#232356 - 04/11/06 02:00 PM
smooth shifting
209_dup2
Loc: Tracy, CA
when i first got my Civic Si about a year ago the shifter would shift real smooth but know its getting harder to shift, i was going try and buy a short shifter but for now i want to know if there is a way to lube it or something
#232357 - 04/11/06 06:06 PM
Re: smooth shifting
jellydoughnutt
i changed the bushings and the tranny fluid made a big difference good write-up here
and here
#232360 - 04/13/06 02:04 AM
Re: smooth shifting
baellremoteuse
Loc: Michigan :)
Try "Syncromesh."
Be lamps unto yourselves. If you can not read do not post.
Lead by example *67, not with threats.
#232361 - 04/13/06 03:24 PM
Re: smooth shifting
209_dup2
Loc: Tracy, CA
thanks now i plan on buying new bushings, but ass far as fluid i dont know how many quarts do i need of that GM stuff
#232364 - 05/18/06 09:47 PM
Re: smooth shifting
TwistedSi
yeah like they said.. Suncromesh helped me 3rd gear grinding problem..
#232365 - 07/06/06 06:37 PM
Re: smooth shifting
wjc05sti
Loc: San Diego, CA
Is anyone else having the issue where sometimes first gear does not want to go in while being stopped? I replaced the bushings and fluid with synchromesh, but it still does it. Also, are there any other bushing that can make the shifter more precise and stirdy?
#232367 - 07/10/06 12:04 AM
Re: smooth shifting
wjc05sti
Loc: San Diego, CA
I don't see how motor mounts would affect shifting, but I do believe that the driver's side mount needs replacement.
#232372 - 07/17/06 10:48 AM
Re: smooth shifting
wjc05sti
Loc: San Diego, CA
From my experience, the OEM mounts are best if you want comfort and if you don't want a noisy interior. I had urethane motor mounts in my other Civic and the entire cabin turned into a noise place with clicks/screaches, etc.
#232375 - 08/17/06 12:46 PM
Re: smooth shifting
Buzzbomb
Loc: Bryan, Ohio, USA
Stock shifter
Urethane shifter bushings.
Amsoil Synchromesh fluid.
Shifts like butta
#232377 - 08/23/06 01:17 AM
Re: smooth shifting
00civicsiboy
Loc: Tennessee
Has anyone also noticed it is eaiser to shift when the tranny is warmed up to operating temperatures?
AIR ASSAULT!!
#232378 - 08/23/06 10:54 PM
Re: smooth shifting
209_dup2
Loc: Tracy, CA
Ok so heres the update, i put in a Skunk2 dual bend shifter, energy Bushings, and got my 30k tranny flush. What can i say my car is just like when i got it, the skunk2 is so much more fun, but the combo of all 3 helped alot.
#232379 - 09/12/06 09:50 PM
Re: smooth shifting
Plik
Loc: Texas
Sometimes I have this problem... just shift it into 2nd then try 1st again. This will get the counter shaft and main shaft to sync up. Works every time
#1304997 - 04/27/07 10:53 PM
Re: smooth shifting
[Re: Plik]
civic13
Loc: You Know
#1410264 - 05/11/07 06:36 PM
Re: smooth shifting
[Re: civic13]
209_dup2
Loc: Tracy, CA
well after driving my friends WRX (with kartboy short shifter) my car felt like it had a lot of play even with the skunk2, bushings. So i just tightened all the bolts but the one that changes it a lot is the one to the tranny just dont get it to tight because you wont be able to shift.
#1416998 - 05/12/07 09:02 AM
Re: smooth shifting
[Re: civic13]
jellydoughnutt
a few things, frist civic13 the shifter you have is the same width as the stock shifter at the joint (bottom of the shifter). so you will need to buy the same civic bushing for your car and it will fit just fine. Thanks JD. So the ES bushings should work since they are replacements for stock shifters (I think)?
yes they WILL work, the bottom of the shifter you have is no different than stock (size wise) connecting to the shift linkage and thats the way it should be. you will want to replace the rusted bolt and get a can of white lithium grease for the install also.
#1594991 - 06/29/07 09:09 PM
Re: smooth shifting
[Re: jellydoughnutt]
2skys1imit3
i would grease with White Lithium under the Engine Bay...really does wonders
#1666658 - 07/20/07 02:14 PM
Re: smooth shifting
[Re: 2skys1imit3]
sephy yo
Loc: San Francisco, CA
is it absolutely necessary to get new washers after draining the T.fluid?
#1668736 - 07/21/07 01:37 AM
Re: smooth shifting
[Re: sephy yo]
shadowdancer
Loc: St.Louis, MO
highly recommended.
#1670476 - 07/21/07 11:46 PM
Re: smooth shifting
shadowdancer
Loc: St.Louis, MO
can also use the vent cap at the top of the tranny. it doesn't require hardly any work except retro fitting a funnel
Moderator: Dr. BrokenLimits, The Mad Paki
