#7901010 - 10/07/14 06:24 PM
Re: I have a garage project!
[Re: scootergeek]
max
#7931263 - 10/25/14 06:39 PM
[Re: max]
max
#7932787 - 10/26/14 10:38 PM
[Re: SiZ]
max
#7938829 - 10/30/14 12:32 AM
[Re: scootergeek]
max
Mostly global warming.
Also Vancouver doesn't really do "snow". We have snow on the ground for maybe five or ten days a year, tops.
2015 Gear Hauler
#7943056 - 11/01/14 07:56 PM
[Re: scootergeek]
max
#7944178 - 11/03/14 12:21 AM
[Re: scootergeek]
auxilary
Loc: Zimbabwe
damn fine job on knocking up the wife, max! also the garage is looking good
#7948390 - 11/05/14 09:13 AM
[Re: auxilary]
g96nt
Loc: Annapolis MD
This is awesome, and very inspiring. We just bought a house that has a well-built screened porch that will some day become a family room. Seeing you convert a carport to what could be a living space is awesome!
Congrats on all the "grown-up stuff"!
I didn't look at the dates on the posts.. know if it's a boy of girl?
2000 Saab 9-5 wagon
#7960433 - 11/12/14 03:00 PM
[Re: g96nt]
max
It's a boy!
Updates have been kinda slow since I put up the wrap because I fucked up my hand and can't really hold tools. I figured I'd save some money by not buying a hammer tacker (basically a hammer action staple gun) and using a normal staple gun instead but the constant squeezing action really inflamed the tendons on my main hand and I can't grip tools without a lot of pain. It's getting a bit better though so I might have some more progress this coming weekend.
Way to go, Cheap Max, way to go.
2015 Gear Hauler
#7961950 - 11/13/14 01:47 PM
[Re: max]
g96nt
Loc: Annapolis MD
Oh my! Seems like an odd way to put yourself out of commission. Have you had it checked out?
Congrats on the future gear-head!
We're having a girl. hopefully it's won't be such a tough sell on a project car when she's 14 or so.
2000 Saab 9-5 wagon
#7964360 - 11/14/14 05:23 PM
[Re: g96nt]
max
Yeah, I have. The doctor told me that it's not serious, just annoying, and that I should man up and take some Advil.
On the plus side I've been seeing an uptick in pity handjobs from the wife.
2015 Gear Hauler
#7964870 - 11/15/14 09:27 AM
[Re: max]
g96nt
Loc: Annapolis MD
hahahah
I don't see a downside anymore.
2000 Saab 9-5 wagon
#7966388 - 11/16/14 11:20 PM
[Re: g96nt]
max
OKAY, so I took my doctors advice and set out to be less of a wimp and get back to work on the double door.
The door itself will be made out of 2x4's which, because dimensioned lumber doesn't actually add up correct, will work just well enough to leave room for plywood sheathing on the outside of the door, foam weatherstripping along the 2x2's on the inside of the jamb, and still be flush with the rest of the wall.
A couple weeks ago, just after I finished putting up the house wrap, I nailed up a jamb made out of pressure treated wood, basically a 2x6 with a 2x2 around the inside.
Then I cut the hinge mortises with a chisel. I could have used a router but the chisel was fast enough. Also you really want to keep the pressure treated wood dust to a minimum because the chemical preservatives that the wood is soaked in are toxic.
My Dad came over and helped me relocate the hose bib from earlier in the thread because having a tap inside the wall is just stupid.
Unfortunately my dad cracked a vertebrae so he hasn't been able to lend much of a hand other than by doing some pipe soldering
I'm building the door in place because I don't trust my carpentry skills to make something that actually fits well without the jambs as a reference.
I screwed a 3/8" spacer to the top of the jamb for clearance and then screwed the door's top stud to the spacer. The bottom of the door was shimmed using bits of leftover ply. This was done to ensure that the door has sufficient clearance from the jamb when it's finished.
Taking leftover bits of plywood from the other sheathing I cut gussets and used them to hold the door studs in place. The double stud just off the centre is where it will be split. One of the door halves is bigger because I anticipate I'll only need one to open most of the time.
The door is built with screws instead of nails because they're easy and it's not a structural component like the walls.
The gussets were pretty lame though and didn't keep things in line well, so I augmented with more leftover plywood scraps
For the most part I had good luck in this project, thinking five minutes ahead has helped me from doing boneheaded things. Except one of the screws I placed to hold the door header in temporarily was boxed in by those two close studs. Doh.
I had to use a ratchet and a u-joint to get it out. It probably would have taken less time to remove the stud but I wasn't about to concede defeat.
Once that was loose I popped the door from the jambs and laid it on the shop floor to begin sheathing it and separating it.
The door is only 78" tall so one of the sheets hangs off the end a fair bit. Nothing that can't be fixed with a flush trim router bit.
Really, flush trim router bits are the best thing. If you can't fix your mistakes with a flush trim router bit you really should re-make your parts from scratch; it's too far gone otherwise.
Unfortunately when running the router down the door split it caught a couple times and ruined my nice straight line. Whoops. Oh well, the door will be covered in siding later so this will just be our little secret.
After the ply was separated along the studs I got out my (borrowed) DeWalt lightsaber and cut the header and footer studs.
And then hung a door. Like a boss.
The second door will require more people to help hang, it's really heavy.
2015 Gear Hauler
#8038141 - 01/09/15 12:48 AM
[Re: max]
max
Man I have not been doing well at updates on this project at all.
The framing is all done now, the sheathing and wrapping is all done now. The double door is complete, in-place, and both are now primed.
I received my shipment of Hardi Plank siding and trim boards today. I need to pick up a bunch of flashing but should soon be able to start putting the siding up.
2015 Gear Hauler
#8050449 - 01/18/15 05:05 PM
[Re: max]
max
#8139745 - 03/22/15 04:47 PM
[Re: max]
max
#8142021 - 03/24/15 11:31 AM
[Re: max]
g96nt
Loc: Annapolis MD
You should paint some sort of mural on that wall so it looks like you're looking out over the pacific or puget.
I feel ya on the naps. I don't know how my g/f does what she does on the sleep she gets. I'm tired all the time, and she's running around like she's sleeping 12 hours/night.
2000 Saab 9-5 wagon
#8279049 - 07/06/15 09:13 PM
[Re: max]
theLoon
Loc: MN
That is some compound you've built there Max, looks like a shit ton of work but the results are unbelievable. Love seeing transformations like this, makes it seem like anything should be possible in my backyard.
I'm a badge whore
#8774934 - 08/29/16 12:06 AM
[Re: theLoon]
max
#8978823 - 03/20/17 09:58 PM
[Re: scootergeek]
ypMs
#9173928 - 10/31/17 02:56 AM
[Re: scootergeek]
HYst
