#3678891 - 04/24/09 11:52 PM B16A2 Head Problems
00DoHcSi Offline
Loc: Northeast
Here's my story; Well, my 2000 Civic Si was heavily burning oil ever since I got it. Symptoms pointed out to bad valve seals and guides (smoking blue on cold start ups) and my cyl 4 spark plug was always fouling out while cyl 1-3 were normal. Compression checked out fine across all four (185-190 psi) and all injectors were "clicking" when I put a screwdriver on the base of injector and my ear to the handle.
So I recently decided to fix my oil burning problem. I had the head removed by a shop owned by a friend and is knowledgeable with Hondas. The head was then sent off to the machine shop only to find out the head was worked on before and that I had bronze valve guide inserts that were heavily worn along with shot valve seals. I was pretty sure this was the main cause of oil burning and hoping it would be fixed as soon as the head was back and the engine reassembled.
So I had the valve seals and guides all replaced. All intake and exhaust valves were cleaned and head was fully cleaned with a mild port and a 16 valve job. Everything was then measured and the valve train was assembled to spec. The head also got a full OEM Honda top end gasket kit when reassembled onto the block.
Well, I recently got my car back from the shop and the problem I have now is that my cyl 4 spark plug still fouls out like before and when I look down on the cyl 4 piston, it's wet. The other 3 cyl's are fine and plugs are fine too. However, the oil consumption is still present but a lot less than it was before but still a decent amount to notice it dropping.
The car does run like a champ, pulls hard and more smoothly than before. But the engine is still consuming oil and the cyl 4 spark plug keeps fouling out.
I was told it could be my piston rings but my cyl walls were smooth and showed no signs of scoring when the head was off. Also, the car does not constantly smoke like it were to have bad rings.
What can be my possible problems?...I mean if the head is basically rebuilt and "new like"...what would cause the fouling of the cyl 4 spark plug and oil consumption?
My friend with the shop is going to get me a new cyl 4 injector and changing it to see if it stops the problem since it's the only thing he thinks is causing the problem besides the rings (he's highly doubtful of the rings).
Edited by 00DoHcSi (04/24/09 11:57 PM)
2000 FBP Civic SI
#3679084 - 04/25/09 03:32 AM Re: B16A2 Head Problems [Re: 00DoHcSi]
4doorEG Offline
Loc: Overland Park, KS
No need to get a NEW injector. Switch #4 injector with #1 and if problems start in #1 then you KNOW you have a faulty injector instead of guessing.
BTW, you can have a cracked ring land or really worn rings and a compression test will not always show it.
#3679622 - 04/25/09 01:27 PM Re: B16A2 Head Problems [Re: 4doorEG]
00DoHcSi Offline
Loc: Northeast
But if the ring land was cracked or the engine had worn oil control rings, wouldn't it smoke like constantly as in big plumes of blue smoke out the exhaust pipe?
Cause my car doesn't do that...only if I get on the throttle hard, I see a bit of blackish smoke coming out...but in VTEC, there is very noticeable black smoke coming out.
2000 FBP Civic SI
#3680803 - 04/26/09 02:24 AM Re: B16A2 Head Problems [Re: 00DoHcSi]
Import Tuner Offline
Gold Member
Loc: Tacoma, Wash..
Unfortunatly, your oil control ring in #4 cyl. has lost it's tensile strenght...
It's an easy enough fix, but considerably easier when the head was at the machine shop...
BTW: your mechanic that doubts the rings, needs a li'l more training!...
Donny
Import Specialty Automotive
#3681852 - 04/26/09 06:45 PM Re: B16A2 Head Problems [Re: Import Tuner]
00DoHcSi Offline
Loc: Northeast
It's possible for that to happen in just one cylinder?
Edited by 00DoHcSi (04/26/09 06:46 PM)
2000 FBP Civic SI
#3690720 - 04/29/09 01:18 PM Re: B16A2 Head Problems [Re: 00DoHcSi]
00DoHcSi Offline
Loc: Northeast
So, I had a test pipe bolted in and drove the car around for a bit. It was smoking blue a lot, during acceleration and idle. I guess my rings are done for \:\(
But then I had the cat switched back on and the smoke went away.
2000 FBP Civic SI
#3698752 - 05/02/09 02:15 PM Re: B16A2 Head Problems [Re: 00DoHcSi]
Gold Member
Loc: Tacoma, Wash..
That's because the cat. is an afterburner of sorts and operates at high enough temp to burn off the oil going through it (at least until the deposits plug it up)...
Donny
#9122631 - 09/03/17 09:45 PM Re: B16A2 Head Problems [Re: Import Tuner]
fatihin nurul Offline
ston Street, antara kaki polisi, sementara ia me Toko Plat Bordes
Toko Plat Bordes
Pabrik bondek
Toko Wiremesh Besi
Pabrik besi unp
undangan pernikahan cantik
Distributor Besi Hollow
Jual Besi Hollow Baja
Toko besi hollow
Distributor besi beton Sni Ulir Polos
Agen Plat Bordes
Agen Plat Bordes
Pabrik Plat kapal besi baja bki krakatau steel
Agen Wiremesh Besi
Pabrik besi siku
undangan pernikahan simple
Distributor Wiremesh
Harga Besi Hollow Baja
Agen besi hollow
Distributor besi beton ais
Pabrik Plat Bordes
Pabrik Plat Bordes
Pabrik besi siku
Pabrik Wiremesh Besi
Pabrik Plat besi plat kapal
undangan pernikahan mewah
Distributor Besi Pipa Baja Schedule 80
Pabrik Besi Hollow Baja
Pabrik besi hollow
Distributor Wiremesh Besi sewa villa puncak
Pabrik pipa besi baja sch 40 sch 80
Distributor Atap Spandek
Pabrik besi h beam baja
undangan pernikahan cute
Distributor Besi Pipa Baja Schedule 40
Distributor Besi Beton
Distributor pipa besi
jasa konstruksi baja
Harga Wiremesh Besi
Harga Wiremesh Besi
Pabrik Plat besi
Harga Atap Spandek
Pabrik besi cnp
undangan pernikahan biru
Distributor Pipa Besi Hitam Medium
Supplier Besi Beton
Harga pipa besi
www.pusatbesibaja.co.id
Jual Wiremesh Besi
Jual Wiremesh Besi
Pabrik besi h beam
Jual Atap Spandek
www.gudangbesibaja.com
undangan pernikahan buatan sendiri
Distributor Besi Wf
Agen Besi Beton
Jual pipa besi
www.pusatbesibaja.com
Supplier Wiremesh Besi
Pabrik besi wf
Supplier Atap Spandek
Distributor besi Wf Baja
Distributor Besi H beam
Toko Besi Beton
Supplier pipa besi
Toko Wiremesh Besi
Toko Wiremesh Besi
Pabrik wiremesh
Toko Atap Spandek
Distributor bondek
Jual Besi Beton
Toko pipa besi
Jual besi beton Sni Ulir Polos polos ulir
Agen Wiremesh Besi
Agen Wiremesh Besi
Pabrik besi unp
Agen Atap Spandek
Distributor wiremesh
www.sentrabesibaja.com
Harga Besi Beton
Agen pipa besi
Jual besi beton sii
Pabrik besi cnp
Pabrik Atap Spandek
Distributor pipa besi baja sch 40 sch 80
undangan pernikahan elegan
Jual Welded Beam T beam King Queen Cross Castellated Beam
Pabrik Besi Beton
Pabrik pipa besi
Jual besi beton psi Ulir Polos
Pabrik besi hollow
Distributor Bondek Cor
Distributor besi hollow
undangan pernikahan animasi
Jual Bondek Cor
Distributor Besi Wf Baja
Distributor sch 40
Jual besi beton perwira
Harga Atap Spandek
Harga Atap Spandek
Pabrik besi beton Sni Ulir Polos
Harga Bondek Cor
undangan pernikahan lucu
Jual Atap Spandek Sni
Supplier Besi Wf Baja
Harga sch 40
Jual besi beton PAS
Jual Atap Spandek
Jual Atap Spandek
ironsteelcenter.com
Jual Bondek Cor
Distributor besi wf baja
undangan pernikahan kalender
Jual Plat Bordes Kembang
Agen Besi Wf Baja
Jual sch 40
Jual besi beton master steel ms
Distributor stainless steel
Supplier Bondek Cor
Distributor besi unp
undangan pernikahan ala india
Jual Plat Besi Hitam
Toko Besi Wf Baja
Supplier sch 40
Jual besi beton ksty
Toko Atap Spandek
Toko Atap Spandek
Distributor atap spandek
Toko Bondek Cor
Distributor besi siku
undangan pernikahan klasik
Jual Plat Kapal Bki Krakatau Steel
Jual Besi Wf Baja
Toko sch 40
Jual besi beton krakatau steel ks
undangan pernikahan islami
undangan pernikahan modern
undangan pernikahan online
undangan pernikahan
undangan pernikahan murah
undangan pernikahan artis
undangan pernikahan arab
undangan pernikahan
undangan pernikahan
LINK 5
#9142357 - 09/27/17 05:10 AM Re: B16A2 Head Problems [Re: fatihin nurul]
lzm Offline
payless shoes online store
Mizuno Shoes
Nike Blazer
pandora rings
Air Max 87 Homme
pandora rings
kate spade outlet bags on Sale
Nike Air Max LTD
Air MAX SKYLINE
mlb shop
puma outlet online
kate spade outlet canada
ray-ban eyeglasses
classic
pandora charms sale
michael kors outlet sale
hermes outlet store
best website directory
birkenstock outlet store
Longchamp Sale
under armour on sale
Prada Outlet
kate spade sale
timberland boots on sale
louis vuitton bags
ray ban outlet store
pandora rings
Nike Air Max 90
Promise Rings - Official
clb sports shoes
moncler clothing
Lisinopril 2.5 Mg Cost
coach
michael kors australia
prada outlet online sale
fake sunglasses sale
louis vuitton uk
talons
Coach Sunglasses Outlet
pandora online outlet
casio watches for women
Air Max 180
michael kors purses
Air Jordan
birkenstock outlet
ray ban online
prada online
cool math games
spendless shoes sale
pandora charms outlet
Birkin Bag Hermes
under armour shoes online
prada bags
birkenstock sale
Wholesale Outlet Sale
Mizuno Shop Japan
Engagement Rings - Official
payless shoes store
authentic shoes
chaussures pas cher en ligne
pandora bracelet
Kaufen Nike Air Max 1
brand sunglasses
ray ban prescription sunglasses
Nike Air Jordan Femme
Nike Air Max TN
hermes outlet sale online
coach carter
pandora rings
Mens Sunglasses
Nike Air Max BW
pandora bracelet uk
canada goose outlet online store
michael kors uk sale
black friday sales online
moncler us
michael kors bags online
Prada Bags
Salomon Shoes
Nike Air Max LTD
yeezy shoes kids
Nike Schuhe
oakley outlet online store
birkenstock outlet online
pandora rings
wordpress
ray ban erika sunglasses
Premier Jewelry. - Official
Nike Roshe Run Femme
timberland sale
Coach Handbags
snow boots
pandora charms uk
oakley australia
coach shoes
zales jewelry outlet
import sunglasses
timberland boots
Nike Schuhe Jungen
Air Jordan Flight
black friday 2016
chrome store
tiffany
Nike Air Max 95
Markenschuhe
trazodone100mg
pandora bracelet
Prada Shoes - Official
Michael Kors Canada
puma outlet
nba shop
Air Max Femme
kate spade outlet sale
breitling watches for sale
Nike Air Max LTD
Nike Schuhe Mädchen
mcm outlet
Nike Air Presto
pandora rings uk
michael kors bags outlet
Add Your Link Free
Nike Air Jordan
boulder shoes sale
Black Friday Ads
small business
pandora jewelry charms
Oakley Sunglasses
prada factory outlet
kate spade online sale
Air Max BW Femme
goose outlet sale
buy under armour stock
adidas yeezy boost 350
omega watches for sale
Nike Free Run
Nike DUNKSB
shoes sale
ugg boots outlet
louis vuitton outle sale
abercrombie canada
Air Jordan
Air Max 90 Femme
puma shoes online sale
pandora necklace sale
louis vuitton bags
chrome store
ray ban polarized
puma sneakers online store
louis vuitton outlet store
kate spade bags store
michael kors factory outlet
vętements de mode
Coach Outlet
prada outlet online
pandora rings
eznara
pandora rings uk
rayban glasses
prada sale
Nike Air Max Lebron 10
ray ban outlet online
Online Oyun
kate spade outlet online sale
Louis Vuitton USA
the beat
pandora earrings on sale
nike running
timberland boots sale
Nike Schuhe
puma sale
coach factory outlet
michael kors online
chanel bag
birkenstock canada sale
ray ban glasses frames
kanye west shoes sale
pandora rings
Nike Air Max 90
moncler jacket
coach factory outlet online store
evbid
diesel watches for men
Air Max 90 Enfant
ray ban justin sunglasses
chrome hearts
timberland shoes online sale
pandora charm necklace
puma sneakers sale
louis vuitton online
swatch store
Dreamland Jewelry - Official
Air Jordan
Nike Air Max TN
Green Cleaned
Wedding Rings- Official
Prada Sunglasses - Official
Diamond Rings - Official
ugg
nike jordan
mk,australia
outlet sale online
coach usa
school bags online store
Burberry Shirt - Official
moncler jacket
nike huarache shoes
louis vuitton bags
tiffany
Nike Air Max
chrome hearts jewelry
Air Max 90
michael kors bags
mode damenschuhe
ray ban clubmaster sunglasses
sunglasses hut
ermes bag for sale
handbags online
Jewelry Armoire - Official
rayban sunglasses
Nike Blazer
Nike Free Homme
pandora bracelet
louis vuitton bags online sale
pandora bracelet
kate spade official
celine outlet
sac louis vuitton
Air Max 95 Femme
payless shoes outlet sale
Nike Air Jordan Femmes
[/b]
oakley outlet sale
burberry outlet sale online
school bags store
Abercrombie Nederland
sunglasses online
Nike Blazer Homme
puma shoes online store
under armour outlet store
Ray Ban Outlet store
Lunette Oakley Ducati Scalpel en soldes
ups tracking number
payless coupons
ray ban sunglasses outlet sale
michael kors bags
payless shoes store
nike chaussure
rayban wayfarer
hermes belt men
[b]80's,eighties fashion
louis vuitton
birkenstock australia
CHanel Factory Outlet
ugg outlet sale
Family Name Research
Nike Jordan Shoes
adidas yeezy boost
Doxycycline
Nike Air Max Light
new yeezy shoes
kate spade australia
Pembesar Penis
KD 8 shoes
AIR MAX LTD 2
coach bags
puma sale
kate spade wallet
coach handbags
ugg
michael kors bags
gucci women watches
payless
China Wholesale
ray-ban outlet
Nike Air Max BW
Burberry Australia
louis vuitton sale
birkenstock sandals online
Nike Air Max 90 Damen
black friday online
gold michele watch
nike outlet sale
Nike Air Max 95
pandora charms sale
michael kors handbags sale
burberry bags outlet on sale
michael kors shoes outlet
coach outlet online sale
birkenstock sandals sale
kay jewelers
Prada bags
coach handbags
Brighton Jewelry - Official
Pharmacy Discount Network
hermes uk
skechers shoes sale
kate spade purses outlet sale
Louis Vuitton Outlet Online
longchamp outlet online
puma outlet sale
rayban wayfarer
mens sunglasses
fulam shoes sale
ray ban shop sale
Nike Air Max Flywire
chaussures asics homme
Jared Jewelry - Official
Air Jordan 1
Air Jordan Fusion
coach australia online shop
pandora rings sale
pandora bracelet
asics gel kayano
ugg slippers sale
tạp chí ẩm thực
balenciaga outlet online store
Premier Jewelry - Official
search
pandora rings
Jordan Fusion Homme
Nike Air Max 2017
rayban prescription glasses
chrome hearts
prada outlet online
kate spade bags
birkenstock sandals outlet sale
rolex watches for men
louis vuitton shop
ray ban sale online
louis vuitton factory outlet
Air Max Homme
north face outlet sale
official prada site
ray ban wayfarer
cartier watches for men
ray ban outlet on sale
louis vuitton sale
ray ban sunglasses sale
coachs outlet sale
Nike Air Max TN Femme
black friday ads
pandora charms uk sale
burberry outlet store
puma online store
Nike Free,Nike Shox
Louis Vuitton outlet
coach factory outlet sale
Nike Air Max 90
Jordan Aero Mania Homme
adidas online
Nike Air Max Lunar 90 Damen
kate spade bags outlet
louis vuitton outlet sale
baseball jerseys
coach sale online
prada outlet online
Air Max TN Homme
rayban aviator
Nike Air Griffey Max Homme
Cheap Ray Ban
school bags online sale store
seiko automatic watches
hermes belt for sale
birkenstock gizeh sale
mk outlet online
Nike Air Jordan Homme
Nike Air Max TN
mk outlet online store
michael kors bags on sale
michael kors bags
hermes bag birkin
Air Jordan 4 Femme
puma suede online
2015 Nike Dunk
Air Jordan Femme
pandora charms sale
Nike Air Max 95 Homme
lzm9.27
#9189970 - 11/17/17 08:57 AM Re: michael kors factory outlet [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
abercrombie and fitch
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
#9235954 - 01/21/18 09:12 PM Re: michael kors factory outlet [Re: chenlixiang]
Andada
colts jerseys
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
nfl jerseys wholesale
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
discount oakley sunglasses
buffalo bills jerseys
fitflops sale
polo ralph lauren outlet
canada goose jackets
nike huarache
seattle seahawks jerseys
jaguars jersey
Moderator:  Professor Paki
