#4810644 - 06/10/10 02:16 AM
TT ZR1 900WHP on pump,100% stock longblock
progressi
http://www.flickr.com/photos/ipsmotorsports/sets/72157623877946145/ Summary of the set-up is as follows:
Bone-stock LS9 (Including stock cam) IPS Twin-turbo Kit featuring HTA 35R Turbos & Tial 44mm WG's IPS Custom Fuel System IPS FMIC Kit w/Tial BOV IPS High-output Alternator Kit RPS Triple-disc Carbon Clutch RPM Level 5+ Tranny & Rear-end PFADT CF Driveshaft DeWitts Aluminum Radiator LS7 Engine Accessory Parts
No dyno #s w/o the owner's permission but I will say that it made as much power at 7psi as it did with the stock blower and many bolt-ons did at 16-17psi
At 15psi and pump gas (No meth) it has made more than any other LS9 ZR1 we have ever heard of E85 and larger injectors are going in on Friday and it is only going to go up from there
Dyno graph's / Vid's and further info to come! Jeff
#4810883 - 06/10/10 08:23 AM
Re: TT ZR1 900WHP on pump,100% stock longblock
[Re: progressi]
NOHC
Loc: Lebanon, Virginia
So, the owner has a small penis?
-Mike- ***Ask me about your broken 360/PS3***
#4812742 - 06/10/10 06:35 PM
[Re: NOHC]
Panda Express
Loc: DFW, Texas
Vid?
#TeamLH aka old ladies at IKEA walk up to me and ask "Do you work for Mercedes Benz?" #Hamfosi My FlickR y0!
#4813196 - 06/10/10 09:30 PM
[Re: NOHC]
progressi
#4813198 - 06/10/10 09:31 PM
[Re: Panda Express]
progressi
I dont know if there's a vid,but I just posted the dyno sheet. It's all there in the original link I posted.
#4817393 - 06/12/10 11:30 PM
[Re: danl]
progressi
Well its fairly simple to figure out how many lbs/min a blower or compressor can support. Anybody know the part number of the blower on the ZR1?
I dont know if this helps:
The LS9's R2300 supercharger is a sixth-generation design from Eaton, with a case that is specific to the Corvette application. The supercharger features a new four-lobe rotor design that promotes quieter and more efficient performance, while its large, 2.3-liter displacement ensures adequate air volume at high rpm to support the engine's high-horsepower aspiration. Maximum boost pressure is 10.5 psi (0.72 bar).
I found it,and a post from a Katech employee:
http://www.katechengines.com/street_perf...N%20HOUSING.bmp
I could not find this so our friends at Magnuson hooked us up. I was curious to see if the speculation that the LS9's supercharger was out of it's efficiency range at 18psi. By our calculations, this is not the case. At 7000rpm, the supercharger loses 6% efficiency going from 10.5psi to 18psi. In my opinion, 6% is not a huge drop.
The debate came up due to a ZR1 that made 700rwhp and these numbers seemed low. I think another contributing factor is that on the chassis dyno, these cars must be seeing tremendous heat soak in the intercoolers. I would be curious to see what the intake charge temperatures are in these conditions.
__________________ _Jason Harding Director of Aftermarket Operations, Katech Performance
http://forums.corvetteforum.com/c6-corvette-zr1/2259154-eaton-tvs-r2300-compressor-map.html
Edited by progressi (06/12/10 11:36 PM)
#4818296 - 06/13/10 03:29 PM
[Re: danl]
progressi
Im tired today. I'll read it again after some sleep.
But the stuff I glossed over:
The Katech employee said that as an engineered system,the air/water intercooler is effective. When the system is pushed further,he said that the intercooler would need to be addressed.
Another thread mentioned the blower was near 80% efficiency,which they claimed was comparable to many OEM turbocharged setups.
So,not comparing it to latest high end aftermarket stuff... is it good?
I really was only posting this to point out some kind of stock block benchmark,as these arent volume cars so we dont see limits pushed often.
