#2341077 - 02/18/08 08:33 PM ZC swap problems
trevino04zero Offline
just swap a DOHC ZC and it wont start and i cant figure out the problem...can anyone shed some light on my problem??? its not the distributor, starter, grounds, fuel pump...all new and check and double checked...
#2343897 - 02/19/08 10:12 AM Re: ZC swap problems [Re: trevino04zero]
Si's_RUS Offline
wont start as in wont roll over?or rolls over but wont fire?check for power to the coil at the dizzy,pwr at the ecu,r u getting spark and no injector pulse, more info would help
#2343923 - 02/19/08 10:13 AM Re: ZC swap problems [Re: trevino04zero]
Si's_RUS Offline
#2358989 - 02/22/08 05:22 PM Re: ZC swap problems [Re: Si's_RUS]
mkjeld76 Offline
Loc: Chattanooga, TN
did you replace the timing belt? If the timing is off just a little it won't start
MR 99 si AEM CAI, DC Sport SS 4to1 Header, RS-R cat back, teg type r intake, Pro-Kit springs with KYB AGX struts.
#2359089 - 02/22/08 05:59 PM Re: ZC swap problems [Re: mkjeld76]
Slurp56 Moderator Offline
Loc: S21
Yeah, thats not entirely true. It will run being a tooth off, but poorly.
#2359096 - 02/22/08 06:01 PM Re: ZC swap problems [Re: trevino04zero]
Loc: S21
How about helping us help you out? Did you put gas it? Does the battery have a charge? Did you turn the key? What symptoms does it give you? You didnt even tell us what car you put this thing into.
#2393776 - 03/03/08 04:40 PM Re: ZC swap problems [Re: Slurp56]
It has gas and the battery is new and i have turned the key and all it does is turn and turn and turn some more then it blows out fire out the exhaust and the swap is in a 89 civic
#2393873 - 03/03/08 05:06 PM Re: ZC swap problems [Re: trevino04zero]
Loc: S21
What's your firing order look like?
and what model is your 89 civic? Is it wired for MPFI and is there an injector resistor box? Any CEL codes?
#2396896 - 03/04/08 11:49 AM Re: ZC swap problems [Re: Slurp56]
Import Tuner Offline
Gold Member
Loc: Tacoma, Wash..
I'm guessing "NOT" 1342 in a clockwise rotation (starting at 7:00)...
Moderator:  Slurp56, The Mad Paki
