Page 1 of 6 12345>Last »
#3380440 - 01/12/09 08:00 AM Current S2K Build Inside.
SiAdam Moderator Offline
I'll try to keep this updated from time to time to for you guys.
So far I'm in parts gathering mode, with a few things installed @ this point.
My goals are somewhere in the 400-450 range on pump, and then a little over 500 on 110.
To do this, I'll enlist the help of these parts.
Tial 44mm vband w/g w/black housing on .5bar (7.25psi)
Tial 50mm bov w/alum mounting flange black housing on 11psi spring
GT3076R Turbo + jet coating hot housing
Pfab, EL Top Mount Manifold
ARP Manifold Bolts & nuts
Manifold Gasket
Comp Stage 4 Clutch
1000cc Bosche Injectors
Walbro 255lph HP pump
Liquid Filled Fuel Pressure Gauge
AEM EMS
AEM UEGO
AEM Serial Guage
AEM Boost Solenoid
3bar Map Sensor
Modifry's ECT fix.
Precision I/C
NGK BKR8EIK
Couplers
T-Bolts
3” exhaust piping
4bolt Flange
Mufflers x 2
Resonator
3.0” Alum I/C Pipe
A-Pod
Tuning (SlowMo)
Oil Feed -4an
Turbo Restrictor
Oil Return
Oil Return fitting
Sandwhich Adapter
Coolant Feed & Return
Vacuum Manifold
Misc. metal for catch can setup.
Fittings & line for catch can & batt box.
Battery Reloc. 2ga.
Battery
Magnetic Oil Drain Plug
A/C Relocation Lines
New Alum. Radiator
Marked off is what I have bought already.
Edited by SiAdam (03/27/09 12:53 PM)
#3380455 - 01/12/09 08:14 AM Re: Current S2K Build Inside. [Re: SiAdam]
Some pics to occupy your time.
Mounted the cooler.
gt3076r w/a .82 exhaust housing.
The turbine housing got sent off this week to be jet coated black.
Pulled the fender off last night to do some clean up and to keep it from getting damaged while I work on it.
More to come.
#3380539 - 01/12/09 08:58 AM Re: Current S2K Build Inside. [Re: SiAdam]
00OldSi Offline
Loc: DC
Looks good bro!
Stock compression?
#3381085 - 01/12/09 11:51 AM Re: Current S2K Build Inside. [Re: 00OldSi]
 Originally Posted By: 00OldSi
Looks good bro!
Stock compression?
Yes Sir.
\:D
#3382561 - 01/12/09 05:47 PM Re: Current S2K Build Inside. [Re: SiAdam]
jcoosi Offline
Loc: TN
Have been seeing your threads in other places looks like a nice street ride.
You can get them Odyssey batteries from password jdm like cft were using on the red s2k they just finished.
#3382836 - 01/12/09 07:22 PM Re: Current S2K Build Inside. [Re: jcoosi]
lol, I've been whoring up H-T & S2Ki..
I contacted CFT about those same batteries from the thread on H-T, but they were $165 & $195 if remember correctly. I decided I wasn't going to pay that for a battery.
So with that said, I looked around and found one for 1/2 the price approx $80 bucks I bought today and hooked up this evening. Fired it right up..so we shall see if it works or not.
My clutch arrived today as well.
#3383096 - 01/12/09 09:02 PM Re: Current S2K Build Inside. [Re: SiAdam]
jcoosi Offline
Loc: TN
Yeah I paid a little over 100 bucks for the one I had on the Si and it ended up going bad out of warranty.So I went to the local battery store and got one that compared to the Odyssey and was half the price.
What clutch you end up going with caarbon on carbon?
And any pointers for pulling the fenders?HAHA
Edited by jcoosi (01/12/09 09:08 PM)
#3383392 - 01/12/09 10:57 PM Re: Current S2K Build Inside. [Re: jcoosi]
Clutch is a Competition Clutch, Stage 4. I bought it from Jeff (evans-tuning) Best deal I found online was $565 shipped I think. He said it's the one he runs in all the s2k's he tunes.
The fenders are easy actually.
I think you have to pull the front bumper to get to the 2 bolts underneath the headlight..
Other than that, there are 5-6 on top in the engine bay, easy enough, and then 3 underneath you hahve to lay on your side to see. I had undercoating on mine I had to scrape off so the socket would get a good bite.
Then only 2 more inside the door, extension and you are golden, 10mm.
Don't forget to unplug the little light before you yank it off the car..lol.
#3383454 - 01/12/09 11:21 PM Re: Current S2K Build Inside. [Re: SiAdam]
Pics of said clutch.
Competition Clutch Stage 4.
#3383819 - 01/13/09 07:45 AM Re: Current S2K Build Inside. [Re: SiAdam]
00OldSi Offline
Loc: DC
Awesome clutch... same one I have for the Si.
You keeping stock internals? ... run a thicker HG = -)
#3383833 - 01/13/09 07:54 AM Re: Current S2K Build Inside. [Re: 00OldSi]
taurusboy Offline
Loc: NC
Damn man, can't get away from boost!!!!
That looks like it'll be a nice setup for sure, give your old Si a run for its money ;\) (that is if its still on same setup)
#3384608 - 01/13/09 12:17 PM Re: Current S2K Build Inside. [Re: 00OldSi]
Nah, no h/g. Gonna see what it will make on stock compression.
#3384618 - 01/13/09 12:19 PM Re: Current S2K Build Inside. [Re: taurusboy]
My Si is in my cousins hands...he is building it to do some serious work, 700whp worth of work in fact...
I'd think this car would take the Si on the same whp level do the rwd/fwd, as they both way pretty much teh same.
#3387700 - 01/14/09 07:50 AM Re: Current S2K Build Inside. [Re: SiAdam]
SamuraiSam Offline
Loc: Bellingham, WA
dude, I didn't know you were so far along, you've been leaving CSI out of the loop! WTF
Nice parts selection.. although 1 question
"AEM UEGO"
Did you get the AEM w/built in wbo2, or an AEM EMS and separate wideband??
if seperate wbo2.... insert facepalm.jpg here
after my years of ranting!!!!!!!
additionally. Very nice pictures, and those rims are absolutely fucking amazing on your car.
#3387736 - 01/14/09 08:07 AM Re: Current S2K Build Inside. [Re: SamuraiSam]
"AEM UEGO"
Don't worry Sam, the wideband unit is built in
The work thats been done has only been over the last week. I'm more or less @ a standstill now, b/c my manifold won't be in for another month or so.
I can still move it around under it's own power for now..so I'll be chilling doin little things until I put it up on jackstands for the manifold/clutch/exhaust work in the following month.
You guys otta know I would never forget ya!!
#3391918 - 01/15/09 06:50 AM Re: Current S2K Build Inside. [Re: SiAdam]
denham Offline
Loc: Macungie
nice work!
#3410596 - 01/21/09 01:45 AM Re: Current S2K Build Inside. [Re: denham]
dude this is pretty sick.
i hate you
#3410839 - 01/21/09 07:56 AM Re: Current S2K Build Inside. [Re: Euphoricuck]
i hate you
#3410861 - 01/21/09 08:20 AM Re: Current S2K Build Inside. [Re: SiAdam]
94cxhatch Offline
Ask me how I wont sell you a car.
3.0 inch IC piping...overkill?
http://www.midwest-autoworks.com
#3410867 - 01/21/09 08:26 AM Re: Current S2K Build Inside. [Re: 94cxhatch]
2.5" on the hot side, I was thinking 3" on the cold side, but it doesn't look like there is much room to work with, so I might be forced to do 2.5"
Just have to see.
#3411190 - 01/21/09 10:16 AM Re: Current S2K Build Inside. [Re: SiAdam]
denham Offline
Loc: Macungie
i love it when photographers do builds, such nice pics of progress
#3417696 - 01/23/09 09:29 AM Re: Current S2K Build Inside. [Re: denham]
Pics as promised.
Aem Serial Gauge.
Gauge in the apod (rough fit)
Aem EMS
#3417821 - 01/23/09 10:09 AM Re: Current S2K Build Inside. [Re: SiAdam]
denham Offline
Loc: Macungie
i love the aem ems system, it really works great in my friends fox body
#3417822 - 01/23/09 10:10 AM Re: Current S2K Build Inside. [Re: denham]
denham Offline
Loc: Macungie
specially with the EPM and the ls1 coilpacks
#3418141 - 01/23/09 11:49 AM Re: Current S2K Build Inside. [Re: denham]
I have bascially nill experience when it comes to AEM. My buddy had it in his Evo..lol.
Should be a little learning curve, but from what I've seen already it seems pretty cool. I'm excited.
#3418192 - 01/23/09 11:59 AM Re: Current S2K Build Inside. [Re: SiAdam]
denham Offline
Loc: Macungie
boost by mph is awesome for street cars.
15 dollars for a gm boost control solenoid.
if you have some questions i could do my best to help you out.
are you running map? or a large mafs?
#3418238 - 01/23/09 12:12 PM Re: Current S2K Build Inside. [Re: denham]
tony tone Offline
Loc: miami
looking great adam... can't wait to see it run.
#3418278 - 01/23/09 12:24 PM Re: Current S2K Build Inside. [Re: denham]
I bought the AEM boost solenoid with the package. It was 50 bucks. Plug and pray baby..lol.
I bought a 3bar map sensor, plugs right in to where the stock em one was.
#3420327 - 01/24/09 03:00 AM Re: Current S2K Build Inside. [Re: SiAdam]
denham Offline
Loc: Macungie
does this 5.0 engine bay look silly?
#3421197 - 01/24/09 06:19 PM Re: Current S2K Build Inside. [Re: denham]
Why do you ask?
#3421707 - 01/24/09 09:46 PM Re: Current S2K Build Inside. [Re: SiAdam]
Here is some wiring I am working on.
I am relocating the battery/fuse box/abs computer.
I plan on putting my catch can there.
#3422046 - 01/24/09 11:26 PM Re: Current S2K Build Inside. [Re: SiAdam]
denham Offline
Loc: Macungie
nice! nip tuck
#3437117 - 01/30/09 12:12 AM Re: Current S2K Build Inside. [Re: denham]
cua0 Offline
Loc: Red Deer, Alberta, Canada
it'd be a real bear if you ever had electrical problems, though it seems you don't mind taking the fenders off, i'd hate to have to strip the front end to replace a fuse lol
#3437498 - 01/30/09 07:55 AM Re: Current S2K Build Inside. [Re: cua0]
I've thought about that, and there is really no other option aside from moving it around and making it look haphazard.
Out of the 3 honda's I've owned, I've NEVER had to replace anything under teh hood ever.
#3444079 - 02/01/09 09:00 PM Re: Current S2K Build Inside. [Re: SiAdam]
94cxhatch Offline
When did AEM change the color of thier EMS?
Great turbo choice!
Same one I had when I made 419@9 psi! with my full race manifold
Let me know if you are interested in one of these
Air pump block off plate:
Air pump block off plate for the people running AEM EMS and got rid of there Air pump injection system. Cleans up the engine bay nicely...
20 shipped
I have 10 left from an order i had to place for 15 minimum..
and yes i know, i forgot to hit macro
Pics installed for reference
