#3692445 - 04/29/09 11:35 PM Discuss: Saab 9-5
Moof Offline
Mounts the residents
Loc: Canadia
You all know who the first person to chime in will be LOL
Good stories, bad stories, story stories.
-The 2.3t
-Linear/ARC/Aero
-Transmissions
-Reliability
-Performance
-Cost efficiency.
And go!
#3692739 - 04/30/09 06:45 AM Re: Discuss: Saab 9-5 [Re: Moof]
CommonGutterTrash Offline
they suck!
stay away!
Drive something much more exciting, and reliable like a 4-cyl accord!!!
Craig R.
2000 9-5 Gary Fisher Wagon
1995 850 T-5R
1996 Galant
AIM = gclipse96
#3692940 - 04/30/09 09:10 AM Re: Discuss: Saab 9-5 [Re: CommonGutterTrash]
RiceEater T/A Offline
Loc: Northern VA
40k on mine in the last year, no problems. Well appointed, comfy, quick on the highway and around town with 250hp, can still throw it around corners. 30mph freeway, great hwy acceleration easy to bump the 155mph limiter.
- Maserati GT - Jaguar XJR - Miata - 9000 Turbo - 200cc DS -
#3693509 - 04/30/09 12:53 PM Re: Discuss: Saab 9-5 [Re: RiceEater T/A]
Aside from oil-changes, the 4-cylinder can go 100k before any major Service.
Used saabs fall into 2 categories: 1: high-mileage comfy cruiser, neglected by first owner. Just driven, and oil-changes. They usually sell them in 3-4 years when they hit 100k, and need water pumps/suspension. They're never washed, usually have broken fog-lights, and cracked lips. The muffler is no longer chrome, and you can't tell what color the carpet was. These, you stay away from.
changing the coolant means the water pump leaks, you often find them with filthy, leaking engines, and there's usually some degree of sludge, since the owner likely went the full 10k OCI, but skimped on the synthetic oil. which means the car smokes on start-up, and the timing chain makes a ton of racket.
The other half of the 9-5's out there are treated as children.
They get new synthetic changes every 2500 miles, they are detailed, they have low miles(or if they're commuters, they LOOK like they have low miles) it'll have no curbing, no broken ANYTHING, and Still have blue coolant in it from the factory. they're well-kept, serviced by a master-tech, and are never skimped on.
it will likely have obscure dealer accesories, and all the badges will have been replaced after they chipped off. The ignition cassette will have been changed, and it will have the correct NGK plugs in it.
In general, they're bullet-proof motors.
the trans is strong, the early 4-speed a/t was great, but the later 5-speed was a little less-strong, (gave out over 350lb/ft, I hear)
the low-pressure cars have a garrett GT17 that tend to fail in 80k or So, and are good for about 275hp. the aero comes with a mitsu TD04 that doesn't quit, and is good for ~325hp. most people call it quits there, as the stock pistons are cast, and tend to 'splode much after that. the good thing, is that the fuel-system will keep up with the turbo's abilities with just an ECU-flash, and a higher-pressure FPR.
The lpt's are soft, cushy cruisers. The brakes are enough, the ride is mushy, but they're comfortable as hell. Sedan and wagon have tons of space for Seating, and storage.
The aero has completely different suspension, sway-bars, brakes, clutch, cams, and ecu.
They're lower, stiffer, and have better/stronger brakes all around.
In 02, the car was revised, but not much changed. just bumpers, HIDs, some interior look, and rear brakes were made bigger.
They're based on a Vauxhall platform, but they changed more than 60% of the chassis, and can only be built in the trollhatten factory, so they're considered their own car.
I don't know any cool facts, like they used whatever material in some place to save weight, and whatever. I know that overall, the car works well. nothing it does conflicts with anything else. it's comfortable, solid, and doesn't sound like a tin can when you drive, and sand gets kicked up by the tires.
when you let go of the door handle, it doesn't twang, and sound like you're breaking it. When you wind one out (which is only 6200rpm), it pulls, and feels healthy. You can run an aero on 87 piss-water, and it will go just-fine.
you'll be ecu-limited to base-boost of ~7-8psi, but it'll drive just fine, and get ~28mpg. (thanks to a 9.2:1 compression ratio)
Craig R.
1995 850 T-5R
1996 Galant
AIM = gclipse96
#3694167 - 04/30/09 05:18 PM Re: Discuss: Saab 9-5 [Re: CommonGutterTrash]
A_Mantis Administrator Online   pandAr
Loc: Valley of the Sun
After seeing Clarkson raving about its highway passing power being on par with a 911, I've started to become curious about the 9-5 Aero. What do they run 0-60 and in the 1/4 stock? I know its not a drag car by any means... but still curious.
#3694343 - 04/30/09 06:56 PM Re: Discuss: Saab 9-5 [Re: A_Mantis]
I prefer the 9-3 simply because is has the better drivetrain, it's cheaper, looks better and has pretty much the same options.
#3694357 - 04/30/09 07:04 PM Re: Discuss: Saab 9-5 [Re: Impulsive]
Moof Offline
Loc: Canadia
The 9-3 with the 2.0T or the 2.8T V6?
#3694395 - 04/30/09 07:21 PM Re: Discuss: Saab 9-5 [Re: Moof]
2.8. I'm sure the 2.0's are the same except the 9-5 has more boost (or a bigger turbo).
Plus you can get AWD with the 9-3.
#3695602 - 05/01/09 09:18 AM Re: Discuss: Saab 9-5 [Re: Impulsive]
I'm not 100%-hip on the newest Saabs, but I'm pretty sure the 2L is an ecotec, and the 2.3L is Still a cast-iron block.
I really stopped paying attention after the 07 updates, where the 9-5 started looking like a Passat.
Craig R.
1995 850 T-5R
1996 Galant
AIM = gclipse96
#8978839 - 03/20/17 09:59 PM Re: Discuss: Saab 9-5 [Re: CommonGutterTrash]
ypMs Offline
nike air max running shoes
Air Max 90
Nike Air Jordan 11
scarpe hogan outlet
ugg clearance
Adidas Originals Superstar
Oakley Sunglasses Cheap
Kobe Shoes Nike
cheap uggs
Air Max Pas Cher
Original Ugg Boots
canada goose jackets on sale
nike mercurial soccer cleats
chaussure Nike homme
zapatillas running
Jordan Sneakers For Sale
toms sale
Pandora Store Sale
Adidas Originals Stan Smith
Canada Goose Outlet
new yeezy shoes
ugg store
Ray Ban Sunglasses Online
moncler jacket sale
Ray ban sale online
Nike Air Sneakers
Nike Shoes Sale Store
Michael Kors
nike schuhe günstig
The official UGG
fitflops sale uk
Canada Goose Outlet
Nike Zapatos
pandora outlet store
air force one pas cher
Nike Online Store
adidas store
Nike Air Women
goedkope nike air max
Coach Bags On Sale
Air Nike
Air Max Sneakers
Adidas Neo Discount Sale
converse store
Hugo Boss Sale
Pandora Store
zapatillas nike baratas
Nike Shox Cheap
new jordan releases
UGG BOOTS FOR WOMEN
Boost Yeezy Sale On Line
nike jordan shoes
zapatilla adidas
ADIDAS NMD SALE ON LINE
religion store
Discount Air Max
pandora jewelry store
nfl store
huarache sneakers
longchamp bags on sale
Negozi Pandora
Nike Roshe Run Sale
nike joggesko
Boutique Ugg
TOMS SHOES OUTLET
abercrombie and fitch store
Jordan Shoes Air
Doudoune Moncler Pas Cher
zapatos de futbol nike
chaussure basket homme
Canada goose dam
Nike Air Huarache For Sale
billige nike sko
Nike Soccer Cleats Boots
Moncler Sale
Uggs Pas Cher Soldes
Michael Kors Outlet
Nike Air Max Goedkoop
botas de futbol
Pandora Official Website
louboutin heels
Ugg boots Sale
Yeezy Black
Hogan Outlet
cheap nike air max
Nike Factory Store
new pandora charms
Cheap Michael Kors
Vans Black Sneakers
Jordan Schoenen
Soccer Boots Outlet nike
canada goose jacket outlet
Nike Air Pas Cher
Scarpe Air Max
nike air jordan pas cher
nike sportschuhe
hogan scontate
Air Max Kopen
Air Jordan Retro Sale
Air max dam
Air max levně
Timberland Outlet
cheap uggs for women
newest lebron shoes
ugg factory outlet
Descuentos Nike
Yeezy Boost Sale Online
Nike Air Max Cheap
Pandora Store
Nike Shox discount Sale
nike sb stefan janoski
Ugg Pas Cher En France
nike sneakers
Ugg Outlet Online Store
Stone Island Outlet
Moncler Outlet Online
scarpe nike
Nike Air Damen
womens nike air max
Air Max Femme
Boty Nike Air
Adidas Superstar
Bottes Ugg Femme Pas Cher
Adidas Superstar Sale Online
Moncler Outlet Store
Ugg Pas Cher Femme
pandora beads
Nike Air 90
chaussures nike pas cher
Canada Goose Womens Coats
reebok running shoes
retro jordans for cheap
günstige nike schuhe
Yeezy Men
official NHL jerseys
Nike Store
Toms Outlet Online
uggs for women
vans shoe store
Nike Pas Cher Femme
Jordan Store
toms shoes outlet
coach factory outlet online
Uggs For Cheap
ypMs 2017.3.21
#8984567 - 03/26/17 08:45 PM Re: Discuss: Saab 9-5 [Re: ypMs]
lcklck16 Offline
20170327lck
http://www.polo-outlet.com.co
http://www.suprashoes.us.com
http://www.mulberrysale.co.uk
http://www.nikeshoes.org.uk
http://www.nikeoutletstore.us
http://www.hermesbirkin.org
http://www.fitflop.in.net
http://www.adidasnmduk.org.uk
http://www.polo-outlet.in.net
http://www.foampositeshoe.net
http://www.niketrainers.me.uk
http://www.herveleger.us.com
http://www.edhardy.us.com
http://www.nikeairmax90.me.uk
http://www.nikefree5.us
http://www.longchampuk.me.uk
http://www.todsoutlet.us.org
http://www.fitflopssale.me.uk
http://www.nikerosheone.us
http://www.mulberrybags.me.uk
http://www.lebronjames.us.com
http://www.kobeshoes.us
http://www.futbol-baratas.com
http://www.airmaxuk.org.uk
http://www.beatsbydrdre.co.uk
http://www.hermesbelts.us.com
http://www.nike-store.org.uk
http://www.nikestore-uk.me.uk
http://www.nikeair-max.me.uk
http://www.pradaoutlet.us
http://www.pradashoes.us
http://www.airmax90.org.uk
http://www.ysloutlet.us.com
http://www.iphone-case.org.uk
http://www.omegawatches.me.uk
http://www.cartier-watches.us
http://www.pandoraoutlet.name
http://www.ugg-outlet.me.uk
http://www.cartier.us.com
http://www.marc-jacobs.us.org
http://www.katespade.org.uk
http://www.nike-airmax2015.us
http://www.cazal.us.com
http://www.ferragamo.eu.com
http://www.fitflopssale.us
http://www.airjordan4.org
http://www.asicsisrael.com
http://www.nikerosherun.me.uk
http://www.cheap-raybans.org
http://www.jordanshoes.us.com
http://www.airforce1.us.com
http://www.toryburch.com.co
http://www.vans-shoes.cc
http://www.airmax90.us.com
http://www.rolex-watches.it
http://www.nike-mercurial.net
http://www.kobe9elite.us.com
http://www.burberryoutlet.ca
20170327lck
#9173926 - 10/31/17 02:56 AM Re: michael kors factory outlet [Re: ]
HYst Offline
#9190006 - 11/17/17 09:04 AM Re: michael kors factory outlet [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
#9214649 - 12/20/17 08:38 PM Re: michael kors factory outlet [Re: ]
20171221yuanyuan Offline
nike outlet store
louis vuitton outlet store
ugg boots
ugg boots
ralph lauren sale
the north face outlet
air max
ray ban sunglasses discount
pandora jewelry outlet
fred perry polo shirts
cheap ugg boots
michael kors outlet clearance
nike outlet store
timberland outlet
longchamp sale
gucci outlet
oakley sunglasses outlet
adidas outlet online
ugg
longchamp bags
birkenstock outlet
michael kors outlet store
retro 11
adidas nmd r1
burberry handbags
supreme clothing
toms shoes
canada goose coats
ray ban glasses
yeezy shoes
air jordans
hermens
louboutin outlet
pandora charms sale
valentino outlet
ugg outlet store
cheap ugg boots
discount oakley sunglasses
coach outlet canada
ray bans
nike outlet online
canada goose outlet store
adidas nmd r1
canada goose coats
fred perry shirts
burberry outlet online
nike outlet online
yeezy boost 350
adidas nmd runner
canada goose coats
kate spade outlet online
moncler sale
moncler jacket
ugg boots
ugg boots
north face outlet
north face sale
burberry outlet
louis vuitton factory outlet
canada goose coats
jordans
nike sneakers
ugg boots sale
moncler
bottes ugg
pandora uk
supreme uk
adidas yeezy boost
ugg outlet store
pandora uk
ray bans
ray ban sunglasses cheap
nmd adidas
hermes bag
moncler jackets
pandora
longchamp outlet store
ugg boots
ugg outlet store
valentino
coach handbags outlet
mulberry
adidas yeezy boost 350
ugg canada
ugg boots
salvatore ferragamo shoes
uggs
red bottoms
north face outlet
mbt
ugg boots
ugg outlet online
coach factorty outlet online
yeezy boost 350
canada goose coats
cheap jordans free shipping
moncler sale
uggs clearance
moncler coats
ugg australia outlet
adidas ultra boost
cheap ugg boots
adidas yeezy shoes
canada goose coats
cheap jordans for sale
nike sneakers
hermes outlet
moncler outlet online
tory burch outlet online
longchamp bags
ugg canada
uggs clearance
ugg boots outlet
ugg boots outlet
ralph lauren sale
nike air max 2018
hermes handbags
adidas outlet store
air max
caterpillar boots
air jordan retro
ugg sale
adidas sneakers
moncler uk
air max shoes
gucci outlet online
moncler jackets
fitflop sandals
hermes bags
cheap air jordans
supreme shirts
pandora charms outlet
ugg outlet online
burberry handbags
moncler pas cher
harden vol 1
mulberry uk
moncler coats
nike outlet store online
adidas yeezy boost
cheap air jordans
ugg boots
moncler jackets
coach purses
burberry handbags
adidas outlet store
north face jackets
yeezy shoes
red bottom heels
yeezy boost 350
mulberry outlet uk
michael kors outlet canada
ugg boots
birkenstock shoes
michael kors bags
cheap uggs
ugg boots
cheap ugg boots
adidas superstars
canada goose jacket
coach outlet canada
mlb jerseys cheap
adidas nmd r1
adidas store
ugg boots outlet
salvatore ferragamo outlet
air jordan shoes
moncler uk
moncler coats
timberland outlet store
ugg outlet online
columbia sportswear outlet
yeezy shoes
canada goose jackets uk
canada goose outlet online
canada goose parka
cheap nfl jerseys wholesale
uggs on sale
adidas superstar shoes
birkin handbags
cheap air jordans
mbt
the north face jackets
red bottom
louboutin outlet
adidas nmd runner
uggs on sale
north face jackets
hermes bags
ugg boots
ugg boots women
tory burch shoes
ugg boots
ugg outlet store
