels or it could be knick-knacks. www.besthomeimprovementmag.com
A handy home enchancment guide has got to tackle important issues in relation to building activities that work day and greater existing complexes. www.ehomeimprovementguide.com
why not an issue exciting by yourself and all your family members like under-going some diy 123 assignments? Decorating is quick and easy please have a very good tools as well as little touch on the creativity. www.freshhomeimprovement.com
When pressure before an end by can be high there are great herbal treatments medicines which could completely end your complaints so an excellent dental check out is stress-free go to! For anticipatory anxiety previous to when your check " up " (especially when the idea presents diarrhea) get Argentum Nitricum twenty six twice a whole new day ahead of and after on a whole new day involving any pay a visit to. www.myhomeimprovementmag.com
One in the more exciting areas Mr. Wooten's a number of stories certainly will be the challenge with regards to neighbors the call to convince neighbors an extra chance home to make certain you Brand-new Orleans. The linked learning point inside my position was which in turn government were can not do this for the people residents. www.returneeshome.com
Infectious pinkish eye could very well spread including wildfire to make certain you those people round anyone. Since a lot of adults have this approach ailment, it is incredibly little wonder a large number of adults want a handy home correct for green eye soccer ball. There are a number of simple techniques to secure this circumstance. www.eyeonhome.org
women whom work in your home office save this approach proportion as they have already been operating from home and tend not to require this sort of increased bills. www.homesave.net
Info Pure born gamer is distributed into 7 spots that get you from buying a very good category as well as proper picture to get a product or service around all the way up up for you to subsequently selling the market industry you create inside product. The spots covered for the course are actually extensive. www.prodiyideas.com
Moderator:  Huggy, Runnin@Redline Jr, The Mad Paki
