#3940575 - 07/28/09 03:25 PM 99 Civic SI timing belt replacement, please assist.
wjc05sti Offline
Loc: San Diego, CA
Ok, the wife's 99 Civic Si is at 114k and it's past due the timing belt change. I want to do this myself, maybe with the help of my neighbor, so I can learn in the process. How difficult is this to do? I'm pretty sure I can follow the directions on the manual, I'm just confused and scared about the timing, etc.
Also, I plan to buy the parts from hondaautomotiveparts.com, what do I need?
Thank you.
#3942051 - 07/29/09 07:43 AM Re: 99 Civic SI timing belt replacement, please assist. [Re: wjc05sti]
kyden Offline
Loc: Providence, RI
i would do timing belt, water pump, and tensioner. might as well do accessory belts while you're at it.
its pretty easy to do, just make sure you follow the helms manual and get all the timing marks correct. its just a matter of lining up marks on the cam gears and at the oil pump.
edit: if you don't have access to air tools, make sure you get the tool to get the crank pulley off.
#3947557 - 07/30/09 09:14 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: kyden]
4doorEG Administrator Offline
Loc: Overland Park, KS
What he said. I also adjust the valve and put a new valve cover gasket on it.
I think the hardest thing I see people have issues with is lining up the timing marks and then also properly tensioning the belt.
#3949267 - 07/31/09 01:00 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: 4doorEG]
wjc05sti Offline
Loc: San Diego, CA
Ok, I'm going to buy the accessory belts locally because online there are different ones that don't seem to match and I'll rather get them locally where I can return them if needed. I'll go over the manual and I'll ask questions. thanks.
#3963593 - 08/06/09 11:30 AM Re: 99 Civic SI timing belt replacement, please assist. [Re: wjc05sti]
wjc05sti Offline
Loc: San Diego, CA
The manual that I have is for the 96-00 Civic and the timing belt removal, etc is only for the SOHC \:\( Does anyone have the manual on how to do it for the DOHC?
#3963721 - 08/06/09 11:57 AM Re: 99 Civic SI timing belt replacement, please assist. [Re: wjc05sti]
DevoStevo Offline
CSI Cars 4 Sale Dealer
Loc: usa
While you have the timing belt off, I would replace the seals behind it as well.
“ All in all, you're just another brick in the wall.”
#3963760 - 08/06/09 12:09 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: DevoStevo]
kyden Offline
Loc: Providence, RI
this is for a gsr, but its the same thing.
http://www.c-speedracing.com/howto/timingbelt/tbelt.php
#3963986 - 08/06/09 12:50 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: kyden]
wjc05sti Offline
Loc: San Diego, CA
thanks for the link...i think i will buy the manual as well.
Which seals should I replace? Is ther anything else in that area that I should replace as well?
#3967184 - 08/07/09 01:13 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: wjc05sti]
wjc05sti Offline
Loc: San Diego, CA
I bought the Chilton manual from Kragen and it sucks. It just tells you what to do, but no step by spep instructions nor good illustrations. I'm going to return it.
#3967252 - 08/07/09 01:36 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: wjc05sti]
kyden Offline
Loc: Providence, RI
http://downloads.hondatech.info/Auto/Man...ce%20Manual.zip
use that.
#3970085 - 08/09/09 12:45 AM Re: 99 Civic SI timing belt replacement, please assist. [Re: kyden]
wjc05sti Offline
Loc: San Diego, CA
Thanks, I read the entire procedure and I'm confident that I can do this now \:\)
I have a list of things to get and I'm awaiting the parts. I'll report back with questions and once I've done the work.
Which are the seals that I should replace as mentioned on a post above?
#3970337 - 08/09/09 09:08 AM Re: 99 Civic SI timing belt replacement, please assist. [Re: wjc05sti]
DevoStevo Offline
Loc: usa
I think they are the front camshaft and crankshaft oil seals, but there might be more, I always let me mechanic do it, so I'm not positive.
#3971851 - 08/09/09 10:07 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: DevoStevo]
kyden Offline
Loc: Providence, RI
i have never seen those leak unless they were messed with.
#3978553 - 08/11/09 10:51 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: kyden]
Import Tuner Offline
Gold Member
Loc: Tacoma, Wash..
Exactly, they leak when people fuck with em...
Leave em be!...
Donny
Import Specialty Automotive
#9122636 - 09/03/17 09:47 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: Import Tuner]
fatihin nurul Offline
p kami memiliki Val dan dua anak-anak di Rumah Sa undangan pernikahan klub bola
Agen Welded Beam T beam King Queen Cross Castellated Beam
undangan pernikahan cetak
Pabrik besi cnp baja
Agen Plat Besi Hitam
undangan pernikahan
Agen Jual Besi Siku Baja
Agen Bondek Cor
Agen Atap Spandek Sni
Toko besi beton psi Ulir Polos
Distributor besi cnp baja
undangan pernikahan klasik
Distributor besi h beam baja
Agen Plat Kapal Bki Krakatau Steel
Agen Besi Unp Baja Profil Kanal
Distributor Stainless steel
Agen Plat Bordes Kembang
Toko besi beton perwira
Harga besi cnp baja
Harga besi cnp baja
undangan pernikahan cantik elegan
Harga besi h beam baja
jasa konstruksi baja
undangan pernikahan simple
Agen Besi Cnp Profil Baja Gording
Supplier Stainless steel
Toko besi beton PAS
Jual besi cnp baja
Jual besi cnp baja
undangan pernikahan custom
Jual besi h beam baja
www.pusatbesibaja.co.id
undangan pernikahan murah
Agen Besi Hollow
Agen Stainless steel
Harga besi cnp baja
Toko besi beton master steel ms
Supplier besi cnp baja
undangan pernikahan cute
Supplier besi h beam baja
www.pusatbesibaja.com sewa villa puncak
undangan pernikahan unik
Agen Wiremesh
Toko Stainless steel
Jual besi cnp baja
Toko besi beton ksty
Toko besi cnp baja
Toko besi cnp baja
undangan pernikahan coklat
Toko besi h beam baja
undangan pernikahan biasa
Agen Besi Pipa Baja Schedule 80
Jual Stainless steel
Toko besi beton krakatau steel
Agen besi cnp baja
Agen besi cnp baja
undangan pernikahan cantik dan murah
Agen besi h beam baja
Agen besi beton Sni Ulir Polos polos ulir
undangan pernikahan bunga
Agen Besi Pipa Baja Schedule 40
Harga Stainless steel
Toko besi cnp baja
Toko besi beton jcac
undangan pernikahan casual
Pabrik besi h beam baja
Agen besi beton sii
undangan pernikahan artis
Agen Pipa Besi Hitam Medium
Pabrik Stainless steel
Agen besi cnp baja
Toko besi beton interworld steel is
undangan pernikahan contoh
Distributor plat besi hitam
Agen besi beton psi Ulir Polos
undangan pernikahan modern
Agen Besi Wf
Distributor Baja Ringan
Distributor Wiremesh Besi
Toko besi beton gunung garuda
undangan pernikahan chinese
Harga plat besi hitam
Agen besi beton perwira
Agen Besi H beam
Supplier Baja Ringan
Harga Wiremesh Besi
Toko besi beton delcoprima
Jual plat besi hitam
Agen besi beton PAS
Agen Besi Beton
Agen Baja Ringan
Jual Wiremesh Besi
Toko besi beton cakra steel cs
Supplier plat besi hitam
Agen besi beton master steel ms
undangan pernikahan animasi
www.sentrabesibaja.com
Toko Baja Ringan
Supplier Wiremesh Besi
Toko besi beton bjku
Toko plat besi hitam
Agen besi beton ksty
Toko Welded Beam T beam King Queen Cross Castellated Beam
Jual Baja Ringan
Toko Wiremesh Besi
Toko besi beton Sni Ulir Polos
undangan pernikahan buatan sendiri
Agen plat besi hitam
Agen besi beton krakatau steel
undangan pernikahan biru
Toko Bondek Cor
Harga Baja Ringan
Agen Wiremesh Besi
Toko besi beton ais
undangan pernikahan batik
Pabrik plat besi hitam
Agen besi beton jcac
undangan pernikahan arab
Toko Atap Spandek Sni
Pabrik Baja Ringan
Pabrik Wiremesh Besi
Toko besi beton
Jaket Parka Jaket Parka
undangan pernikahan kalender
undangan pernikahan islami
undangan pernikahan online
undangan pernikahan
undangan pernikahan
undangan pernikahan
LINK 10
#9189985 - 11/17/17 09:00 AM Re: 99 Civic SI timing belt replacement, please assist. [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
abercrombie and fitch
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
#9214651 - 12/20/17 08:38 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: ]
20171221yuanyuan Offline
nike outlet store
louis vuitton outlet store
ugg boots
ugg boots
ralph lauren sale
the north face outlet
air max
ray ban sunglasses discount
pandora jewelry outlet
fred perry polo shirts
cheap ugg boots
canada goose jackets
coach factory outlet online
michael kors outlet clearance
nike outlet store
timberland outlet
longchamp sale
gucci outlet
oakley sunglasses outlet
adidas outlet online
ugg
longchamp bags
birkenstock outlet
michael kors outlet store
retro 11
adidas nmd r1
burberry handbags
supreme clothing
toms shoes
canada goose coats
ray ban glasses
yeezy shoes
air jordans
hermens
louboutin outlet
pandora charms sale
valentino outlet
ugg outlet store
cheap ugg boots
discount oakley sunglasses
coach outlet canada
ray bans
nike outlet online
canada goose outlet store
adidas nmd r1
canada goose coats
fred perry shirts
burberry outlet online
nike outlet online
yeezy boost 350
adidas nmd runner
canada goose coats
kate spade outlet online
moncler sale
moncler jacket
ugg boots
ugg boots
north face outlet
north face sale
burberry outlet
louis vuitton factory outlet
canada goose coats
jordans
nike sneakers
ugg boots sale
moncler
bottes ugg
pandora uk
supreme uk
adidas yeezy boost
ugg outlet store
pandora uk
ray bans
ray ban sunglasses cheap
nmd adidas
hermes bag
moncler jackets
pandora
longchamp outlet store
ugg boots
ugg outlet store
valentino
coach handbags outlet
mulberry
adidas yeezy boost 350
ugg canada
ugg boots
salvatore ferragamo shoes
uggs
red bottoms
north face outlet
mbt
ugg boots
ugg outlet online
coach factorty outlet online
yeezy boost 350
canada goose coats
cheap jordans free shipping
moncler sale
uggs clearance
moncler coats
ugg australia outlet
adidas ultra boost
cheap ugg boots
adidas yeezy shoes
canada goose coats
cheap jordans for sale
nike sneakers
hermes outlet
moncler outlet online
tory burch outlet online
longchamp bags
ugg canada
uggs clearance
ugg boots outlet
ugg boots outlet
ralph lauren sale
nike air max 2018
hermes handbags
adidas outlet store
air max
caterpillar boots
air jordan retro
ugg sale
adidas sneakers
moncler uk
air max shoes
gucci outlet online
moncler jackets
fitflop sandals
hermes bags
cheap air jordans
supreme shirts
pandora charms outlet
ugg outlet online
burberry handbags
moncler pas cher
harden vol 1
mulberry uk
moncler coats
nike outlet store online
adidas yeezy boost
cheap air jordans
ugg boots
moncler jackets
coach purses
burberry handbags
adidas outlet store
north face jackets
yeezy shoes
red bottom heels
yeezy boost 350
mulberry outlet uk
michael kors outlet canada
ugg boots
birkenstock shoes
michael kors bags
cheap uggs
ugg boots
cheap ugg boots
adidas superstars
canada goose jacket
coach outlet canada
mlb jerseys cheap
adidas nmd r1
adidas store
ugg boots outlet
salvatore ferragamo outlet
air jordan shoes
moncler uk
moncler coats
timberland outlet store
ugg outlet online
columbia sportswear outlet
yeezy shoes
canada goose jackets uk
canada goose outlet online
canada goose parka
cheap nfl jerseys wholesale
uggs on sale
adidas superstar shoes
birkin handbags
cheap air jordans
mbt
the north face jackets
red bottom
louboutin outlet
pandora jewelry store
adidas nmd runner
uggs on sale
north face jackets
hermes bags
ugg boots
ugg boots women
tory burch shoes
ugg boots
ugg outlet store
#9236007 - 01/21/18 09:22 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: 20171221yuanyuan]
Andada
colts jerseys
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
michael kors handbags sale
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
buffalo bills jerseys
fitflops sale
nike huarache
seattle seahawks jerseys
jaguars jersey
#10080288 - 06/26/21 12:26 PM Re: 99 Civic SI timing belt replacement, please assist. [Re: Anonymous]
TittyQ Offline
Loc: The unknown
SPAM
#10200904 - 01/28/22 08:03 AM Re: 99 Civic SI timing belt replacement, please assist. [Re: TittyQ]
Honda350 Offline
Loc: South FL
You are not looking for fit flops?
Moderator:  4doorEG, Pakisurf
