Page 5 of 8 « First<34567>Last »
#6569100 - 09/05/12 07:05 PM Re: My 5/3/1 log... [Re: Impulsive ]
DieZel Offline
Loc: 18th green
It's not based on a 1RM to start... You're supposed to pick a weight that is like 80% of your guesstimated 1RM then do as many as you can and plug it into the formula to get your theoretical 1RM, then yeah x .90 to get your training max...
Needless to say I was weak as nuts when I started this that's why my 1+ and 3+ sets I'm still able to pull multiples... So I am progressing very nicely and will likely bump my dead and squat training maxes by 15 or 20 next cycle vs just 10...
I stick with the 5lb bumps on the OHP and BP cause my reps aren't as high as the lower body...
#6591298 - 09/17/12 09:36 AM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
OH DB press 70x9,8,7
Tbar rows 190x11,11,10,8 then dropped to 135x12
DB flat press (where I started to struggle) 95x9,8,7,6 dropped to 80x9
Close grip bench was fail 175x9,7,6 was shooting for 3 sets of 10
Killed my lateral and bent over lateral raises though 35x12x3
#6591314 - 09/17/12 09:45 AM Re: My 5/3/1 log... [Re: Impulsive ]
OB1 Offline
Loc: I have no home
I still don't understand this routine. \:\(
#6591538 - 09/17/12 11:02 AM Re: My 5/3/1 log... [Re: OB1]
65_289 Offline
His specific exercise choice or 5/3/1 in general?
#6591547 - 09/17/12 11:06 AM Re: My 5/3/1 log... [Re: OB1]
DieZel Offline
Loc: 18th green
Week 1
Day 1
OHP 3 sets of 5, last set is 5+ (do at least 5 but continue until failure or just prior to failure)
Then you can choose to do 5 sets x 10 at 55% of your training max... What's your training max...?
Got that...?
Move to week 2 you do a set of 3 with 70% TM, 3 with 80% TM, set of 3+ with 90% TM
Move to week 3 you do a set of 5 with 75% TM, 3 with 85% TM, set of 1+ with 95% TM ( hence the name 5/3/1)
Move to week 4 (deload week) you do 3 sets of 5 with 40,50,60% TM
EASY SCHMEEZEY...
#6591590 - 09/17/12 11:31 AM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Oh a better way to determine your training max is to estimate what your max may be and then take 80% of that number and rep til failure...
You estimate your bench max is 250... X .8 = 200...
You rep 200 for 10 reps...
Then use this formula to determine your " theoretical max)...
Weight (200) x reps (10) x .0333 + weight (200)
200x10x.0333+200 = 266 x .9 = 240 training max...
#6591606 - 09/17/12 11:37 AM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Example of gains i've made to date...
first OHP day my 5+ set looked like this...
125x9 theoretical max from that would be 125x9x.0333+125 = 162
todays 5+ looked like this...
150x9 theoretical max from that would be 150x9x.0333+150 = 195
GAINZ, MO GAINZ...
#6600331 - 09/20/12 05:42 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Deadlifts yesterday for 5+ @ 290 did 12 and stopped... could have done a few more, but i told myself if i hit 12 i'm done... if i keep hitting these high ass rep numbers i will continue to bump my training maxes by 15 vs 10 pounds fromn month to month...
tomorrow my 5+ bench is 215... really hoping to get 10... may not seem like alot to you big benchers, but my bench has always been shittay...
#6601104 - 09/20/12 10:33 PM Re: My 5/3/1 log... [Re: DieZel]
Silock Online   pedobearsmiley
Loc: Jayhawk Country
Better than my bench . . .
#6601758 - 09/21/12 09:10 AM Re: My 5/3/1 log... [Re: Silock]
DieZel Offline
Loc: 18th green
Well got 9 @ 215... 1 more rep than my last 5+ set so ill take it... Gainz is gainz...
#6601858 - 09/21/12 09:42 AM Re: My 5/3/1 log... [Re: DieZel]
Impulsive Online   nohc
Exactly. My gains seems pretty minor right now, but I think the whole point of the 5-3-1 is that even small gains are gains, so any progression matters.
#6602120 - 09/21/12 11:00 AM Re: My 5/3/1 log... [Re: Impulsive ]
DieZel Offline
Loc: 18th green
No doubt...
#6603514 - 09/21/12 11:56 PM Re: My 5/3/1 log... [Re: DieZel]
137 Online   nohc
Loc: Alhambra, CA
I'd love to hit anything over my body weight for reps. Slowly getting there! Chest is going to look awesome one that bottom tit fat melts away!
Wayne T. Edwards
http://om1kron.blogspot.com - car blog
http://waynescn.blogspot.com - diet blog
#6608206 - 09/24/12 10:23 PM Re: My 5/3/1 log... [Re: 137]
DieZel Offline
Loc: 18th green
OHP today for a set of 3+ @ 160 I got 7 reps...
According to that formula I could press nearly 200 overhead...
I noticed today importantly that I actually bring the bar down to damn near my chest... Here I thought I was stopping at parallel, didn't even realize I was going down that far...
#6616787 - 09/28/12 01:32 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
last week on incline db press @ 90 i did 9,8,7 dropped to 80 for 8,7
this week on incline db press @ 90 i did 9,9,8,7 dropped to 80 for 9
#6620500 - 10/01/12 09:47 AM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
http://youtu.be/m0x8peqX0t8
#6625371 - 10/03/12 09:47 AM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Deadlift today 1+ @ 325 I got 8 reps...
#6669135 - 10/24/12 03:09 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Deadlift today for 3+ @ 315 hit 10 reps... Might have pulled 1-2 more but lower back was stiff last few days so didn't go all out...
I think this is the last cycle ill be doing of the 531 for the next 7-8 months... I plan to start my contest prep at end if December and want to get more volume in vs trying to jam push and pulling into same days so I'm gonna go to a 5 day workout week and follow a push, pull, legs split... Days off will me Tuesday and Thursday...
#6676133 - 10/28/12 03:28 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
#6685390 - 11/01/12 03:59 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Last week of my current attack on this 531... wednesday my 1+ on deads was @335, which i pulled 10 reps... may have been able to do 1-2 more, but i didn't want to get crazy, considering i had like 25 more sets of other stuff to do...
tomorrow i will be doing 1+ @ 250 on the bench press... really hoping to bang out 4 or more, but we shall see...
looking forward to moving onto new program, but will definitely revisit the 531 in my next "offseason"...
I will continue my progress updates here, but will be using a different protocol... i have decided to continue with a "bulk" phase through the end of this year, and then start a 28-32 week cut and compete in October 2013...
#6704049 - 11/09/12 08:15 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
First week of my new training program is nearly in the books... (ran out of time today, and didn't get my calf work in so i'll do them tomorrow)
First 2 workouts are strength based (3-8 rep range)
-Day 1 is upper body
-Day 2 is lower body
Next 3 days are more hypertophy work (8-20 rep range - varies on the movement)
-Day 3 is pushing
-Day 4 is pulling
-Day 5 is legs - I fucking annihilated my shit today... high reps really does fuck your shit up when you're not used to it...
Today's workout
Squat - 3x10-15
Hack squat - 2x10-15
Walking lunges - 3x30-40
Leg extension - 3x10-25
Lying leg curl - 2x10-15
Seated leg curl - 2x10-15
SLDL - 2x10-15
I hit the upper rep range most of the time, except for leg extensions, i knocked out 13,14,15... my quads were shot after those lunges, but improved on each successive set... I do them single leg so try and keep them symetrical...
Looking forward to the next week, and pushing some bigger weights on Sunday and Monday...
#6704053 - 11/09/12 08:17 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
current macros
training days
500c/75f/210p = 3515cals
off days
360c/80f/220p = 3040cals
Saturday refeed
680c/55f/175p = 3915cals
#6704104 - 11/09/12 08:55 PM Re: My 5/3/1 log... [Re: DieZel]
65_289 Offline
current macros
training days
off days
Saturday refeed
#6704454 - 11/10/12 06:48 AM Re: My 5/3/1 log... [Re: 65_289]
DieZel Offline
Loc: 18th green
#6704464 - 11/10/12 07:14 AM Re: My 5/3/1 log... [Re: DieZel]
65_289 Offline
#6704599 - 11/10/12 09:58 AM Re: My 5/3/1 log... [Re: 65_289]
DieZel Offline
Loc: 18th green
#6704841 - 11/10/12 01:26 PM Re: My 5/3/1 log... [Re: DieZel]
65_289 Offline
#6704858 - 11/10/12 01:42 PM Re: My 5/3/1 log... [Re: 65_289]
65_289 Offline
I'll stop hijacking your thread now. \:\)
#6704937 - 11/10/12 03:00 PM Re: My 5/3/1 log... [Re: 65_289]
DieZel Offline
Loc: 18th green
For you weight 140 it's definitely overkill... Personally I'd drop it to 150 and add some more carbs and fats...
#6706245 - 11/11/12 03:56 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Some gym vids from today...
Incline DB Press 100x5
http://youtu.be/feSP-VzbEfk
DB rows 130x5
http://youtu.be/ljuMvSD5GZQ
#6706249 - 11/11/12 03:58 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Tried doing the 110's today... Lol no dice... Couldn't even get the first one up... I wish my gym had 105's... I'm supposed to be doing 3-5 reps without going to failure... I can do the 100's for 5 but that jump to 110 is just too much... Prolly have to move to a barbell press to be able to make weekly increases...
#6723449 - 11/19/12 12:58 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
#6723581 - 11/19/12 01:54 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
Oh yeah new macros...
training days
525c/80f/210p = 3660cals
off days
400c/80f/220p = 3200cals
Friday refeed - moved to Friday so it fell on a training day...
700c/65f/175p = 4085cals
#6723582 - 11/19/12 01:54 PM Re: My 5/3/1 log... [Re: DieZel]
DieZel Offline
Loc: 18th green
weight sitting at 203-204 still... should increase with a bump in cals...
#6725002 - 11/20/12 05:34 AM Re: My 5/3/1 log... [Re: DieZel]
Moderator:  Bumjubeo
