#5542303 - 05/05/11 03:36 PM
nitrous with boost...
Flexin5
maybe you guys can guide me in the right direction.
basically, i have a integra, LS motor, stock sleeves, forged pistons, rods, micropolished crank,ARP head studs everything new etc etc.
turbo setup on it now is a T3/T04E 54trim .63a/r, top mount manifold, external gate,closed dump, 3 inch turbo back, tuned on chrome running off wastegate spring @ 8psi. (made 256whp, 210tq) oh and compression is sitting at about..9.5:1 with the milled head.
i blew the headgasket in fall, so i pulled the motor to clean some things up, and i'm getting a new top mount and downpipe made up; then it's back to the dyno for maybe..15-18psi but tuned with neptune this time.
i always wanted to spray, so i was thinking maybe a 50shot for a bit more power? fuel wise, the setup is RC 750cc injectors, AEM fuel rail, sard fuel pressure regulator, intank walboro 255lph, stock lines.
also, i'm going to make the entire thing hidden. hide the lines, bottle everything. what would be the best way to go about this?
Edited by Flexin5 (05/05/11 03:37 PM)
02 RSX 05 325i
#5553239 - 05/10/11 07:28 PM
Re: nitrous with boost...
[Re: Flexin5]
civicsidude
Loc: somewhere in florida
with all that stuff in there it wont be that hard to hide it. a 50shot is a small shot and relativly safe you can go about this 3 ways
1. being run a intercooler system that basically rapidly cools your intercooler for a nicer boost "safest way"
2. run a wetshot, it would be a standard install the hard part is just trying to hide the noids out of site unless you put them in some sort of little box to hide them.
3. would be running a dry shot, since you have upgraded injectors and pump this would not be so bad. I would even go to say using a zex they are very easily hidden and low cost, extremly safe due to their conservative ratings.
Bottle hiding is a completly different story, the only real way is to make a custom enclosure in the trunk to hide it but make sure you have a blow down tube if the track people see that with out one you could be banned from the track
#5559501 - 05/13/11 12:45 PM
[Re: Flexin5]
civicsidude
sice you are going to have to run the nitrous and fuel to them you have to keep them outside the engine compartment. having them inside the car is grounds for a ticket some places i even heard car impounding.
Also if a noid breaks you dont it want it leaking in there
#5996122 - 12/14/11 05:27 PM
[Re: MyPlumbing]
thedlake
interesting... very good info
#6141524 - 02/15/12 09:14 PM
[Re: thedlake]
sallycooper296
Thanks for sharing some good informations..
#6654501 - 10/17/12 09:34 PM
[Re: gasad]
ssdada
Why are so many people on the Diablo 3 disappointed? Why always play not long but from time to time, want to play? Blizzard what they are doing? They should do? Diablo 3 gold will help your. You should choose a reliable store to buy Diablo 3 gold.This article is long, but it is a rare and in-depth analysis of Diablo 3 compared to Diablo 2 missing. Quweicunzhen from Diablo 2 to Diablo 3. Blizzard lost should not lose. We always miss our expectations, but could not speak. I hope this article can that you've made up your mind!
#6765596 - 12/12/12 12:06 AM
[Re: ssdada]
glenneaves
So you want to start taking supplements . That's great. Here's a few articles we've compiled that should get you started and simplify what can at times seem overwhelming if you're a beginner:
Moderator: civicsidude
