#2820810 - 07/14/08 05:00 PM Need some polishing advice...
Kmac Offline
Loc: Ft. Bragg
I posted this on Autopia last night, but received a limited response, so I'm asking here as well. Pic of swirls before polish at bottom.
Recently I ordered a PC 7424 with a bunch of pads, P21S, Sonus, Klasse and towels. After having read many many threads on Autopia and watching numerous 'how to' videos for the PC on youtube, I decided to get to work on my mothers FJ Cruiser, to try out my new stuff. It had never seen wax and was washed very sparingly.
Degrease- check.
2 bucket wash- check.
claybar- check.
wash again- check.
At this point I get out the PC and as seeing the paint had swirls (but not major swirls to my mind) I opened up the Sonus SFX-2 that I had ordered and started to mimic the youtube instructions. Using an oragne CCS pad I spread it, worked it, broke it down and removed it.
Even though the finish was indeed 'glossier' and smoother, swirls still remained. So I repeated the process and it did not improve. Disgruntled, I threw a quick coat of wax on the FJ and called it a day.
Earlier today I decided to detail my car.
P21S total auto wash, P21S wheel gel, 2 bucket wash, Sonus green clay, wash again. My car is a 2007 Nissan with slightly moderate swirls (less than the FJ had) so I figured I'm in good shape to use the SFX-2. After applying it the swirls are still evident (although reduced). Again I repeat the process but it does not help. What REALLY didn't help was the fact that it was about to storm at this point and I panicked and threw some Klasse AIO on for a temporary protectant.
So here I am, debating whether or not I need the SFX-1 (paint isn't oxidized or old) and if I do need a more aggressive polish, can I use it even though I just put the Klasse on?
Thanks for reading, hopefully I'm not making this more complicated than it needs to be.
Swirls before attempting to remove:
#2821815 - 07/14/08 10:03 PM Re: Need some polishing advice... [Re: Kmac]
You can always use a polish over a sealant, it will just take it off. Im not familiar with the Sonus brand of things, but you do know that using a harsh polish and a rough pad actually causes swirls (microswirling) which needs to be removed by using a less harsh combo. Think of it as sanding a piece of wood. You dont start with 100 grit and then be done with it for a smooth finish. You have to work your way to 1000+ grit for it to be wicked smooth, and the same applies to polishing, you have to work your way down.
#2822433 - 07/15/08 03:06 AM Re: Need some polishing advice... [Re: 2000CheetahStud]
SD91RS Offline
Loc: Bakersfield, CA
I think that SFX 3 or maybe even their paintwork cleanser would work pretty well for your situation.
#2824508 - 07/15/08 08:12 PM Re: Need some polishing advice... [Re: SD91RS]
Kmac Offline
Loc: Ft. Bragg
Good point about working up to a finer polish, however the SFX-2 is equivalent to Poorboys SSR1, so I don't think it's leaving anything behind. As for the SFX-3, that is non abrasive and you can't use that with Klasse AIO, which I plan on using. I'm thinking hitting it with SFX-2 on an orange pad, then going over it again with SFX-2 using a white pad. Then apply the Klasse AIO (which is a micro polish) with white. Meh, what a pain.
#2824623 - 07/15/08 09:04 PM Re: Need some polishing advice... [Re: Kmac]
SD91RS Offline
That should probably work fine.
Welcome to the wonderful world of car detailing!
Sometimes I wish I never logged on to Autopia.com...lol
#2826442 - 07/16/08 01:03 PM Re: Need some polishing advice... [Re: SD91RS]
I have the Sonus SFX1 and 2 and wasn't that impressed with them... Honestly I'd try poorboys SSR2.5 and SSR1 (orange pad for 2.5 and white pad for 1) and see if you get better results.
#2834555 - 07/18/08 08:30 PM Re: Need some polishing advice... [Re: PurduinaSi]
Kmac Offline
Loc: Ft. Bragg
Sadly, I think I'm going to have to do this. I just tried SFX-2 with orange, then again with white and I still have some swirls and whatnot. Ugh, I've spent so much fucking money lately, I think I'm just going to finish up the SFX-2 on the rest of the car, then get some Klasse on it till I have some extra dough to buy the Poorboys.
On a side note, my paint has a shitton of little tiny circles all over the place. Really small, but when viewed in light you can see them, along with the leftover swirls.
#2835000 - 07/19/08 01:20 AM Re: Need some polishing advice... [Re: Kmac]
Just out of curiosity...... what are you using to remove the polish after you break it down with the buffer?
#2835247 - 07/19/08 08:09 AM Re: Need some polishing advice... [Re: PurduinaSi]
Kmac Offline
Loc: Ft. Bragg
I've bought some Sonus der wunder polishing towels and some Sonus der wunder buffing towels. I basically bought all new microfibers before I started this time.
#2837278 - 07/20/08 10:41 AM Re: Need some polishing advice... [Re: Kmac]
04silvrSI Offline
Loc: NY
I think your on the right track with the poorboys. You might also want to try xmt from Pinnicle. Take a look over at Autogeek.net, they are having a sale this weekend.
#2838963 - 07/21/08 08:49 AM Re: Need some polishing advice... [Re: PurduinaSi]
Thats exactly how I roll.
I have 3, 2.5 and 1.
Orange pad on w/a higher speed ~5 and microfiber off, clean towel with each stage.
Works wonders.
