Page 1 of 9 12345>Last »
#6470140 - 07/20/12 02:04 PM So, I'm finally building an engine... *new dyno # 2/7/2014*
#6470184 - 07/20/12 02:25 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
#6470197 - 07/20/12 02:31 PM Re: So, I'm finally building an engine... [Re: FCobra94]
#6470218 - 07/20/12 02:40 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
LowTech302 Offline
#6470346 - 07/20/12 03:33 PM Re: So, I'm finally building an engine... [Re: LowTech302]
hustler Offline
yeah watch out you will want a big windsor soon \:\) you should check out this american iron video of paul brown with a n/a 5.7 ex cup motor.
#6470356 - 07/20/12 03:39 PM Re: So, I'm finally building an engine... [Re: hustler]
#6470444 - 07/20/12 04:18 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
347? 331? 408? 470? C'mon...don't be a bitch and just tease. Put out man! I want details or you're useless to me!
#6470461 - 07/20/12 04:22 PM Re: So, I'm finally building an engine... [Re: UglyValiant]
#6470592 - 07/20/12 05:21 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
hustler Offline
That will be a healthy motor and the 185's are a good match for a naturally aspirated 331. a 205 or a 210 edel vic jr head would have been a good match too, that thing will make power. What intake are you going to use? Don't say stock either \:\) stock intake manifold is a cork. I finally gave in and upgraded to a 96 exploder intake after i grabbed some gt40 heads. For your motor I would look at an Edel Performer RPM 2 intake. That is a great midrange rpm intake and would make the most usable power throughout the powerband on that n/a 331. I had a systemax intake which was similar to the vortech/saleen intake and i just felt like the runners were so big that the velocity suffered with my stock 302 and the e7 heads which were so small. My HP went up by 40+ with the e303 cam but torque dropped considerably and felt like a dud off the line. it definitely ran better with the blower, but the e7 heads and my 19lb injectors with FMU still held me back to 340whp @ 10psi. Not very impressive. would guess you will need 36lb injectors for your new setup. 24lb'ers might just be a tad small.
#6470669 - 07/20/12 06:17 PM Re: So, I'm finally building an engine... [Re: hustler]
#6470907 - 07/20/12 08:42 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
Impulsive Online   nohc
Awesome. Glad you're doing it right.
#6471581 - 07/21/12 01:25 PM Re: So, I'm finally building an engine... [Re: Impulsive]
ScottStaypuff Offline
#6471589 - 07/21/12 01:33 PM Re: So, I'm finally building an engine... [Re: ScottStaypuff]
GB Offline
Sharesies!
Loc: Craigslist
#6472215 - 07/21/12 11:30 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
Well, the parts are there...it'll depend on the cam you select. For a fuel-injected engine w/ this many cubic inches, I'd look to something in the 228-234 @.050 range (intake side) w/ a 112-114 LSA for a hyd. roller. You'll want to spin this thing to 6500 rpm for those cubes to make the target practice.
#6472446 - 07/22/12 09:39 AM Re: So, I'm finally building an engine... [Re: UglyValiant]
#6474513 - 07/23/12 12:04 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
hustler Offline
Would recommend staying with shortys. I had to switch from Kooks to BBK longtubes after I put head studs on the stock block. Getting them in was no fun job because you have to lift the motor up very high. So basically to get the trans out I had to take off the passenger side header by unbolting mounts, raising it, then had to lower it back and bolt the mounts again so i could pull the bellhousing/trans out. Pain in the ass. I don't like unbolting the driveshaft when pulling the trans either so I wiggle it out at an angle making it a little harder before I pull it off the yoke on the ground. Anyway I would steer away from longtubes. Don't think they are worth the hassle unless you are making over 500whp.
#6475527 - 07/23/12 07:50 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
As for the cam, I was thinking of going with Comp Cams XE282HR.[/quote] That cam will make the number...easily. Might be a little wild for the street with those cubes, but will command attention any cruise spot you pull into. NICE.
#6503042 - 08/04/12 08:03 PM Re: So, I'm finally building an engine... [Re: UglyValiant]
Well, some of the parts came in already. Here is the lot of parts that came in so far
For bottom end I went with Eagle 331 internally balanced rotating assembly. I really wanted to do an internally balanced engine, so it could be more rev happy. I'm probably not going to rev it too far, since this is a street engine using hydraulic roller cam. Probably going for a 6500 rpm redline. Everything is forged, including the Mahle pistons and H-beam rods.
Top end parts so far are Comp 1.6 roller rockers and hardened pushrods
And since factory engine is a 50oz externally balanced, I can't reuse stock flywheel or balancer. So I ordered one of ACT ProLite flywheel. What's cool about this piece is that most of the material has been removed from outside of the flywheel, in effort to keep the rotating mass down. And it's also one piece, which means that it will be as reliable as stock flywheel.
Other stuff that's not in pictures are just gaskets, and Ford Racing high volume oil pump. Stay tuned for more.
#6503435 - 08/05/12 12:54 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
Though you purchased a balanced kit, make sure you go ahead and have it balanced by the machine shop. You'd be surprised how many people buy balanced kits and they turn out not to be terribly balanced. I forget how many grams my "internally balanced" kit was off...but it was very worth my while to pay the extra 175 to get it done and know it was dead nuts on...and now it revs so smoothly...very impressed with the results.
#6503513 - 08/05/12 05:02 AM Re: So, I'm finally building an engine... [Re: UglyValiant]
#6521898 - 08/13/12 01:06 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
hustler Offline
Love watching a new build happen \:\) just got back from vacation, so will keep checking your progress.
#6545578 - 08/24/12 01:11 AM Re: So, I'm finally building an engine... [Re: hustler]
#6546122 - 08/24/12 10:51 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
hustler Offline
These engines can go a long time when taken care of no doubt about it.
#6546581 - 08/24/12 02:56 PM Re: So, I'm finally building an engine... [Re: hustler]
#6547726 - 08/25/12 06:05 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
GB Offline
Sharesies!
Loc: Craigslist
So, car back to you, finished by second week of october? Ish?
#6548242 - 08/25/12 04:34 PM Re: So, I'm finally building an engine... [Re: GB]
#6571790 - 09/06/12 09:59 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
Few more parts. Say hello to:
Machined block with filed rings
Shorty Headers
In Tank Fuel Pump
Camshaft
Harmonic Balancer
Oil Pan
Roller Lifters (a little blurry)
#6573723 - 09/07/12 06:34 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
Looking good man. I'm jealous!
#6576897 - 09/10/12 01:39 AM Re: So, I'm finally building an engine... [Re: ScottStaypuff]
#6577353 - 09/10/12 11:02 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
hustler Offline
Some nice additions \:\) The Innovators West is a nice piece.
#6577737 - 09/10/12 03:55 PM Re: So, I'm finally building an engine... [Re: hustler]
#6577759 - 09/10/12 04:20 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
hustler Offline
An ATI came with the race shortblock I had, very nice unit, I ended up using my motorsport piece since it had more material and figured it would hold up better with the large blower crank pulley after I had it double keyed. It had a removable counterweight as well. Romac's are good as well I'm told. Funny part is i was looking for something cheap to go back on my stock shortblock so I bought an ebay special old stock Lunati unit for around 80 dollars. Seems to be working so far \:\)
#6589802 - 09/16/12 11:36 AM Re: So, I'm finally building an engine... [Re: hustler]
Stage 8 bolts for headers.
#6589957 - 09/16/12 01:13 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
PsychoEBPSiR Offline
Loc: Vancity,Canada
Awesome man, it ll be like driving a new car . Vids to follow of course
#6590357 - 09/16/12 05:33 PM Re: So, I'm finally building an engine... [Re: PsychoEBPSiR]
