#2766221 - 06/26/08 09:37 AM The day has come gentlemen...[moar pics]
SiAdam Moderator Offline
As of yesterday 6.25.8 I am the proud new owner of an 05 Black Berlina S2000 w/black interior w/47k on the clock.
It is completly stock sans an AEM intake, also came with a tonneu cover, upgraded speakers in the doors and some in the headrest, has a front OEM lip which as well.
The Si will be sold to my cousin (mastrcobb) the same one who helped me work on it in the past...he is taking ownership Saturday..he will be in town for a week, then taking it back cross country with him.
He is dead set on getting that 10.9 timeslip for me...
I'll still have plenty of pics/vids to post up about it, and I'm not going anywhere.
I will always be SiAdam b/c that is where it started...and of course still hanging out here.
Plans for this new car is of course to boost it..b/c it's slooooow, unless you rape it everygear..then it's actually quick..but I miss my snail already..so hopefully by Spring I'll have a new setup.
Pics to come as I get them uploaded and the thing wax/polished/buffed.
There are a few reasons I choose the 05. I was originally set on an 04 b/c there are no differences between the 04/05 but I got a deal on this so I grabbed it.
Here are the differences between 00-03 S2K's and 04-05 S2K's. Worth reading imo, cool some of the stuff they added/changed.
Only downside imo is the rev limiter to 8200, but the Si started there and it's back to 9k..I'll do the same with this...so no worried there..lol.
Model Year 2004
(Second generation S2000).
ENGINE
To improve torque output, Honda engineers stroked the all-aluminum four-cylinder 6.7mm to deliver another 160cc of displacement and a slightly undersquare configuration. By Honda's measurement, there's still 240 hp at your command, only it arrives at 7800 rpm, some 500 rpm lower than previously delivered. This is because the increase in piston speed from the long-stroke layout would stress the internals to the breaking point at a higher rpm. It's one of those physics things.
• Redline dropped from 9000 RPMs to 8000 RPMs.
• F20C engine code changed to F22C ( 2.2 liter) in North America market; the F20C (2.0 liter) remains in production elsewhere. Reportedly Greece gets the F22C too with engine code designation F22C1.
• Through the use of a longer stroke (increased to 90.7mm from 84mm), the motor's displacement was increased from 1997cc (2.0L) to 2157 cc (2.2L).
• Basically a 500rpm shift of the horsepower curve (to the left, on the rpm scale). Thus the new motor makes the same power as the older F20C, simply 500rpms sooner at basically every point on the curve.
• Compression has been bumped up a tenth of a point to 11.1 (from 11.0:1) and the valve timing has been altered to enhance mid-range performance.
• 240hp at 7800 rpm (vs 240hp@8300 rpm) and 162 lb-ft @ 6500 rpm (vs 153 lb-ft @ 7500 rpm).
• This will improve oil consumption and reduce piston noise, Honda improved the cylinder machine honing process by bolting a dummy head to the block (a technique used in race engine building) to improve accuracy. It results in reportedly less than 25% of the deformation on a block.
• The enlarged displacement results in a 6-10% improvement in horsepower and torque from 1000 to 8000 RPMs. Honda claims at the normal operating range of 4500 RPMs the 8 ft-lb torque increase in real world driving translates to 15 ft-lbs over the prior years engine.
• Continues to use traditional VETC instead of iVTEC as on the K-series motors.
• highway gas mileage dropped 1 mpg
• Honda claims better acceleration in each gear, offset only slightly by the reduced top speed potential in each gear (in the older car, thanks to the slightly taller gearing and extra rev capacity, you're able to hold a gear a bit longer, resulting in better acceleration during that brief period where the '04 must up shift while the '00-'03 is able to remain in the lower gear).
• Throttle pedal travel was shortened and pedal effort increased. By reducing the diameter of the throttle body drum, pedal effort is increased approximately 10% at the completely shut end, and 6% at WOT. This was done partly to reduce the occurrence of accidental throttle input such as when the driver encounters a road undulation. Accelerator pedal travel was shortened by approximately 10mm.
• The '03's pistons whiz at 4906 feet per minute at 8900 rpm, whereas the '04's slugs rip along at just 4761 feet per minute at 8000 rpm.
TRANSMISSION
• A tighter secondary gear reduction ratio (1.206 vs 1.16) to provide a bit more snap off the line and to better match the characteristics of the new motor. This is also called the intermediate ratio and is the gear after the transmission and before the driveshaft. It goes like this: Crankshaft --> clutch --> transmission (gears 1-6 + R) --> intermediate ratio gear --> driveshaft --> rear diff --> axles
• 4% shorter ratios for 1st through 4th gears while the 5th ratio is effectively 1% shorter and 6th is effectively 2% longer, for a slightly more relaxed cruise speed. 5th gear ratio changed from 0.971 to 0.942. 6th gear ratio changed from 0.811 to 0.763.
• Carbon fiber synchromesh replace the solid brass ones for all gears except reverse. The new design features a brass ring with a carbon fiber element bonded on the inner surface, resulting in simplified mechanical components, increased synchronizer capacity, improved abrasion resistance, and reduced weight. The weight reduction and increased capacity translates to a smoother and quicker shifting feel. Further enhancing shift feel quality is a reduction in the load acting on the disc spring. Per Honda, this tweak results in reduced shift knob operational load and reduced harshness.
• transmission case rigidity improved
CLUTCH
• Redesigned clutch and clutch case.
• To reduce the "impact torque" of a high rpm clutch dump, the new clutch has an additional orifice at the sleeve cylinder, which reduces the torque reaction acting on the drivetrain, in effect a clutch delay system.
• The clutch case has incorporated additional rib reinforcements to reduce vibrations and noises generated by the drivetrain. The additional ribs have improved clutch case rigidity by approximately 10%.
DIFFERENTIAL
• Redesigned differential; it has been beefed up.
• By moving to an FCD material (from FC), the case rigidity was improved by 40% while the overall case strength was increased 20%.
• Gear fatigue resistance improved by 5% through a change in the shot peening method for the drive pinion gear.
SUSPENSION & STEERING
• Front spring rates increased by nearly 7%
• Rear spring rates were softened by roughly 10%.
• Shock damper rates have been adjusted accordingly.
• Front stabilizer bar is unchanged.
• Rear stabilizer bar was reduced in diameter by 1.8mm to 25.4 mm to improve bump steer & cornering.
• To enhance steering feel and accuracy, the suspension geometry was altered slightly, lowering the steering knuckles by 1.5mm.
One owner’s research found the front suspension received a new front upper arm (left side only); some owner’s speculate that was to correct difficulties in setting the camber on that side. There’s a new part number for the self lock cam nut and bolt at the lower arm’s adjustment point. There’s a new part number for the front lower arm but no apparent geometry change; it’s thought to be a test spec. There are no apparent changes to the front sub frame. The rear suspension received a new knuckle and they moved the mounting point for the control arm. The bushing for the upper arm now has a separate part number; previously it bundled with the part. The tabs for the rear upper arm in rear sub frame have a new part number; it could be durability or geometry change. Front and rear hubs remain the same.
• The EPS (Electrical Power Steering) system features an optimized steer response gain, while the software was updated to improve steering linearity and agility. The steering gear ratio was also changed to match the new suspension and tire characteristics. Increased rigidity of the steering gearbox supporting mounts results in improved steering precision as well.
• One of the "features" of the outgoing S2000's rear suspension was its tendency to exhibit bump steer at the limits. Honda's engineers have attacked this issue from several angles. Rear toe in was reduced from -0deg 19' to -0deg 10'. At a 50mm bump deflection, toe-in has been reduced from -0.19 degrees to -0.05 degrees. Secondly, the rear roll center was lowered from 101mm to 92mm. Honda claims improved roadholding under full suspension compression or during severe body roll situations.
• Honda claims improvements in overall stability, steering accuracy/effort/feel, bump steer characteristics, wet performance/hydroplaning, high-speed stability, smooth ride comfort, choppy ride comfort, and at the limit controllability.
• steering wheel lock-to-lock increased from 2.4 to 2.6 wheel turns.
• steering ratio lowered from 13.8:1 to 14.9:1
CHASSIS
• Chassis code AP1 = MY00-MY03 chassis changed to AP2 with the re-designed bumpers and new headlights / tail lights.
• A new cross brace at the very front of the frame (positioned horizontally, in front of the radiator),
• Reinforcements at key crossmember joints
• Additional fixing points to existing braces
• Reinforcements to the rear wheel arch bulkhead
• Front suspension upper arm brackets were strengthened, further benefiting handling.
• overall weight increase of 25 pounds, from 2810 to 2835 pounds
WHEELS & TIRES
• New 17" wheels, wider in front and rear (by 0.5" and 1.0" respectively), wrapped in wider tires.
• In the front, 205/55R16s were replaced by 215/45R17 tires.
• In the rear, 245/40R17s bumped the incumbent 225/50R16s.
• Honda says both changes are key contributors to extended cornering limits.
• The tires are now Bridgestone Potenza RE050s, replacing the former model's Bridgestone Potenza S-02s.
• The new tires feature a completely different tread pattern, intended to improve the balance in performance between dry and wet conditions.
BRAKES
• To improve fade resistance and stopping power at and near the limit, the brake pad material has been changed from a non-metallic compound to a new metallic compound. The new pad material (Jurid632) provides greater frictional stability in high-temperature operating ranges.
• Master cylinder ratio has been changed from 6.5 to 6.0, resulting in an increased feel of rigidity and "build-up" quality (Honda's term for more stopping power in the latter stage of brake application under constant application). Honda claims less pedal travel is required than previously.
• The ABS system has been improved through the use of split-regulation yaw-control logic for improved stability on split-μμ surfaces when the ABS is triggered. Furthermore, though more powerful than before, the system (consisting of the CPU and modulator) has been downsized for both precious space and weight savings.
EXTERIOR
• new nose job, with wider air intake and new headlights above it
• fake brake opening reshaped and moved inward
• new HID headlights using projector beams
• new LED taillights
• lower appearing rear bumper
• reshaped exhaust pipes, now oval
• spiral double horn unit replaces the current flat double horn.
• new color - Rio Yellow Pearl
• Spa Yellow dropped
INTERIOR
• new combination red and black colored seats
• more sculpted door panel inserts; shoulder room increased by 0.5"
• wave ignition key to make copying it more difficult
• reshaped steering wheel
• new tweeter and mid range speaker housings
• metallic-look trim
• new center console with two beverage holders
• dash changes including a new gauge cluster, reshaped roll where the start button and radio controls are located
• restyled aluminum finish.
FIRST COMPARISON
Sport Compact Car magazine did a road test of the 2004 S2000. They report the 2.2 liter made 210 hp at 8000 rpm at the rear wheels, compared to 203 hp at 8500 rpm that the old 2 liter delivered, and 146 lb-ft of torque at 6400 rpm, compared to 136 lb-ft at 6300 rpm. They go on to say, “Sure, peak power remains the name of the game here, but there's obviously more power than Honda is telling us, and the improved midrange is nice to have around town”. They also did some handling tests and reported the 04 understeered on the skid pad; it registered .89 compared to .92 for the 2 liter car. In the slalom the 04 improved by 1.2 mph to 71.0 mph. They also did some acceleration runs but fried the clutch. 50 to 70 acceleration was faster by .18 seconds, and 0 to 100 is faster by just .2 seconds.
Model Year 2005
Per 9/1/04 Honda press release “There are no changes to the 2005 Honda S2000.”
#2766270 - 06/26/08 09:52 AM Re: The day has come gentlemen... [Re: SiAdam]
99redSiR Offline
Loc: Hamilton Ontario
congrats man.. good buy.. that will defintality be a fun car.. and at least yoyur Si is staying in the family.. so thats always a plus..!!! congrats again.. lets see some pics!
"You either die a hero, or live long enough to see yourself become the vilian"
#2766376 - 06/26/08 10:17 AM Re: The day has come gentlemen... [Re: 99redSiR]
Agreed, I'd have it no other way. Justin is one of the very few that I trust with this car.
#2766434 - 06/26/08 10:30 AM Re: The day has come gentlemen... [Re: SiAdam]
00OldSi Offline
Loc: DC
INLINEPRO kit; 430whp/AEM ems and call it a day!
http://www.inlinepro.com
owner/ friend's silver S2K 530whp
http://youtube.com/watch?v=kMxORk9JzUE
Congrats bro!
#2767195 - 06/26/08 01:19 PM Re: The day has come gentlemen... [Re: 00OldSi]
This thing w/400whp would be hella fun..
I am gonna try to have it boosted by springtime..
You all know me, I can't roll a kit, I'll end up piecing mine together..lol.
#2767304 - 06/26/08 01:40 PM Re: The day has come gentlemen... [Re: SiAdam]
jdmslave Offline
Loc: stl,MO
wow,this came outta nowhere...what made you decide on a s2k?
#2767389 - 06/26/08 01:53 PM Re: The day has come gentlemen... [Re: jdmslave]
Sorta just happened..
I didn't really have anything in mind, just sorta wanted to try soemthing new...was talking with my cousin one night on the phone..he was like..sell it to me..I was like ok..
Then I thought..well I better look for something to replace it..
Found a deal,jumped on it...and the rest is history..all started about 4 weeks ago..give or take a few days..
He is getting a bonus (navyman) and has $$ to spend..so I figure why not..
He knows the car as he helped here and there..has as much or more knowledge about boost than I do. So it will be in fine hands..
Besides he has a track a few miles from his house..so I know it will get some time to run down the 1320..
#2767497 - 06/26/08 02:10 PM Re: The day has come gentlemen... [Re: SiAdam]
jdmslave Offline
Loc: stl,MO
thats cool man...well good luck with the new ride,be sure to post pics soon!!
#2767817 - 06/26/08 03:09 PM Re: The day has come gentlemen... [Re: jdmslave]
Here are some pics..these are taken from the actual 4 sale post.
The pics don't do the car justice. The front lip wasn't on in these pics either.
Enjoy.
I'll have more pics of my own once it's cleaned and detailed..
\:D
#2767896 - 06/26/08 03:24 PM Re: The day has come gentlemen... [Re: SiAdam]
Not funny, Joker Offline
Loc: Florida
I hope there is a bypass valve on that AEM intake...
"Like rosie odonnel at a bi-sexual bridal shower!" - Eli Porter
#2767922 - 06/26/08 03:28 PM Re: The day has come gentlemen... [Re: Not funny, Joker]
00OldSi Offline
Loc: DC
ehhh.... He's in WVA; not too much rain! Tint the windows, add boost... keep everythign OEM ftw! Factory rims in flat black!
#2767929 - 06/26/08 03:29 PM Re: The day has come gentlemen... [Re: Not funny, Joker]
2000CheetahStud Online   nohc
And why are there 06-07 wheels on an 05?
#2768146 - 06/26/08 04:25 PM Re: The day has come gentlemen... [Re: 2000CheetahStud]
jcoosi Offline
Loc: TN
Congrats on the new ride I to have also been thinking about selling my Si.Look forward to the progress you make with the s2k.Good luck
#2769116 - 06/26/08 09:30 PM Re: The day has come gentlemen... [Re: Not funny, Joker]
Meh, my Si never got driven in the rain, neither will this one..doesn't matter anyway..the intake will be up for sale over the winter methinks..
As for the wheels...he traded for those...
#2769904 - 06/27/08 02:23 AM Re: The day has come gentlemen... [Re: SiAdam]
forced00si Offline
Got Boost'r
Loc: the south
congrats on the new Chariot. I have a lust for one of those. It will someday be cured.
almost done...Woot!!
#2773919 - 06/28/08 12:52 PM Re: The day has come gentlemen... [Re: forced00si]
SamuraiSam Offline
Loc: Bellingham, WA
I hear those things are really fun with an AEM EMS, fuel pump, injectors, and a Full-Race turbo kit. 100% stock, I guess they are good at like 450whp levels??? Factory forged internals are bitchin'.
#2773930 - 06/28/08 01:02 PM Re: The day has come gentlemen...[pics] [Re: SiAdam]
drpoopmanchu Offline
Loc: ohio
The car looks nice. I bet that will be a blast boosted.
Will corey be tuning again
B16 Forged-Supertech head-GSR cams-PeakBoost Ramhorn-38mm Tial-Hondata S300-GT3076R .63ar-Precision 600hp FMIC-1000cc-Fullblown Dual Walbro-8an feed 6an return-3" ApexI N1...
500 WHP 350 WTQ @ 26psi on E85 tuned by Corey Parish of Slowmotion Motorsports
#2773945 - 06/28/08 01:11 PM Re: The day has come gentlemen...[pics] [Re: drpoopmanchu]
Ghost Si Offline
Loc: Lake Stevens/Lynnwood/Bellevue
adam, we need some before and after pics of the Si. I wish i would have sold my SI to my brother when he asked for it. Instead this kid blew my motor a week after he bought it.
2000 Si 344whp t3/t4 *SOLD*
2004 audi a4 USP 19" VMR wheels/ milltek high flow cat/milltek exhaust/APR snub mount/koni coilovers
IMPORT SPECIALTY AUTOMOTIVE
(253)473-2606
#2774258 - 06/28/08 05:34 PM Re: The day has come gentlemen... [Re: SamuraiSam]
I've been reading the same thing..thats prolly what I am going to be doing first off...get me back to Si power levels..lol.
Yea, Corey from SlowMo will be tuning again when the time comes along...he picked up a S2K last fall and is working on making it nasty..
I still have pics of my Si on the link in my Sig..and will be getting more from Justin as he gets some track time in and what not..
All is good.
#2774282 - 06/28/08 05:49 PM Re: The day has come gentlemen... [Re: SiAdam]
SamuraiSam Offline
Loc: Bellingham, WA
http://www.full-race.com/catalog/product...8c6197bdc3ed677
You want it...
I guess the rear end is weak and that's about it? I haven't read alot about them. There is a user on this site (owner of Midwest Autoworks) that has a badasss S2k, he would be a valuable resource. 94cxhatch I think.
And that's on a 2 liter.... you need it....
 Originally Posted By: Full-Race Geoff
100% stock motor and stock oem honda headgasket. 11 psi spring (no boost controller hooked up), 91 octane
3" exhaust, AEM ecu
the kit includes everything from brackets, fuse box mounts, manifold, turbo, wastegate, downpipe, intercooler, black aluminum charge piping, inlet piping, oil filter relocator, couplers/constant pressure T bolt clamps, oil lines, vacuum lines, etc [tial 50mm BOV]
the only parts not included, but needed for install are:
-fuel injectors
-fuel pump
-standalone ECU (we recommend AEM or Kpro)
-resistor box (ONLY if low impedance injectors are used)
-battery relocation
Our kit is a more refined and complex kit which includes all brackets (we dont use zip ties to relocate the fuse box and other important things), an oil filter relocation kit, precrimped lines, nice couplers nice t bolts, a long runner merge collector manifold, perfect fitment, very direct downpipe, perfect quality welds you will not need to worry about, etc. If you have no experience with turbocharging street cars, it is difficult to appreciate these things, and they are the things that matter the most. There is a difference.
Edited by SamuraiSam (06/28/08 05:55 PM)
#2776880 - 06/29/08 11:42 PM Re: The day has come gentlemen... [Re: SamuraiSam]
Freakin $6200 bucks..lol..yea right...
I am sure it's nice..but not $6200 bucks nice..
Manifold/turbo/tuning will be 3k. Piece together the other/odds/ends and I will round up to 5k max.
Same thing for less. I can make brackets/etc.
Of course I'll need to beef up the rearend and clutch..but other than that..I think I can do all that for the $$ invested into the full-waste as Shane used to call it..lol.
I've noticed parts for this car aren't cheap, not like buying for the civic...
#2776882 - 06/29/08 11:43 PM Re: The day has come gentlemen... [Re: SiAdam]
Car still hasn't been washed since I got it...waiting on some cleaners/conditioners/etc to arrive.
Was out today a little bit today..snapped some pics @ a car show @ a city park.
#2776918 - 06/29/08 11:55 PM Re: The day has come gentlemen... [Re: SiAdam]
SamuraiSam Offline
Loc: Bellingham, WA
Haha, yeah. I hung out with Shane for a month straight when I was in San Diego in April, he is a cool guy. But, I started buying the more expensive parts, and it has been worth it. More reliability, better fit and finish, and they make more power. Tomei turbo manifolds, HKS turbos, TODA cams. It all makes a difference. I used to be an ultra penny pincher too...
#2776933 - 06/30/08 12:00 AM Re: The day has come gentlemen... [Re: SamuraiSam]
I agree...you do get what you pay for..but I just checked their site and they are charging $500 bucks for an oil filter relocation "kit"...I mean come on?
Btw...where has Shane been...haven't seen him online here in some time?
Tell him to get back on..
#2776955 - 06/30/08 12:08 AM Re: The day has come gentlemen... [Re: SiAdam]
SamuraiSam Offline
Loc: Bellingham, WA
Shane left ClubSi. While I was down there, he got banned for absolutely NO reason. I made a post in OT asking why, etc, http://forums.clubsi.com/ubbthreads.php?ubb=showflat&Board=31&Number=2666588 and OT went to fucking TOWN on him. Donny - Import Tuner, reinstated him, but Shane said fuck it he didn't need to deal with the idiots and hasn't been back since.
Edited by SamuraiSam (06/30/08 12:20 AM)
#2776965 - 06/30/08 12:13 AM Re: The day has come gentlemen... [Re: SamuraiSam]
Shane left ClubSi. While I was down there, he got banned for absolutely NO reason. I made a post in OT asking why, etc, (http://forums.clubsi.com/ubbthreads.php?ubb=showflat&Board=31&Number=2666588) and OT went to fucking TOWN on him. Donny - Import Tuner, reinstated him, but Shane said fuck it he didn't need to deal with the idiots and hasn't been back since.
I didn't know that..
He is always welcome in GB...why doesn't he come back for us..??
#2776975 - 06/30/08 12:21 AM Re: The day has come gentlemen... [Re: SiAdam]
SamuraiSam Offline
Loc: Bellingham, WA
You posted in that thread, man!
#2777865 - 06/30/08 10:37 AM Re: The day has come gentlemen... [Re: SamuraiSam]
lol you are right, I just reread it.
#2858555 - 07/27/08 04:24 PM Re: The day has come gentlemen... [Re: SiAdam]
HCivic02 Offline
Loc: CA
nice s2k. I almost sprung for one before the Evo.
Chris
06' Evo IX - E85@29psi
13' FRS
#2861383 - 07/28/08 04:09 PM Re: The day has come gentlemen... [Re: HCivic02]
AllMyTSi Offline
Loc: New York
TRAITOR !
LoL nah man sweet ride. You will have a lot of fun with that. I miss mine \:\(
R.I.P -Rosemarie Montalbano- Passed Nov. 1999 You are always in my thoughts R.I.P -Margarita Martinez- Passed April. 2000 You will always have this special place in my heart, I Miss You... R.I.P -Brian DeBoer- Passed April. 2000 In our thoughts... R.I.P -Grandma- Passed May 2000 I love you !
#2866210 - 07/29/08 10:22 PM Re: The day has come gentlemen... [Re: AllMyTSi]
jrsi Offline
Loc: Arizona, United States
Well I have to say its sad to see her go. I sold my si just last month to my lil bro... Kind of ironic if you ask me, nonetheless I thought you'd have that thing forever. Now don't laugh but i ended up getting a good deal on an 05 350z. (Couldn't afford the vq35hr)
I'll be anxious to see how this s2k build evolves. Let us know!
Congrats Adam
#2866346 - 07/29/08 10:59 PM Re: The day has come gentlemen... [Re: jrsi]
Thanks guys...I don't consider my Si gone..even though it's on the other side of the country...lol.
It's still in the family if you ask me..
Justin just bought slicks for it, and plans on getting some numbers for us over the next few weeks..
I am more excited about how the Si runs than my new car...
#2888795 - 08/06/08 12:50 PM Re: The day has come gentlemen... [Re: SiAdam]
Buzzbomb Offline
Loc: Bryan, Ohio, USA
Congrats on the S2000. I keep telling myself I need to sell the Si and buy something else, but I just can't bring myself to do it.
I have too much going on right now anyway to spend on a new project car. The wife and I just had kid #2 so little time and money is on hand to put into anything else. The Si gets driven on weekends (sometimes) and it's fun so I'm staying content with that.
Authorized AMSOIL Dealer
00' Si Turbo
02' WRX Wagon XPT Stage2
13' Tribeca 3.6R Limited
