#3499186 - 02/20/09 09:22 PM
Re: what are the cheapest, most effective upgrades?
[Re: Fratt3]
MiataOwner
FUCK YOU!
Loc: Walking in Memphis...
Cheapest and most effective? Learn to drive.
Seriously, you could sit there and throw parts at it all day, but if you're running mid-15's with an EM1 with all those parts, then you're pretty much hanging with a huge pile of stock Si's that could do the same. Unless you live a mile above sea level, there's probably a 14-second timeslip in that car somewhere if it had a good driver.
Want continued cheapness? Remove weight. Gut the interior from fore to aft, leave only the driver's seat and the dash. Go to the drags on a 1/4 tank of gas (or less) and take a full 5-gallon jug of gasoline. Remove the jug and race, there's another few dozen pounds.
Wanna keep going? Go buy some 13x9 steelies with some psycho offset and some drag radials -- just for the front. The overall smaller diameter of tire will effectively lower your gearing, which means faster acceleration. The far-enhanced grip can potentially reduce your 60ft times by a half second or more, depending on how crappy your current launches are.
Now, you've got a 14-second monster. Granted, it probably wouldn't do that on the streets, but since you're mentioning drag race ET's, then I only provided options that were specific to drag racing.
Nope!
#3629922 - 04/07/09 12:41 PM
[Re: Fratt3]
cruzersi99
14 flat in an em1 with a b16 isn't easy to do. Even with a good driver and a beast of a motor.
Removing weight is always a good idea, as well as gearing (careful here though as changing your gearing too much may result in an un-needed shift).
Even with 2.1 60s you're going to need approximately 200whp with a wide (well wide for a b16) powerband.
186 whp - Church Automotive (Dynapack) 189 whp - Zero Factory (Bosch)
#3631031 - 04/07/09 05:13 PM
[Re: cruzersi99]
supercivic00
Loc: glen burine md
just add some gas 2 that bitch n a vafc to rich it up so u dnt blow it up
#5028291 - 09/12/10 01:44 AM
[Re: supercivic00]
Boostd4
Loc: Bay Area, CA
Kinda reminds me of the old phrase "Cheap, Fast, Reliable...pick two".
14s are hard even in the old GSRs. After spending some time with boosted cars (3 Evos, 1 Audi S4, and 1 FC RX7), forced induction is the best way to go fast. Now, I'm not into car bowling at all...but as a few of the guys above said, remove weight and practice. I can't say that will get you a flat 14, but I do know that my 3200lb street trim Evo 9 with 305whp/318wtq did low 13s the one time I took it to the Infineon Raceway drags, and that was without hard launches.
Now, having driven the EM1 around for the past two weeks I can't imagine this car hitting anywhere near a flat 14 without some power adders or at least a well built NA motor. Back when I had my 96 GSR, I STRUGGLED to get into the 14s...and that was with a mostly gutted interior and the basic bolt ons.
Edited by Boostd4 (09/12/10 01:46 AM)
1999 EBP Si Comptech Stainless Header/Type R Front Brakes AS Evo 9 SE Haxxxored by Bryan@GST 361whp/324wtq 91 octane CBRD/ARP/MAP/Walbro/Mil.Spec/FIC/Nisei/Perrin/Kelford/Supertech/GReddy
Moderator: Runnin@Redline Jr, Dr. BrokenLimits, The Mad Paki
