#2209720 - 01/10/08 08:48 AM How-To: 99-00 Si Gauge Cluster Color Change
Buzzbomb Offline
Loc: Bryan, Ohio, USA
Below is a brief how-to on changing your Si gauge cluster color. This is meant as a companion to the Changing Climate Control Colors on Civics by: Neo Noodle, which goes into more detail on LED wiring, resistor selections and voltage requirements.
Disclaimer:
This how-to is not for beginners, this mod is not reversible and you have a very good possibility of ruining something. You also need to have some experience soldering. This mod should not be rushed. I did this mod while my car was in storage over the winter and I took my time. Now on to the how-to.
Begin by removing and disassembling your gauge cluster. I'm not going to go into how to do this as there are many resources out there that outline this procedure. Anyways, if you can't do this first step without directions and pictures, then you shouldn't do this mod anyway.
The first thing I did was remove the colored backing on the gauge faces. Behind the black lies orange coloring that needs to be removed for the alternate color to show through. The best thing for this is an automotive paint reducer. You can find this at an automotive paint supply store. I used DuPont 7175S Basemaker. I tried using nail polish remover but it was just way too slow. The reducer works very fast and did not melt the plastic.
Originally I removed the area under the redline protion , but when I tested it, it didn't light up evenly. So I painted over it.(which didn't affect anything because that area never lit up anyway)
Next are the LEDs. When I first did this mod, I used standard LED's. A couple years later, I started seeing what is called "Inverted" LED's. If you're looking at a profile, the top is squared off instead of rounded. They also have a small inverted cone on the top.
These are MUCH MUCH better than the standard LED's as they actually disperse the light in all directions vs. concentrated in one direction like that standard LED's (I would suggest using the inverted type in the climate control also)
(Since I didn't want to completely redo my cluster, I took out my Dremel and cut off the tops of my round LED's. It produced the same results as the inverted ones. So if you already have rounded LED's here's a cheap solution.)
I created chains of LED's to sit behind each gauge. I pointed the LED's down as to try and keep "hot spots" from forming and have more even light dispersion.
I then wrapped each chain in blue saran wrap to help further the light dispersion, however I do not believe this to be a requirement.
Power and ground wires were fished through the back using holes where the bulbs used to be and tied together. Tap into the stock wiring harness for power. The ground go to the back of the cluster itself. Find a screw with a (-) sign next to it.
I removed all light bulbs EXCEPT for the two that are on the top of the cluster that illuminate down onto the gauges. This helps keep the gauge needles lit at night.
Test, re-test, then test again to make sure all LED's are working and you have even light distribution throughout the cluster. Reassemble the cluster and test again. Install and go.
Interesting Note:
When I first started the project, I thought that the blue LED's would mix with the red of the "Si" logo and red tabs on the gas and temp sides to make a purple color. So I tested this before going any further. Oddly enough, this didn’t happen. The “Si” logo and red tabs glowed red just fine. This made it much easier to do since I could use all blue LED's instead of two colors.
Edited by Buzzbomb (02/23/08 07:19 PM)
Authorized AMSOIL Dealer
00' Si Turbo
02' WRX Wagon XPT Stage2
13' Tribeca 3.6R Limited
#2214036 - 01/11/08 10:26 AM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: Buzzbomb]
jellydoughnutt Offline
buzz ive always loved your how-to's and this is no different. another one on the list of shit i need to do, thanks man!
#2215449 - 01/11/08 03:55 PM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: jellydoughnutt]
kyden Offline
Loc: Providence, RI
btw the original link is broken.
#2217172 - 01/12/08 08:32 AM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: kyden]
Buzzbomb Offline
Thanks, much appreciated.
Fixed
00' Si Turbo
#2474355 - 03/25/08 11:17 PM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: Buzzbomb]
NCSkylineR33 Offline
Loc: Hubert, NC
that is some nice work, props!
95 Skyline R33
93 RX-7 Type RII SE
#2642496 - 05/15/08 05:39 PM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: NCSkylineR33]
EM1 Buckeye Offline
Very nice man, I was just wondering exactly how long it took you to do?
#2672739 - 05/27/08 07:48 AM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: EM1 Buckeye]
Buzzbomb Offline
It's hard to say really. I did it over the winter while my car was in storage. I took a couple hours here and there or whenever I had some free time. A lot of time was spent just thinking how I was going to it.
If I had to guess, at least 8 hours.
00' Si Turbo
#3390199 - 01/14/09 07:19 PM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: Buzzbomb]
Japanman2009 Offline
Nice where did you get the LEDs?
#3552821 - 03/11/09 09:12 AM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: Japanman2009]
Buzzbomb Offline
I got mine from eBay.
00' Si Turbo
#3553394 - 03/11/09 11:55 AM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: Buzzbomb]
furball Offline
Do the LEDs dim/brighten up like normal, using the dimmer knob? Or do they stay a consistent brightness?
#3557036 - 03/12/09 11:25 AM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: furball]
Buzzbomb Offline
You know, I don't know off the top of my head. I never mess with the brightness. I would imagine it would since I tapped into the wire for the gauge lights. When I get the car out of storage, I'll have to check.
00' Si Turbo
#3773103 - 05/28/09 10:40 AM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: Buzzbomb]
CivicRacerExR Offline
Loc: Landisville, PA, USA
wow that is nice. I did the original remove the paint from the backs of all the numbers and had the hotspots (back in 2001), hated it so much I got new ones. So purchased all new gauges and just removed the Si \:\)
Sponsored by: KAM Racing Sports, Falken Tires, Progress Technology, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
#9235987 - 01/21/18 09:18 PM Re: How-To: 99-00 Si Gauge Cluster Color Change [Re: ]
Andada
colts jerseys
coach factory outlet
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
michael kors handbags sale
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
true religion outlet
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
nfl jerseys wholesale
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
cheap basketball shoes
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
discount oakley sunglasses
buffalo bills jerseys
fitflops sale
polo ralph lauren outlet
canada goose jackets
nike huarache
seattle seahawks jerseys
jaguars jersey
