Page all of 3 123>
#105934 - 07/25/05 07:17 PM B20B/B16A2 Frankenstein Build. . .Numbers In!!
b6ixteen Offline
Loc: Florida
I am in right lane for each. Overall I am happy with the times and I know I am capable of much better (see 60'), so I will just do some more practising with this new setup.
vs Mustang GT. . . ____________________ vs Integra LS (think stock). . . ___________vs Fully gutted EG w/stock B16
My setup: If its not mentioned, its stock.
Block: B20B
ACL race bearings
Eagle H-beam rods w/ARP rod bolts
Wiseco 10.8:1 pistons
KMS block guard
Head: Stock B16A2/PR3
Tranny: Stock S4
Toda lightened flywheel (~10lbs)
Some stage 1 clutch.
Misc.: AutoZone 3" SRI w/ K&N filter
DC Sports 4-1 (not 2.5" collector)
2.5" exhaust piping back
ARP headstuds
Golden Eagle VTEC conversion kit
EnDyn crankase breather kit
RC 370cc injectors
B&M FPR and fuel pressure gauge (set at 50psi)
Autometer oil pressure gauge
GSR water pump, oil pump, timing belt
OBD2b to OBD1 conversion harness
Chipped P28 w/Crome EMS (AFR WOT street tuned)
I am in the process of doing this build and ever so often, little questions arise and I just need to know if I am on the right track with it. I thought of doing this build ever since I got my B16 a year ago. I started acquiring parts couple weeks ago but it wasn't until last week when my motor blew (one week after hydrolocking) that I see the need to hurry the build. I need the car to be a everday driver, occasional drag car. . .maybe once every two months. I am concentrating on the bottom end for now, will do the head later on.
Parts I already have:
B20B block. . .stripped bare leaving only crank.
B16A2 motor. . .block has hole, head is stock and ok.
New GSR oil pump.
KMS block guard.
GSR water pump, timing belt and seals.
Eagle H beam rods (ordered and on its way).
Chipped P28 and Hondata S200. . .no conversion harness yet.
Parts to be ordered:
ARP headstuds
Golden Eagle LS/VTEC conversion kit
Wiseco pistons. . .not certain of CR yet.
ACL racing bearings.
What am I missing as far as getting the motor together is concerned?
What compression pistons should I get if I want to attain 11:1 with the B16 head?
Does all B-series motors use the same bearings. . .main, rods, thrust washers?
All and any help will be appreciated, thanks.
Edit: Placed times and current setup to 1st page. Original is on page 3.
Edited by b6ixteen (10/16/05 02:21 AM)
#105935 - 07/25/05 09:19 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
surubasi00 Offline
Loc: VA
call honda and compare part number with the engines i cant remember but im sure the bearings are the same....call and check...then call someone who carries ACL and get their bearings, they are cheaper. Call arias or weisco directly or go o their website, they have all those specs for b20 motors. You need a head gasket...check out the Poor mans type R post at the top...that should help you out a lot...good luck, its not that hard to do
Dave
Turns out my dog is allergic to peanuts. - FortCollins
#105936 - 07/25/05 10:46 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Thanks, the GE LS/VTEC kit comes with a headgasket thats why I didn't mention it. The reason I asked about the bearings, is that someone from a popular tuner shop in S. FL told me to make sure I use B16 bearings. I will find out from Honda tomorrow.
#105937 - 07/27/05 02:10 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Am I the only one with this build?
#105938 - 07/27/05 03:16 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
Dr. BrokenLimits Moderator Offline
Loc: Austin, TX
you are using stock rods? Thats going to be your incredibly weak link right there.
Nm saw you have Eagle Rods.
Everything appears to be in order. Make sure you have a header that clears a 1.8 block. The B16 header typically will not.
What ECU are you going to run?
Edited by BrokenLimits (07/27/05 03:17 PM)
/Brandon
#105939 - 07/27/05 03:30 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
surubasi00 Offline
Loc: VA
you aren't the only one...but it's typical to come here, get the information, and then they never come back and post how stuff went...oh well
Dave
#105940 - 07/27/05 08:04 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Ok, I just took off the B16 header today. I am going to run a P28 ECU. I will be sure to keep everything here just so that people can correct me an stuff. I am just trying to get feedback, and when the dyno numbers are in, will put em up as well.
Thanks.
#105941 - 08/01/05 07:37 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Update. . .these babies came in today, coated like the Rs. Ordered the rods before but they are taking kinda long, suppose to start this weekend on the build.
#105942 - 08/01/05 10:42 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
surubasi00 Offline
Loc: VA
oh so fucking pretty,,,,im jealous
Dave
#105943 - 08/01/05 11:35 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
what CR did u decide to go with on the pistons?
2000 EBP Si 181.5whp, 119wtq- All Motor B16
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105944 - 08/02/05 12:24 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
10.8:1, I think the VTEC head adds like 0.2 then I would be up near 11.1. Then later on with flat valves and thinner gasket, I might get up to 11.5:1. I am trying to keep it really street, even though in FL we have 93 octane.
#105945 - 08/02/05 01:30 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
yea, u'd be plenty fine w/ 11.5:1 on 93.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105946 - 08/02/05 10:21 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Yeah I figured so but I was more concerned with the longevity of the stock B20 sleeves on such high compression. Thats why I didn't really try to get it up greater than a 11.5:1.
#105947 - 08/02/05 12:04 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
ahh, yes the sleeves will be a weak point. I saw that ur getting eagle rods at least but It mentions nothing or rod bolts, make sure to get arp rod bolts.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105948 - 08/02/05 01:12 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Yeah I think the eagle rods come with ARP rod bolts.
#105949 - 08/02/05 06:04 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
CivicVTi Offline
Loc: Athens , Greece
B16 and b18 have different rod bearings. I am not sure on the main ones. I do not know about b20. What cams do you plan to use? What is the max rpm you plan to rev your engine?
Honda Civic VTi '95 EG6 hatch (stock B16A2) B18C6 specR swap (Euro)
#105950 - 08/02/05 06:44 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Thanks for the answer on the rod bearings; yes I did find out they were different and ordered race bearings for the B20. The entire head is stock for now, plan to do BC3+ or Blox B when head is done. Max rpm is possibly 8k, thats only for track days maybe, won't push it like the B16 cause I know it can't hold revs as good. More likely 7k if I have to rev that high daily.
#105951 - 08/02/05 10:20 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
surubasi00 Offline
Loc: VA
yeah you can do those cams with aftermarket pistons NO problem...the valve reliefs are bigger
with the bc3's you are going to need to rev highet than 8k...just fyi
Dave
#105952 - 08/03/05 12:59 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
I thought they stopped making power at like 8500rpm; thats why I want to stick to mild stage 1 cams, cause I don't want to be revving like 9k+ to be making use of a cam's full potential. Good heads up though, thanks.
#105953 - 08/03/05 04:47 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
CivicVTi Offline
Your engine is capable of 8000rpm no problem. If you want to rev it higher you could install a block girdle for added strength. Just like the b18 engines. If I were you, I would also stick with stage1 cams. Also do not make the mistake most people do and use an ITR/skunk2 intake manifold. Keep the stock B16 intake manifold as it performs better up to 8000rpm. A 62-64mm throttle body wouldn't hurt though.
#105954 - 08/03/05 09:02 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
I'll keep the IM and TB info in mind.
#105955 - 08/03/05 12:28 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
BC3's will be great for ur motor. It will make tons of torque & not peak at that high of rpms. Check out jwyoung's build. Its a b16 peaking at 7800rpms on bc3's. Ur motor is bigger & higher CR then his so it should peak even lower. & I would also keep the stock intake mani cuz like vti said, it tends to be best under 8000rpms.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105956 - 08/03/05 03:11 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
I saw the dyno he has and its really impressive, but I am not certain of his mod list. Right now I am relying on the power from the ~2.0 displacement, I will get the motor tune without the head work. Cams and stuff is for later on, so basically it will be a partially built bottom end with stock head.
#105957 - 08/08/05 10:37 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Does anyone know to what motor specs the bolts for this build should be torqued? In other words, should I use the 96-00 Honda Civic Helms manual or the Acura Integra 94-01? I think GSR/ITR specs but not certain, need to be.
#105958 - 08/09/05 12:48 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
jwyoung Offline
Loc: Ca, USA
whoa this thread is new to me... dude, i'm jealous.. i need to work on my block.. good luck
Edited by jwyoung (08/10/05 03:45 AM)
00' E95P Si 178whp, 122tq on 89 octane - B16 all motor
#105959 - 08/09/05 07:50 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
You alread have an impressive motor . I am just trying to get one myself. So anyone know about what motor specs bolts should be torqued?
#105960 - 08/09/05 09:31 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
I'd imagine they're all the same or very similar, but
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105961 - 08/11/05 03:40 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
DPK/Honda Offline
Loc: W.C. All over the world.
I have heard that b20/b16 setups require a crankshaft ventilator (endyne, etc) I am not sure if this is only required for forced induction but I'd look into it, i think they're fairly cheap too. I know I have heard a few people on Club si say that a crankshaft ventilator is a must for a b20/b16. Anyone?
"You have to face death and survive to feel more alive." -Canibus R.I.P: 2000 NBP SI: Turbonetics T3/T04E 309whp, 213lb/ft@15psi
#105962 - 08/11/05 06:29 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
I never heard this but I am thankful you mentioned it, I will seek out getting one. Anything that will prolong this motor's life is welcomed. I just read about the kit on "The Old One" and it does seem like something worth investing in. Its listed for $164, I was going to get a lightened flywheel but this seems to be more of an investment, where longevity is concerned.
#105963 - 08/12/05 07:19 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
Ohjolt2 Offline
It will run with out a catch can just fine. But it would be a good idea to set out up. My motor has been running over a year with out one. i dont have the vent line on the valve cover hooked up either.
Jake 88 CRX SI CRVTEC 13.8 1/4
#105964 - 08/12/05 10:15 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
I wasn't planning on doing a breather for the valve cover still. Don't think its as important as the one for the block. I see your sig says 13.8 in the 1/4 Ohjolt2, whats your mods and how much does your car weighs?
Edit: Forgot to mention I went to the machine shop today to have the pistons/rods assembled only to find that one of the locks was missing, so one piston pin is loose in one of the piston/rod assembly. Could I just go to the Honda dealer and ask for a B20 piston lock and use it? I just want to know if the OEM lock will be just as good as the aftermarket one. Thanks.
Edited by b6ixteen (08/12/05 11:06 PM)
#105965 - 08/13/05 10:31 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
Ohjolt2 Offline
Piston lock? Piston pin? You mean the wrist pin? Dont OEM pistons and rods use a press fit system that isnt compatable with any aftermarket stuff? Anyway my car is gutted so i guess its pretty light. stock bottom end and stock b16 head. no internal mods yet. time was ran in falken st615's.
#105966 - 08/13/05 11:11 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
I am referring to the piston lock also called a C-clip. Yes I recently heard aftermarket ones are different, but thanks for the headsup, I was so ready to call the Honda dealer to get this thing asap. But I found a local dealer who stock aftermarket pistons n stuff so I will contact them next week (close on weekends).
Thats a good time considering you have no internals. Is this B20B or Z?
#105967 - 08/14/05 06:55 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
Ohjolt2 Offline
Never bothered to look, engine was in the car when i bought it. Car was kinda fucked up in a lot of areas when i got it. So i had alot of work to do on the inside and unfucking wireing nightmares and stuff. Then i left for iraq, i never bothered to get to far into the engine. Its gutted though so its a few 100 lbs lighter than stock.
#105968 - 08/15/05 11:41 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Got the clip and all pistons/rods assembly are ready to go. I need to know is resurfacing the B16 head is a must??
I am pulling the motor tomorrow, I am still waiting on the GE conversion kit (suppose to come Wednesday), a flywheel and the Endyn crankcase breather kit. Block is ready to assemble. Hoping to have the car running by weekend.
#105969 - 08/17/05 03:02 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
jwyoung Offline
Loc: Ca, USA
edumicate me... can you point me a direction or let me know why you chose a b20b? why not a c5? or c1? pros cons? price.. blahblah.. anything
#105970 - 08/17/05 09:42 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Pros:
B20 has longer stroke, bigger bore. . .hence more displacement. Like getting a stroker kit.
Block is extremely inexpensive.
Easy way to get power and torque. Though its a bit involved if you want to do it right.
Cons:
Sleeves are thin, and are likely to crack under very high pressure, ie. high rev, nitrous, turbo, too high CR.
Not able to rev as high as a C5 or C1 block in stock form.
I am sure there are some more but those are essentially the ones IMO.
#105971 - 08/18/05 09:06 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Update: Finished bottom end internals about 3:30am this morning at home. Going to the shop now to do some more.
#105972 - 08/18/05 01:24 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
VictoriaSiR Offline
Loc: Victoria, British Columbia, Ca...
Fucking sex!
But is a Block guard gonna be enough for even 8000 rpm @ 11.5? I knwo you were saying you'd only be going there for track days. I have been looking into doing the same but sleeving the block instead.
#105973 - 08/18/05 01:38 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Actually I have seen people on higher CR without a block guard. I won't be at 11.5 just yet; that will be after head work, this is going to be about 11.1. If you have the money to sleeve the block, by all means do it. I didn't have it. . .and now I am crunching cause school starts next Monday and I didn't know; thought it was the following week.
I am now waiting on the Endyn kit, which I want to get before I drop the motor back in cause I hear installation is a bitch with the motor in the car. And should be getting a Today flywheel tomorrow.
#105974 - 08/18/05 03:50 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
jwyoung Offline
Loc: Ca, USA
wow... that's hot.. what's the cost break down to be like?
#105975 - 08/18/05 06:35 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Entire thing running me about $2000, considering I doing it, I don't pay for labour.
#105976 - 08/18/05 09:24 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
surubasi00 Offline
Loc: VA
awesome dude..
good luck with it all....and contrary to homeboys advice,,, the type R mani is much better than the fucking b16...you will see when you get one...the b16 is fucking tiny
Dave
#105977 - 08/18/05 11:09 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Thanks. . .I'll probably get the manifold when its time for the head. Right now I am having some issues. Went to get the oil pan and pick up from the shop to find that the pickup wasn't there. Tried the GSR but it was too short and can't find an LS in time so I might just have to go to the dealer tomorrow. Boy somn would have to happen, can't just go smooth at all.
#105978 - 08/19/05 01:36 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
very sweet, seems to be coming along nicely!
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105979 - 08/19/05 07:57 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
Loc: Austin, TX
looks a lot like mine congrats man.
/Brandon
#105980 - 08/19/05 08:30 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Thanks guys. Wow thats some dome on those pistons
#105981 - 08/19/05 10:24 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
Loc: Austin, TX
12.7:1
/Brandon
#105982 - 08/19/05 12:04 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
That would have massacred the B20 sleeves, looks good though.
#105983 - 08/19/05 01:49 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
jwyoung Offline
Loc: Ca, USA
.. what kind of power we looking at b6ixteen?
#105984 - 08/19/05 02:55 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
surubasi00 Offline
Loc: VA
i would put him at about 210
Dave
#105985 - 08/19/05 06:33 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Yeah, possibly ~187whp and ~150wtq or so. I am not really very big on dyno numbers still. . .I am more interested in seeing what improvements I have made since my last 15.2s B16 run.
#105986 - 08/21/05 08:02 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Ok I have a situation; went to put the head on today. . .didn't pull it off before. Noticed 4 bent valves, two intake and two exhaust. So now I am on the market for valves, just need to replace these ones. So if there is anyone who would like to sell/offer me their used B16 valves, let me know. . .I want some like yesterday. School starts tomorrow and it now seems I won't have my car not even for this week.
#105987 - 08/22/05 01:22 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
Bro, I've got a complete set of my b16 valves cuz i got omni's. U seem cool so just pay for shipping + $10 for my time spent & shipping materials & I'll send u all of them. This is a sweet project u got so I'd like to help u get it finished.
They will be coming from CA though so probably not the quickest shipping, but if u can't find anything else just let me know.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105988 - 08/22/05 09:52 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
PM sent.
#105989 - 08/22/05 04:26 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
jwyoung Offline
Loc: Ca, USA
steve.. ur such a nice guy
#105990 - 08/22/05 08:16 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Yeah I owe him one!
#105991 - 08/22/05 11:22 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
no problem. just trying to help u out so u can finish this project & let us know how it turns out.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105992 - 08/23/05 09:25 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Thanks a lot for the help Steve; I just received the valves from UPS.
#105993 - 08/23/05 11:21 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
cool
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105994 - 08/24/05 10:22 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
More issues with the head; although I was thinking this would happen. So I took out the bent valves yesterday (don't have pics right now), and found the valve guides looking like this. . .
on the intake side, the exhaust ones are damaged also but the intake took a beating. Intake valvles were bent worse than the exhaust ones also.
#105995 - 08/24/05 01:36 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
ouch. any idea why this all happened? how was ur b16 running with these problems?
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105996 - 08/24/05 02:05 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
It happened because and when the engine actually blew, rod snapped so piston loose, hit valves causing them to bend and when they did, they were forced against the walls of the valve guide causing them in turn to crack/break. When the engine blew, I was at about 6k rpm in 3rd so I imagine quite a bit of compression. So I don't think it was crack while the car was running per say; I presume it all happened in a single moment. After the hydrolock though, it wasn't running quite as strong, but it was ok for the while. I never thought this build would get so involved. . .so it will be back to the machine shop for new guides.
#105997 - 08/24/05 02:17 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
dam, that sucks. i didn't even realize that ur b16 blew like that. just though u were building a b20 just cuz.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#105998 - 08/24/05 10:36 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Ooh yeah; I was planning on doing the B20 anyway but not at this point. The engine going just pushed me to do it even quicker. Thats why I am trying to have it done right cause I have no other car but this one.
#105999 - 09/02/05 12:58 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
The motor is ~finished now but it runs like crap, starts with no problems and idles really nice ~650rpm. I think the crappy running is due to the fact I am using the stock Si ECU and injectors. . . it seems this motor wants a lot more fuel so tomorrow I am going to try a GSR ECU and see if that helps, cause the way it runs is just crazy. I feel a little torque from start and then above 2000rpm, it seems like the power just dying. Haven't taken it pass 4000rpm so I don't know what the top-end feels like but right now it needs some work.
Also there is oil leak at the oil pressure switch which needs attention ASAP. I am going to try and remedy that problem and also adjust the valves to see if that helps. I will post some pics later on; I also have a short digicam video of first startup.
#106000 - 09/02/05 01:07 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
sweet! be easy on it & get it tuned asap. its probably running lean as hell, which obviously could be very dangerous.
get hondata, crome... if u dont already & take it to be tuned, for now I'd have them do part throttle tuning to clean up the a/f ratio. Then drive it around to break it in. Then go back for some full tuning.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106001 - 09/02/05 01:35 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
jwyoung Offline
Loc: Ca, USA
dude congrats
#106002 - 09/02/05 01:39 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
I do have the S200 and a chipped P28 but I don't have the conversion harness yet, I was going to break it in with whatever stock ECU will work well and then get it tuned after. It is said that the GSR P72 could be used, even though the motor still requires more fuel than a GSR. And yeah, I am oh so easy on it. . .2000rpm then shift.
#106003 - 09/02/05 01:41 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
dude congrats
Thanks but lets hold that til about 3 weeks to see how things go with it.
#106004 - 09/02/05 01:11 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
if it were me, I'd still have it part-throttle tuned to clean up the a/f ratio. u def dont want some detonation to start going on if its running to lean.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106005 - 09/02/05 08:21 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Yeah I know, more problems more money more problems. Ok, I have a question regarding the Hondata system. I have the base model S200 which has the interface blue box, interface cable, datalog cable and some little chips. Could I just get the conversion harness for the P28 and then add the S200 and tune? Or do I have to have the little chips installed in the ECU for it to work? The guy I bought it from said the ECU was already chipped. . .but I don't really sure. Is there a way to tell on the ECU to know if its chipped and with what; eg. are there specific ICs in it that were not in it as stock, or virgin ECU?
I know thats a lot. . . any help is appreciated.
#106006 - 09/03/05 02:09 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
yes, first u need to buy a conversion harness. u have an 99-00 Si right? So u need an obd1-obd2b harness. Jhpusa.com sells nice ones for very cheap.
call ur local hondata tuner. ask him if he sockets the ecu's for hondata? or if not then does he know anyone around who does?
most likely he does it himself. (i suck at electronics, so this part wont be to technical, but u'll get the idea). drive there. give him ur p28 ecu & the hondata s200. he'll socket the system into ur ecu so that the little red wires w/ the plug on the end will run from the inside of ur ecu to the outside. that plug plugs into the blue box. ur tuner will then also probably burn a base map he feels suitable for ur app & chip it into the ecu or something. then he'll put u on the dyno. do some part throttle tuning. then full throttle.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106007 - 09/03/05 10:12 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Hondata tuner about an hour from me, that is, one that was listed on their site. Its already socketed then cause it has the red/black wire running out the ECU. I'll post a pic of what I have later, I don't have my camera right now.
#106008 - 09/04/05 01:21 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
http://www.importbuilders.com/breakinarticle.htm
u should read this article. it explains why its dangerous to drive it around to "break it in" before u tune it. i just don't want all ur work destroyed cuz u got a sweet motor there.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106009 - 09/05/05 02:00 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Thanks for the article, even though I read it sometime ago, the refresher is good. I am now wanting to go get it tuned quickly but it doesn't make sense until I can get an FPR and some bigger injectors. Well I guess I am at the stage where I am driving to see if anything is wrong. I was really surprised and happy to know that after putting the entire motor together, there was only one oil leak. . .which is now fixed so no oil leaks currently.
One problem thats getting me now is that there is a knocking sound coming from the tranny and I really don't know what it is. . .any ideas anyone? I started the car while on the lift and when the wheels spin freely, you don't hear the sound. But once you are on the road, whether the car is driving or coasting with engine off. . .you hear the sound. I thought it was the axle at first but its not.
#106010 - 09/05/05 10:58 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
A few pictures of work in progress.
HG and ARP headstuds. . .
New IM gasket. . .
Valves Steve sent, seated with new guides.
Head and cams install. . .
GE VTEC kit adapter; with Endyn breather kit nipple to the right. . .
Car on lift after motor went in. . .
After valves adjustment the day after, I changed the valve cover.
#106011 - 09/05/05 12:55 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
that looks so nice. cant wait to c what it puts down. right now ur still using a stock b16 head right, cams & all?
so did u build the thing urself or did someone else do it?
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106012 - 09/05/05 12:56 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
surubasi00 Offline
Loc: VA
dude those pistons look sexy....
did you get the problems sorted?
Dave
#106013 - 09/05/05 04:44 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Yeah the B16 head is completely stock. The only thing I did not do is what the machine shop did, ie. honing block, press in pistons to rods, install new guides and the valves, and tap the head. I assembled the block at home then took it to the shop, where two of my friends helped me with the rest.
There is still a knocking sound coming from what seems to be the tranny. Oil leak has stopped, and got a oil pressure guage yesterday to keep tabs on that. Should be getting and installing a FPR in a few hours.
#106014 - 09/05/05 10:17 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
awesome! nice work!
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106015 - 09/06/05 12:08 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Thanks! Fine misc. stuff to get now include, bigger injectors (thinking 310s), FPR, OBDII - I harness, and <50% throttle tune below 5000rpm.
With that said; I would like to know if there are qualified Hondata tuners in the South FL area. . .West Palm Beach, Fort Lauderdale, North Miami??? I only know of one and its kinda far from me.
#106016 - 09/13/05 02:27 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
jwyoung Offline
Loc: Ca, USA
what's the status?!
#106017 - 09/13/05 10:03 AM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Parked at home waiting on RC310s and a tune. Installed B&M FPR and gauge last week and turned fuel pressure from stock 35psi to 50psi. . .it ran a little better, no bogging at partial throttle below 4000rpm. I am also researching/thinking of Crome for tuning and selling the Hondata S200 I already have.
#106018 - 09/13/05 02:45 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
jwyoung Offline
Loc: Ca, USA
thinking of going chrome because of the ability of tuning it has or the person needed to tune the s200?
#106019 - 09/13/05 08:01 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
From what I have read so far, its way cheaper than Hondata and has the same capabilities, if not more, as Hondata does. The same person who recommended Crome is the same person I was talking to about tuning with Hondata. So if any at all I can sell the Hondata, get Crome, and save some money in the process, I will choose that route. In my estimation, they are all the same until you get into some stand alones like AEM EMS, MoTeC, Haltech etc. the real expensive ones.
#106020 - 10/07/05 03:41 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Ok so here is the deal, car got a WOT tune two days and is running really good as far as I can see. Its tuned with Crome and thats why I am selling the S200. VTEC is set at 5400rpm but the guy said he really wouldn't know the xover that would yield most power without a dyno. Rev. limiter is at 8296rpm but I don't go more than 7500rpm. Right now, only thing set is the AFR, idle, xover etc. I will be dyno tuning in a few weeks to tweak that, get the right VTEC xover and timing. I am also proud to say I am getting at least 32hmpg with light throttle. Don't have to go too much on the throttle to move cause the torque is great. For a stock head, I think it does well, my feeling after I've seen it run is between high 13 and low 14 on the track.
Edit: I know most of you guys won't have anything to say until you see a graph with numbers.
Edited by b6ixteen (10/07/05 03:42 PM)
#106021 - 10/07/05 04:23 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
strsi Offline
Loc: CA
awesome! so is the same guy that is doing ur street tuning now going to be the guy that dyno tunes it also?
I dont know how all u guys get such great gas mileage. Even when I'm really easy on my car the best I can manage is between 23-25mpg. Mostly city driving though w/ tons of stop lights. Although I guess its good that my gas mileage is still about the same as what i was getting stock.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106022 - 10/07/05 08:59 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
Yeah same guy doing the dyno tuning as well, cause he has all the information of my setup stored on his laptop.
The gas mileage is a result of having the car run a bit lean at partial throttle or highway driving. Then the O2 sensor will do minor corrections to the AFR.
#106023 - 10/09/05 05:41 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
eg2.0LT Offline
Loc: NOR T.O
my buddy has pretty much the same set-up stock b20 block with valve reliefs cut out,
pr3 head b16 cams type r intake mani-throttle body oversize-compression is like just over 10.0 and is making 184whp 151torque with a tune and cam gears ajusted. if i were u i would go with wiseco piston and h beam rods, here in canada every all motor street competitor is using that block with stock parts but the head is shaved to the max making over 200whp
#106024 - 10/09/05 07:54 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!!
b6ixteen Offline
Loc: Florida
The motor is already built if you didn't read that part of the thread. I will list the parts when I do the dyno, cause I ended up with a little more than I planned. But yeah I have Wiseco 10.8:1 pistons.
#106025 - 10/16/05 02:16 AM Re: B20B/B16A2 Frankenstein Build. . .Numbers In!!
b6ixteen Offline
Loc: Florida
So I went to the tracks last night. These are my best 3 times of 5 passes. Other passes were 15.1xx and 15.0xx, these were testing launch point/shift point since it was my first time with this motor. With all the runs, I have some serious traction issues even with the drag radials. These are launching at ~4000rpm and shifting at ~7600rpm. I am in right lane for each. Overall I am happy with the times and I know I am capable of much better (see 60'), so I will just do some more practising with this new setup.
Block: B20B
ACL race bearings
KMS block guard
Tranny: Stock S4
ARP headstuds
RC 370cc injectors
Motor Pic.
I'll copy this to the first page so new people can see it on the front.
Thanks to all for help on build/parts/advice etc.
Dyno still to come.
#106026 - 10/16/05 01:09 PM Re: B20B/B16A2 Frankenstein Build. . .Numbers In!!
strsi Offline
Loc: CA
looks good so far. ur traping about 1 mph quicker then me. like u said drop the 60's & it will look even better. too much torque to handle, huh .
that thing's gonna be pretty dam quick once u get a better header & cams.
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106027 - 10/16/05 01:23 PM Re: B20B/B16A2 Frankenstein Build. . .Numbers In!!
b6ixteen Offline
Loc: Florida
Yeah the torque is pretty harsh, I cannot launch at 5000rpm or more. I have my AGXs adjusted accordingly and good psi in the radials, and tried launching there on one pass. The car was hopping and moving from side to side and when I shifted to second, I got so much jerk it flung me back and my radar detector off the windscreen.
Yeah I am going to try work on a better header for now. Then I will do IM, TB, cams & valvetrain. Or should I go cams first? If I get R cams, I will just drop them in as is.
Edit: I also have a video, if anyone wants to host it or let me know where I can host it. That would be .
Edited by b6ixteen (10/16/05 01:26 PM)
#106028 - 10/16/05 01:30 PM Re: B20B/B16A2 Frankenstein Build. . .Numbers In!!
strsi Offline
Loc: CA
if it were me i'd do cams first. sounds nice though. nice job on the build! now i cant wait to see the dyno
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#106029 - 10/16/05 05:44 PM Re: B20B/B16A2 Frankenstein Build. . .Numbers In!!
b6ixteen Offline
Loc: Florida
Thanks. I will try get some cams before dynoing then. I just want a nice torque curve and I know that should look good. When I ran the GT, I left him all the way to 4th he passed me just near the end of the 1/4 mile. And I thought he would have left me cause of the torque those cars got.
#106030 - 10/18/05 04:45 PM Re: B20B/B16A2 Frankenstein Build. . .Numbers In!!
surubasi00 Offline
Loc: VA
maybe i missed it but have you dyno'd it yet?
Dave
#106031 - 10/18/05 06:55 PM Re: B20B/B16A2 Frankenstein Build. . .Numbers In!!
b6ixteen Offline
Loc: Florida
No I haven't. I think I might get some other mods before I do, at least some cams. But I could just do like a 2 pulls (~$40 at local shop) to see the power, only thing is there would be no torque reading, and I am interested to see the torque.
#9122632 - 09/03/17 09:45 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!! [Re: b6ixteen]
fatihin nurul Offline
ngarahkan lalu lintas. Tentu saja, mereka mengkl Supplier sch 40
Supplier sch 40
Supplier Plat kapal besi baja bki krakatau steel
Supplier besi Pipa sch 80 baja
Supplier besi beton Sni Ulir Polos
undangan pernikahan ala jepang
Pabrik Besi Pipa Baja Schedule 40
Toko Besi Unp Baja
Supplier besi wf
Toko sch 40
Toko sch 40
Supplier besi siku
Toko besi Pipa sch 80 baja
Supplier besi wf baja
undangan pernikahan islami
Pabrik Pipa Besi Hitam Medium
Jual Besi Unp Baja
Toko besi wf
Distributor besi beton Sni Ulir Polos polos ulir
Agen sch 40
Agen sch 40
Supplier pipa besi baja sch 40 sch 80
Agen besi Pipa sch 80 baja
Supplier besi unp
undangan pernikahan ada fotonya
Pabrik Besi Wf
Harga Besi Unp Baja
Agen besi wf
Distributor besi beton sii
Pabrik sch 40
Pabrik sch 40
Supplier Plat besi
Pabrik besi Pipa sch 80 baja
Supplier besi siku
undangan pernikahan ala india
Pabrik Besi H beam
Pabrik Besi Unp Baja
Pabrik besi wf
Distributor besi beton psi Ulir Polos
Distributor besi Pipa sch 80 baja
Supplier besi h beam
Distributor Plat Bordes
Supplier Plat besi plat kapal
undangan pernikahan
Pabrik Besi Beton
Distributor Besi Cnp Baja
Distributor Besi Beton
Distributor besi beton perwira
Harga besi Pipa sch 80 baja
Supplier besi wf
Harga Plat Bordes
Supplier besi h beam baja
undangan pernikahan simple
www.sentrabesibaja.com
Supplier Besi Cnp Baja
Harga Besi Beton
Distributor besi beton PAS
Jual besi Pipa sch 80 baja
Supplier wiremesh
Jual Plat Bordes
Supplier besi cnp
undangan pernikahan bermanfaat
Distributor Welded Beam T beam King Queen Cross Castellated Beam
Agen Besi Cnp Baja
Jual Besi Beton
Distributor besi beton master steel ms
Supplier besi unp
Supplier Plat Bordes
www.gudangbesibaja.com
Distributor Bondek Cor
Toko Besi Cnp Baja
Supplier Besi Beton
Distributor besi beton ksty
Supplier besi cnp
Toko Plat Bordes
Pabrik besi Wf Baja
Distributor Atap Spandek Sni
Jual Besi Cnp Baja
Toko Besi Beton
Distributor besi beton krakatau steel
Supplier besi hollow
Agen Plat Bordes
Pabrik bondek
Distributor Plat Bordes Kembang
Harga Besi Cnp Baja
Agen Besi Beton
Distributor besi beton jcac
Pabrik Plat Bordes
Pabrik wiremesh
undangan pernikahan chinese
Distributor Plat Besi Hitam
Pabrik Besi Cnp Baja
Pabrik Besi Beton
Distributor besi beton interworld steel is
ironsteelcenter.com
Distributor Wiremesh Besi
Pabrik pipa besi baja sch 40 sch 80
undangan pernikahan lucu
Distributor Plat Kapal Bki Krakatau Steel
Distributor Besi Hollow Baja
Distributor besi hollow
Distributor besi beton gunung garuda
Harga Plat Bordes
Harga Plat Bordes
Pabrik stainless steel
Harga Wiremesh Besi
Pabrik besi hollow
undangan pernikahan bagus
Distributor Jual Besi Siku Baja
Supplier Besi Hollow Baja
Harga besi hollow
Distributor besi beton delcoprima
Jual Plat Bordes
Jual Plat Bordes
Pabrik atap spandek
Jual Wiremesh Besi sewa villa puncak
Pabrik besi beton Sni Ulir Polos
Distributor Besi Unp Baja Profil Kanal
Agen Besi Hollow Baja
Jual besi hollow
Distributor besi beton cakra steel cs
Pabrik baja ringan
Supplier Wiremesh Besi
Pabrik besi wf baja
undangan pernikahan contoh
Distributor Besi Cnp Profil Baja Gording
Toko Besi Hollow Baja
Distributor besi beton bjku
Jaket Parka Jaket Parka
undangan pernikahan kalender
undangan pernikahan modern
undangan pernikahan online
undangan pernikahan
undangan pernikahan murah
undangan pernikahan artis
undangan pernikahan arab
undangan pernikahan
undangan pernikahan
LINK 6
#9210701 - 12/15/17 11:33 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!! [Re: b6ixteen]
adc580888 Offline
michael kors outlet bags
Nike Air Max
timberland boots outlet
under armour outlet store
jimmy choo heels online
tiffany
new pandora charms
louis vuitton online
michael kors bags sale
Online Oyun
evbid
balenciaga outlet sale
louis vuitton outlet
Nike Free
mk outlet online
kate spade outlet sale
Nike Air Force 1
polo online
kate spade outlet bags store
Burberry Shirt - Official
escarpins
mlb store
Nike Air Max 95
Sunglasses for men
jimmy choo outlet online store
puma sneakers online
puma online sale
Nike Roshe Run Femme
the beat
Nike Dunk SB Low
canada goose outlet online sale
ray ban sunglasses online store
coach factory outlet
payless boots
michael kors bags outlet
kate spade shopping store
kate spade outlet online sale
oakley outlet online sale
Abercrombie Nederland
trazodone100mg
Nike Air Max Tavas
Coach Outlet Online, Coach Factory
louis vuitton belgium
puma sneakers sale
Wholesale Outlet Sale
online shoes,shoes online
michael kors online
Nike Hyperdunk
Abercrombie Outlet
Louis Vuitton Handbags Outlet
jimmy choo australia for sale
Prada bags
michael kors australia online store
moncler jacket
michael kors black friday on sale
timberland boots outlet sale
timberland boots sale
pandora uk
moncler down jackets
80's,eighties fashion
payless shoes outlet
ray-ban glasses
Prada Sunglasses - Official
Nike Air Jordan Homme
ray ban outlet sale
Air Max LTD Femme
Doxycycline
Nike Air Force
breitling mens watches
payless shoes near me
adidas yeezy shoes
Coach Handbags
Michael Kors
swatch watches for men
birkenstock sandals online
handbags sale
michael kors factory outlet on sale
black friday offers
Chanel bags Outlet
Air Max TN
coach outlet online store
Air Jordan Enfant
pandora earrings online sale
2017 Nike Air Max
Nike Free
men hermes belt for sale
michael kors outlet sale online store
michael kors uk online
black friday online sales
kate spade canada
jimmy choo australia online sale
pandora charms outlet
timberland outlet sale
New jordans
Prada bags
hot burberry sale
coach factory outlet online
ugg outlet online store
Jared Jewelry - Official
Premier Jewelry. - Official
puma online
ray ban outlet
Nike Free 7.0
under armour sale
louis vuitton outlet online store
Jordan Flight The Power
birkenstock outlet online sale
chaussure new balance femme
skechers shoes store
spendless shoes australia
Michael Kors Outlet Online
michael kors outlet sale store
coach usa online
nfl store
prada outlet bags
puma shoes sale
the north face outlet store
kanye west shoes sale online
ray ban australia
prada outlet online sale
Zales Jewelry store
quality Lunette Oakley Minute 2.0 pas cher
coach handbags outlet
black friday sales
prada outlet online store
Michael Kors Store
pandora rings
hermes belt kit
pandora princess ring
sunglasses online
Jewelry Armoire - Official
jimmy choo shoes store
oakley sunglasses australia
birkenstock australia
burberry scarf
louis vuitton on sale
michael kors shoes store
eznara.com
Ray-Ban Sunglasses
kate spade online sale
payless shoes store
Lisinopril 2.5 Mg Cost
Kaufen Nike Air Max 1
burberry bags outlet online store
black friday deals
Air Max Femme
Nike Schuhe
payless shoes online
chaussures de sport
kate spade bags
mode damenschuhe
jimmy choo shoes
black friday michael kors online store
Engagement Rings - Official
Oakley Sunglasses
salomon hiking shoes
coach shoes for women
kate spade outlet for sale
hermes bag
moncler jackets
ugg boots on sale
ray ban australia sale
Nike Schuhe Kleinkinder
Green Cleaned
pandora rings uk
online outlet sale
pandora charms outlet sale
ray ban wayfarer sunglasses
gucci men watches
coach australia
mcm outlet online
Nike Roshe Run
kate spade uk store
Nike Air Max Thea
rolex watches for sale
Nike Roshe Run
Longchamp Outlet
kate spade bags
birkenstock sandals online sale
prada bags
Nike Free Run
pandora rings
school bags
Markenschuhe
Nike Air Presto
birkenstock outlet
omega mens watches
birkenstocks on sale
Nike Air Max 95
chanel outlet online store
Air Max
kate spade online store
pandora bracelet charms
jimmy choo uk online
coach purses
Nike Air Max
pandora charms uk store
fulam shoes online
ugg boots sale
michael kors bags
Air Max Lunar 90
louis vuitton bags
Brighton Jewelry - Official
official michael kors
Coach Outlet Store
official prada site
prada uk
ray ban sale
payless shoes sale
michael kors uk online store
pandora bracelet
kate spade handbags online store
kate spade purses sale
Premier Jewelry - Official
boulder shoes
Nike Air Jordan Enfant
blog
ray ban polarized
pandora necklace for sale
Obat Pembesar Penis
[/b]
Dreamland Jewelry - Official
ugg australia
Nike Blazers Mid
Hermes Belt
official rayban
pandora bracelet
Nike Air Jordan
kay jewelry store
adidas verkauf
Louis Vuitton belts
michael kors official site
Nike Air Jordan Hommes
louis vuitton bags on sale
yeezy shoes 350
Air Jordan Running
pandora rings
school bags
Nike Free 5.0
jimmy choo shoes for sale
coach outlet,coach handbags
leather hermes bag sale
cheap ray ban
hermes outlet bag
yeezy 350
under armour stock
MIZUNO Shop US
soccer jerseys
puma outlet online sale
shoes online sale
major league baseball
ray ban
michael kors bags
Diamond Rings - Official
yeezy boost 350
small business
Promise Rings - Official
pandora online outlet
Add Your Link Free
burberry outlet sale store
rayban sunglasses
michael kors handbags outlet
rayban justin
birkenstock canada outlet
burberry bags online,burberry online store
coach sale outlet
louis vuitton online store
pandora bracelet
michael kors outlet online shopping
Salomon Speedcross Shoes
trx
Nike Air Max Lunar
under armour shoes sale
longchamp outlet online
fun games to play
ray-ban aviator
north face sale
michael kors shop australia online store
Prada Shoes - Official
oakley frogskins
mens seiko watches
coach factory
snow boots
Coach Outlet
Nike Air Max BW
Family Name Research
hermes bag sale
Wedding Rings- Official
asics gel
Mizuno Wave
louis vuitton united kingdom
oakley sunglasses online store
Prada Wallet
louis vuitton shopping mall
Nike Hyperdunk
sunglasses hut
Air Max Skyline Femme
black friday ads
prada online
WebDesign
rolex mens watches
mens sunglasses
michael kors bags online sale
ups shipping
Coach Sunglasses Outlet
coach online
puma shoes online
chanel bag
ray ban sale
under armour outlet sale
Black Friday Amazon
diesel mens watches
hermes outlet sale
Nike Air Max Skyline
burberry sale online
chrome hearts jewelry
brand sunglasses
pandora australia online sale
school bags
under armour shoes
kate spade oulet online sale
ray ban erika polarized
cartier watches for women
kate spade on sale
michael kors australia sale store
michael kors outlet shop
chaussures femme pas cher
clb shoes online
louis vuitton bags
Nike Air Max Thea
rayban prescription
puma outlet
michele
pandora official site
coach sale
business
kate spade online outlet
burberry outlet online store
Nike Roshe Run
Nike Air Max Thea
coach factory outlet online sale
kate spade sale
Nike Lebron ST 2
fake sunglasses online
Nike Free
boots
am thuc
[b]pandora jewelry
Kevin Durant Shoes
louis vuitton
Nike Air Max
rayban eyeglasses
pandora australia online store
kate spade outlet sale online store
Nike Air Max
adidas yeezy boost 350 shoes
prada bags outlet
mk outlet
Air Max 180
jimmy choo shoes online
michael kors australia store
kate spade outlet store
Louis Vuitton Shop Online
oakley australia online sale
Coach Sale Online
ray ban outlet
prada outlet bags
ugg slippers online sale
burberry handbags
ugg
Pharmacy Discount Network
coach carter
celine factory outlet
Nike Air Max 2016 Damen
kate spade bags sale
burberry book bag mens
ray ban wayfarer
michael kors online
China Manufacturers
Air Jordan Retro 3
ray ban online store
chrome hearts jewelry for men
chrome store uk
louis vuitton purse
Air Max 95 Homme
casio watches official site
yeezy boost 350 black
puma outlet
Nike Dunk SB
louis vuitton outle sale online
puma suede online store
nike outlet online sale
pandora bracelets
ray ban shop outlet
payless shoes for sale
pandora rings jewelry
Nike TN Enfant
chrome hearts canda
moncler us
tiffany
birkenstock gizeh birko
ray ban outlet online
kate spade black friday
Air Max Homme
kate spade bags on sale
puma sneakers
Jordan Big Ups
birkenstock outlet online store
ray ban glasses frames
burberry outlet online sale
kate spade new collection
Nike Air Max Enfants
Nike Air Max TN
oakley outlet on sale
pandora rings uk
michael kors outlet store
ray ban prescription glasses
nike huarache shoes
timberland shoes online
Air Max TN Homme
michael kors online sale
Ray Ban Outlet
Nike Schuhe Unisex
Nike Roshe Run
Nike Air Max TN Homme
chaussure nike femme
ray ban clubmaster
cheap ray ban
kate spade bags
Air Max TN Homme
kate spade outlet sale store
Nike Free,Nike Shox
burberry outlet
me adc12.16
#9212689 - 12/18/17 08:42 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!! [Re: b6ixteen]
20171219caihuali
toms sko
marc jacobs outlet
polo outlet
polo outlet
giuseppe zanotti outlet
huaraches shopping
longchamp bags
adidas wings
canada goose jackets
michael kors wallets
polo outlet
tory burch outlet
birkenstock outlet
kicks nice
swarovski crystal
tory burch outlet
nike roshe
canada goose parka
lebron james shoes
chrome hearts outlet
fitflops shoes
prada sunglasses
longchamp solde
nike air force 1
burberry outlet
ugg boots clearance
salomon sko
burberry outlet
soccer jerseys
links of london
burberry outlet
nike sko
adidas nmd
fred perry polo shirts
toms sko
air huarache
air max 1
hermes outlet
mulberry sale
adidas trainers
ugg boots
tory burch outlet
chrome hearts
canada goose black friday
montblanc pens
air jordan 4
ugg boots clearance
burberry outlet
rayban sunglasses
reebok outlet store
longchamp pas cher
nike sko
nike store uk
new balance shoes
tods outlet
adidas outlet store
birkenstock sandals
nike free 5
cartier outlet
mulberry outlet
ecco shoes
tory burch outlet
fitflops shoes
[url=http://www.canadagooseoutletgoose.us.com ]canada goose outlet[/url]
supreme clothing
vans shoes
cheap snapbacks
tory burch outlet
kobe shoes
true religion uk
ugg boots clearance
Girls shoes
ugg boots
basketball shoes
tory burch shoes
cheap nhl jerseys
lakers jerseys
herve leger outlet
football shirts
swarovski crystal
salomon shoes
swarovski outlet
adidas nmd
swarovski outlet
soccer jerseys
adidas uk
ysl outlet
supreme clothing
supreme clothing
futbol baratas
vans sko
dansko shoes
polo shirts
valentino outlet
canada goose cyber monday
moncler jackets
tory burch outlet
ralph lauren polo shirts
ralph lauren pas cher
air huarache
cleveland cavaliers jersey
timberland boots
nike roshe one
reebok trainers
ed hardy clothing
polo outlet
polo outlet
bottega veneta outlet
prada shoes
ugg black friday
ugg boots
michael kors bags
soccer shoes
nfl jerseys wholesale
ugg boots clearance
ecco sale
canada goose coats
adidas sko
cheap jerseys
mac cosmetics
chicago blackhawks jerseys
thomas sabo
vans greece
air max trainers
mulberry outlet
lacoste polo shirts
supra shoes
coach outlet canada
ugg boots
kobe 9
mcm outlet
true religion outlet
ugg boots
ugg outlets
puma outlet
ugg boots
ugg boots clearance
cheap snapbacks
longchamp pliage
coach canada
nike factory outlet
cheap jerseys
ugg cyber monday
hermes birkin
swarovski outlet
nike air max 2015
hermes belt
ugg boots
fitflops sale
kobe bryant shoes
polo outlet
converse shoes
polo outlet
cazal sunglasses
mulberry bags
rayban sunglasses
hermes outlet
longchamp solde
toms sko
nike sko
air max uk
kevin durant shoes
fitflops outlet
moncler jackets
polo outlet
christian louboutin online
nfl jersey wholesale
yeezy boost 350
lacoste soldes
ray bans
nike foamposite
uggs
coach handbags
timberland sko
swarovski outlet
coach handbags
supreme clothing
tory burch outlet
hogan scarpe
ray-ban sunglasses
mulberry bags
asics shoes
new balance shoes
ugg boots clearance
converse shoes
20171219caihuali
#9214703 - 12/20/17 08:41 PM Re: B20B/B16A2 Frankenstein Build. . .Questions and Issues!! [Re: b6ixteen]
20171221yuanyuan Offline
nike outlet store
louis vuitton outlet store
ugg boots
ugg boots
ralph lauren sale
air max
ray ban sunglasses discount
pandora jewelry outlet
cheap ugg boots
michael kors outlet clearance
nike outlet store
timberland outlet
longchamp sale
gucci outlet
oakley sunglasses outlet
adidas outlet online
ugg
longchamp bags
birkenstock outlet
retro 11
adidas nmd r1
burberry handbags
supreme clothing
toms shoes
canada goose coats
ray ban glasses
yeezy shoes
air jordans
hermens
louboutin outlet
pandora charms sale
valentino outlet
ugg outlet store
cheap ugg boots
discount oakley sunglasses
coach outlet canada
ray bans
nike outlet online
canada goose outlet store
adidas nmd r1
canada goose coats
fred perry shirts
nike outlet online
yeezy boost 350
adidas nmd runner
canada goose coats
moncler sale
moncler jacket
ugg boots
ugg boots
north face outlet
north face sale
burberry outlet
louis vuitton factory outlet
canada goose coats
jordans
nike sneakers
ugg boots sale
moncler
bottes ugg
pandora uk
supreme uk
adidas yeezy boost
ugg outlet store
pandora uk
ray bans
ray ban sunglasses cheap
nmd adidas
hermes bag
moncler jackets
pandora
longchamp outlet store
ugg boots
ugg outlet store
valentino
mulberry
ugg canada
ugg boots
salvatore ferragamo shoes
uggs
red bottoms
north face outlet
mbt
ugg boots
ugg outlet online
coach factorty outlet online
yeezy boost 350
canada goose coats
cheap jordans free shipping
moncler sale
uggs clearance
moncler coats
ugg australia outlet
adidas ultra boost
cheap ugg boots
adidas yeezy shoes
canada goose coats
cheap jordans for sale
nike sneakers
hermes outlet
moncler outlet online
tory burch outlet online
longchamp bags
ugg canada
uggs clearance
ugg boots outlet
ugg boots outlet
ralph lauren sale
nike air max 2018
hermes handbags
adidas outlet store
air max
caterpillar boots
air jordan retro
ugg sale
adidas sneakers
moncler uk
air max shoes
gucci outlet online
moncler jackets
fitflop sandals
hermes bags
cheap air jordans
supreme shirts
ugg outlet online
burberry handbags
moncler pas cher
harden vol 1
mulberry uk
moncler coats
nike outlet store online
adidas yeezy boost
cheap air jordans
ugg boots
moncler jackets
coach purses
burberry handbags
adidas outlet store
north face jackets
yeezy shoes
red bottom heels
yeezy boost 350
mulberry outlet uk
michael kors outlet canada
ugg boots
birkenstock shoes
michael kors bags
cheap uggs
ugg boots
cheap ugg boots
adidas superstars
canada goose jacket
coach outlet canada
mlb jerseys cheap
adidas nmd r1
adidas store
ugg boots outlet
salvatore ferragamo outlet
air jordan shoes
moncler uk
moncler coats
timberland outlet store
ugg outlet online
columbia sportswear outlet
yeezy shoes
canada goose jackets uk
canada goose parka
cheap nfl jerseys wholesale
uggs on sale
adidas superstar shoes
birkin handbags
cheap air jordans
mbt
the north face jackets
red bottom
louboutin outlet
pandora jewelry store
adidas nmd runner
uggs on sale
north face jackets
hermes bags
ugg boots
ugg boots women
tory burch shoes
ugg boots
ugg outlet store
Page all of 3 123>
Moderator:  Runnin@Redline Jr, Dr. BrokenLimits, Professor Paki
